It's been a while since I had some time and inspiration to create something in
POV-Ray, but I had a bit of both recently. Here's the result, which I hope you
like.
Cheers,
Erwin
Download 'gear-800x600-withtitle.jpg' (48 KB)
Preview of image 'gear-800x600-withtitle.jpg'
On 19/05/2014 20:26, Eriban wrote:
> Hi,
> like.
> Cheers,
> Erwin
That is nice. I've not seen that one before.
:-D
Regards
I solemnly promise to kick the next angle, I see.
Very nice, and a wonderful variation of the triangle (wasn't that Escher?
) image.
Now I want to know how it was done. ;)
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
"Eriban" <pov### [at] spamgourmet com> wrote:
> Hi,
> like.
> Cheers,
> Erwin
That's unpossible!
> Hi,
> like.
> Cheers,
> Erwin
Very good, I understand how someone can draw something like this but to model it
in POV... I have no idea how that could be done.
Sean
>> Hi,
>> like.
>> Cheers,
>> Erwin
> Sean
Make it a T-shirt... or a corporate logo !
Actually, wonderful on a black T-shirt, need a white background for
printed logo, but not sure it remains as lovely.
It remind me of Escher, but of different kind.
http://www.4-construction.com/fr/magazine/images/formes-geometriques-dans-les-peintures-de-mc-escher_7539/12345/
The gear could be the next General Motors' or any steel/mechanic-related
company.
Or even a TV channel.
Just because nobody complains does not mean all parachutes are perfect.
On 19-5-2014 21:26, Eriban wrote:
> Hi,
> like.
You truly are a 3D Escherian. Very well done indeed. And beautiful too.
Thanks for all your comments. Please find my replies below.
> :-D
It's indeed far less common than the impossible triangle for example. However,
this illusion is not the first of its kind. See for example
http://im-possible.info/english/art/computer/ausbourne.html or
http://impossible-world.blogspot.nl/2014/03/impossible-cog-wheels.html. The
drawings on the latter page actually inspired this one.
Jim Henderson <nos### [at] nospam com> wrote:
> Very nice, and a wonderful variation of the triangle (wasn't that Escher?) image.
Thanks. Escher indeed created drawings based on the impossible triangle,
The basic part of this illusion is quite straightforward to achieve. Two halfs
of the gear, oriented at right angles and placed such that they appear to line
up.
The devil is in the detail though. Given that the surface is reflective (and
also has a subtle normal) a few more tricks are needed to avoid discontinuities.
It's rendered in one go though, and did not require any post-processing.
"jhu" <nomail@nomail> wrote:
> That's unpossible!
Well, apparently not. Ray-tracers don't lie... ;-)
Thanks. My above reply to Jim gives some insight on how to start. One of the
advantages of ray-tracing is that you have quite powerful tools at your
disposal: perfectly accurate object placement, perfect mirrors, perfect copies
of objects, programmatic textures, etc. Those all really help when rendering
impossible objects.
Might make a nice t-shirt indeed. The black background really helps to make the
object stand out, so best to leave that unchanged.
Yes, it's quite similar to the ribbons in Escher's "Cube with magic ribbons"
drawing. That one, however, is more advanced with bumps slowly morphing into
dents. Maybe I should give that a go as well sometime.
> company.
It's a question though whether it then represents excellence, or shoddy
craftsmenship ;-)
Thanks. This is indeed becoming my ray-tracing specialty. The only thing I can
do reasonably well. Ah well, better that than doing many things poorly I
guess...
Cheers,
Erwin
> (and also has a subtle normal) a few more tricks are needed to avoid
> discontinuities.
Indeed, I could see that this would make things really challenging. You
did a /fantastic/ job with lining things up and avoiding reflections that
give it away. :)
Jim
Eriban wrote:
> Hi,
> something in POV-Ray, but I had a bit of both recently. Here's the result,
> which I hope you like.
> Cheers,
> Erwin
I don't like it, I love it. It puts the impossible cube I did a while ago way to
shame.
Ger
