POV-Ray : Newsgroups : povray.binaries.images : alpha channel not work Server Time
20 Apr 2026 14:24:21 EDT (-0400)
  alpha channel not work (Message 11 to 16 of 16)
Subject: Re: alpha channel not work
Date: 7 Aug 2014 21:15:00
Message: <web.53e423b8c9af2909397e8cbb0@news.povray.org>
> Am 07.08.2014 04:19, schrieb liujg:
> >          image_map { gif "DHKX0221.gif"  transmit 0, 1.0}
> >           finish {
> >        specular 0.3
> >        roughness 0.01
> >   // translate <1,  2, 5>
> > Such as can render to have result picture,but I change image_map { gif
> > "DHKX0221.gif"  transmit 0, 1.0}to image_map { png "DHKX0221.png"  transmit 0,
> > 1.0}. The povray will have a parse error ,keyword "transmit"cann't use with non
> > color_map image.Why? Thank you.
> In .gif image files, for each pixel only a single value in the range
> 0..255 is stored: This is an index into a table of RGB colours (the
> so-called "palette").
> The syntax
> tells POV-Ray that each pixel referring to the first entry of the palete
> should be treated as being transparent.
> PNG files (normally) don't use a palette, but store RGB colours for each
> pixel, so the above approach does not work.
SO How can I use PNG files which contains alpha channel to be treated as being
transparent in some area.
Thank you .
Date: 7 Aug 2014 23:45:01
Message: <web.53e446c9c9af290914ed8b7f0@news.povray.org>
Your problem is not how to use the alpha channel in POV-Ray, your problem is
that your alpha channel inside the PNG image does not specify any transparent
parts. The alpha channel inside your PNG image currently says all pixels are not
transparent. You need to change the alpha channel inside your PNG image to
specify which parts of the PNG image are to be transparent.
To modify the all-non-transparent alpha channel inside your PNG image, you need
to open your PNG image inside an image editor that supports PNG images with
alpha channel. Then you modify the alpha channel inside the PNG image using the
image editor to specify which parts of the image are transparent. You can only
modify the PNG image inside an image editor. You cannot modify the PNG image
inside POV-Ray.
Once you have specified, using the image editor, which parts of the PNG image
are transparent, the image editor will save a valid alpha channel for your PNG
image. This alpha channel, created by the image editor, needs to specify the
transparent parts of the image, meaning the data in the alpha channel will be
different for transparent and non-transparent parts of the image. All this is
done in an image editor, it is not done in POV-Ray.
After you have specified the transparent parts of the image using your image
editor, you can save the modified PNG image and use it in POV-Ray. But as said,
you need to use the image editor first. This is not a problem with POV-Ray or a
problem using POV-Ray. This is a problem with your PNG image that does not
contain transparent areas in its alpha channel. Its alpha channel currently says
all pixels are non-transaprent. You need to specify which pixels are transparent
inside the PNG image using an image editor.
Date: 7 Aug 2014 23:50:07
Message: <53e448ef$1@news.povray.org>
Am 08.08.2014 03:11, schrieb liujg:
>> The syntax
> Thank you .
You did everything right on the POV-Ray side: Normally you would simply use:
     image_map { png "DHKX0221.png" }
*BUT*, what we're trying to tell you all along:
     Your *IMAGE* is *BROKEN*.
     It does *NOT* contain a /useful/ alpha channel.
Whoever created this image did something wrong when trying to add an
alpha channel to the image. The alpha channel is there, but the
information in there says, "all pixels are opaque; there are no
transparent portions in this image."
How to fix this depends on your image manipulation program, and really
has nothing to do with POV-Ray at all.
Date: 8 Aug 2014 00:09:48
Message: <53e44d8c@news.povray.org>
> Thank you .
Try this image to see how it /would/ work in POV-Ray if only your image
had a proper alpha channel.
Download 'dhkx0221_.png' (703 KB)
Preview of image 'dhkx0221_.png'
Date: 10 Aug 2014 02:25:01
Message: <web.53e70fc2c9af2909c2d977c20@news.povray.org>
> Thank you .
Here is a 'visual guide' to the problem you are having. It compares your .png
image to Clipka's corrected version. Your all-white alpha channel simply needs
the proper 'mask shape'-- which is missing.  ;-)
Download 'comparison.jpg' (101 KB)
Preview of image 'comparison.jpg'
Date: 11 Aug 2014 00:22:36
Message: <53e8450c@news.povray.org>
Oh, and to add to what everyone else has said, one thing that annoys the
hell out of me is how Photoshop handles "backgrounds". If the background
has alpha, your fine, if it doesn't, then you can have a "layer" with
it, but once you export that it something like png, the result merges
the solid background, while still "seeming" to have alpha in it. There
is a way around this, but, sadly, it isn't as simple as, say, setting
the color to alpha, then using a fill tool (you can do that in Paintshop
Pro, or could, in older versions, and I think it also has/had a direct
replacement thing you could do). Photoshop treats all colors, no matter
how transparent they are, as something to "paint over" the background,
not replace. This means that you can never add transparency to
background, where the background doesn't already contain it, it will
just be ignored.
So, to get alpha in an image that doesn't have it you need to make a
copy of the "background" layer, which is what will eat the alpha layer
when it merges into the png. This new layer can now have sections
"edited out" making them transparent. Then, delete the unneeded
background. When saved, it should result in nothing ending up "under"
the parts you want to be see through.
But, so long as the background doesn't contain, and never did contain,
any alpha, the png will never show any either, when created. The
background will simply "fill in" any holes you have in the image, in
your case, with black.
Commander Vimes: "You take a bunch of people who don't seem any
different from you and me, but when you add them all together you get
this sort of huge raving maniac with national borders and an anthem."
