scott <sco### [at] scottcom> wrote:
> > I have changed with your advice,and have a test.but the image is black.Nothing
> > in my scene.
> It's always helpful to post the bit of code you changed, otherwise
> nobody has any idea why your image is black, it could many different
> reasons.
> This works for me, I also added the rotate command as it seems your
> points are not aligned with the axes:
> box
> -1.55,1.55
> rotate y*-30
> translate <x1-center_x,y1-center_y,z1-center_z>
> pigment{color rgb 1}
> finish {
> ambient 0
> diffuse ref
> May I ask where you got the "reflection" numbers from in your
> pov-ref.txt file? If I knew where those numbers came from it might help
> trying to figure out what you want to achieve.
These "reflection" numbers in pov-ref.txt file are extracted from a image,which
with location and reflective information for 40000 points.We call this image a
reflecity image in remote sensing.This image is photoed by flight.Thank you for
your advice.I go to have a try!Gratitudes!
> > in my scene.
> reasons.
> box
> -1.55,1.55
> rotate y*-30
> finish {
> ambient 0
> diffuse ref
Yes,with this change,I have got a image which I wanted.However,the whole trend
of the values of pixels is different from my true radiance.
> > in my scene.
> reasons.
> box
> -1.55,1.55
> rotate y*-30
> finish {
> ambient 0
> diffuse ref
The anlyze.doc is the image simulated by pov with your advice.However,I compared
it with my true image,there is huge differeces in it!Beg you have a look!
Download 'anlyze.doc.dat' (132 KB)
> > in my scene.
> reasons.
> box
> -1.55,1.55
> rotate y*-30
> finish {
> ambient 0
> diffuse ref
I am so sorry.Above anlyze.doc is wrong by myself.This .doc is right!Sorry!
Download 'anlyze.doc.dat' (215 KB)
"CAS" <sup### [at] cstnetcn> wrote:
> > >>> Hello,everyone.I am a student.I am doing my graduation project recently.It is
> > >>> simulating radiance with ray-tracing.I have done a test with pov.But I am
> > >>> confronting a error with my result.Could anyboby help me check out my
issue.Beg
> > >>> a hot.I am a student.I am confronting the pressure of graduation.I feel so
> > >>> worry.I have uploaded the whole process of my test,beg a hot help me!
> > >>> "pov-xyz"is the location of each sphere.
> > >>> "pov-ref"is the reflectivity of each sphere.
> > >>> "pov.exr"is the output image by pov.
> > >>> I have converted "pov.exr" to "pov.tiff".
> > >>> "result"is my analyse.My issue was wrote in it.
> > >>> Expecting somebody help me.Great gratitudes!
> > >> Using a specular highlight on tiny spheres is going to give very
> > >> unpredictable results, the output pixel value will highly depend on
> > >> exactly where the ray hits the sphere compared to the highlight
> > >> position. I zoomed in on your scene and rendered it, see attached, I
> > >> also changed the background colour to red to highlight the spheres
> > >> better. Do you see the problem?
> > >> I would use boxes rather than spheres and use diffuse rather than
> > >> specular reflection:
> > >> finish {
> > >> ambient 0
> > >> diffuse ref
> > >> That should give much more uniform results and not depend on where each
> > >> ray hits the shapes. I don't know if that will solve your problem or not.
> > > I have modified the statements and done a test with your advice.I find the
> > > result changed,but not what I wanted.Besides,I only have 40000 points ,if I used
> > > box as my model, which needs two points to describle,but my input scene is as
> > > "pov.tif".One point stands for one object,corresponding,with a reflectity.If I
> > > used box,may need two point to descible a object,I doublt the scene is not my
> > > wanted.
> > You can use boxes instead of spheres without doubling the size of your
> > file. Curently, you use this code to place your spheres:
> > sphere {
> > <x1-center_x,y1-center_y,z1-center_z>,1.55
> > finish { ambient 0
> > emission 0
> > specular ref
> > To use box, just use this code:
> > box{-1.55, 1.55 // reduce slightly is you want to keep some gap.
> > // The following line is the key...
> > finish { ambient 0
> > emission 0
> > specular ref
> > This will give you boxes with a width identical to the diameter of your
> > spheres.
> > Even beter, make an union containing all your objects:
> > union{
> > #fopen Input_geom_file geom_file_name read
> > #fopen Input_spec_file spec_file_name read
> > #while(defined(Input_geom_file))
> > #read(Input_geom_file, X1, Y1, Z1)
> > #read(Input_spec_file, Ref)
> > translate <X1-Center_X,Y1-Center_Y,Z1-Center_Z>
> > }// Remove the texture from the objects
> > #end
> > // and apply it to all objects at once
> > finish { ambient 0
> > emission 0
> > specular Ref
> > }// End of the union
> > As the variable "n" is never used, I removed it.
> > Finaly, a general recomendation: In all of your user defined variable,
> > use at least ONE upper case letter. This ensure that you don't have any
> > conflict with predefined variables and primitive. It also make it clear
> > that those are YOUR variables. It can realy help when debugging your code.
> > Alain
> Hello,I want to ask a question:
> "try
> Imf::RgbaChannels channels;
> if (options.grayscale)
> if (use_alpha)
> channels = WRITE_YA; // only write luminance & alpha
> else
> channels = WRITE_Y; // only write luminance
> else
> if (use_alpha)
> channels = WRITE_RGBA; // write RGB & alpha
> else
> channels = WRITE_RGB; // write RGB"
> this is a part of resource code in openexr.cpp,I want to write luminance
> only,how can I set some parameters in pov?
-UA :Sets alpha output off
+Feg:output type 'e' grayscale output
I set "-UA +Feg" in command line,but messages says :grayscale not currently
supported whith output file format "e";But only openexr file supports luminance
output.How can I solve this problem?
>>>>>> confronting a error with my result.Could anyboby help me check out my issue.Beg
>>>>> finish {
>>>>> ambient 0
>>>>> diffuse ref
>>>> wanted.
>>> sphere {
>>> finish { ambient 0
>>> emission 0
>>> specular ref
>>> finish { ambient 0
>>> emission 0
>>> specular ref
>>> spheres.
>>> union{
>>> #end
>>> finish { ambient 0
>>> emission 0
>>> specular Ref
>>> Alain
>> "try
>> if (use_alpha)
>> else
>> else
>> if (use_alpha)
>> else
Currently PNG, and PPM are the only file formats that support grayscale
output
issue.Beg
> >>>>> finish {
> >>>>> ambient 0
> >>>>> diffuse ref
used
> >>>> wanted.
> >>> sphere {
> >>> finish { ambient 0
> >>> emission 0
> >>> specular ref
> >>> finish { ambient 0
> >>> emission 0
> >>> specular ref
> >>> spheres.
> >>> union{
> >>> #end
> >>> finish { ambient 0
> >>> emission 0
> >>> specular Ref
> >>> Alain
> >> "try
> >> if (use_alpha)
> >> else
> >> else
> >> if (use_alpha)
> >> else
> output
"try
if (use_alpha)
else
else
if (use_alpha)
else
this is a part of resource code in openexr.cpp,and only this text mentions
something about luminance.
However,when I turn on grayscale output for png file ,setting alpha turned
off,the result of simulated image may not be luminance,what is it?I input "-UA
+FNg"in command line,whcih is supported.
I must admit I don't have much experience with OpenEXR output. What
happens if you render the below scene to OpenEXR and check the
luminance, what values to you get for different values of "ref"? Do they
match up?
#version 3.7
global_settings {assumed_gamma 1}
#default{ finish{ ambient 0.0 diffuse 1.0 }}
camera
orthographic
location z
look_at 0
light_source{ <0,0,10> color rgb 1 }
#local ref = 0.5;
box { -1/2 1/2 pigment{ color rgb ref} }
> match up?
> #version 3.7
> camera
> orthographic
> location z
> look_at 0
> #local ref = 0.5;
XYZ.txt stores 40000 points,REF.txt stores 40000 points.XYZ is matching up
REF.One xyz stands for one surface,one ref stands for the reflectivity of
surface.XYZ matches REF.
> match up?
> #version 3.7
> camera
> orthographic
> location z
> look_at 0
> #local ref = 0.5;
I have tryed a lot of outputs.Only I set the output exr,the trend of whole
image is the same as my real luminance or radiance,but the value of each pixel
has huge error compared with my real radiance.
