Ger <No.### [at] ThankYou> wrote:
> Or for a CRT you could also use http://www.displaycalibration.com/
WELL!!
I'm embarrassed to say that my CRT monitor was *not* well-calibrated, when I
*thought* it was OK. I followed the procedure on that page (and also re-ran my
'Adobe gamma' app, as well as looking again at POV-Rays' gamma documentation
image), and the results are MUCH better-- I can now see the details in the two
..png's that I posted about. (Before, in FractRacer's image, I couldn't see any
details in the background-- the mountain and the dark blue sky were nearly
black!)
Lesson learned: I shouldn't assume that my system is always running perfectly
:-O
So sorry to give FractRacer and Pekka Aho a false impression of their images.
Thanks, everyone, for helping me out with this. I'll be MUCH more careful in the
future ;-)
No worries at all! =)
On Thu, 10 Apr 2014 23:53:16 EDT, "Kenneth" <kdw### [at] gmailcom>
wrote:
Have a look at this web page or search for "grey scale step wedge"
http://www.pbase.com/jackcnd/1080p_tests
in particular look at the greyscale step images. On a properly
calibratedhigh quality monitor you should be able to see and
differenciate all the steps.
I hope this helps
John
I'm happy to report that my monitor now passes *all* the tests there. Thanks for
the link.
The underlying problem was... human error, naturally. Sometime in the past--
maybe more than a year ago!-- I had actually reduced the brightness AND
contrast-- for the sole purpose of trying to avoid 'burning in' my monitor's
phosphors (IIRC.) That was my thought, anyway-- based on *old* and probably
out-of-date info from decades ago. Then I forgot that I had done it!
Am 10.04.2014 20:58, schrieb Kenneth:
> I'm beginning to think that there is something wrong with my computer/monitor
> set-up (Windows XP on a CRT monitor): The .png images that various POV-Ray users
> are uploading to the newsgroups look 'dark' on my system, and I have no idea
> what the cause is. (Well, I'm guessing that the images *should* look brighter,
> although I don't know for sure.)
There are various possible reasons:
(A) Personal preference.
Some people simply love playing with darkness and light, and the images
may be intended to be that dark, while you may prefer images to have
less contrast.
(B) Your "display gamma".
In a nutshell, no two computer/display combinations natively show the
same image in the same way, due to hardware tolerances, manufacturer
preferences, and brightness/contrast control settings.
The only way to make sure your computer display shows .png images
exactly the way they are supposed to be (according to the file format
specification and the data in the file) is to /calibrate/ your display,
which in essence means that you teach your computer to auto-correct for
your display's peculiarities.
While proper calibration would require a colorimeter (and would also
account for hue and saturation issues), if proper brightness is all you
want then simple /gamma correction/ will suffice; most display hardware
I know of comes with tools to perform gamma correction, and if I'm not
mistaken Windows 7 and later (maybe also Vista) comes with such tools
onboard.
(C) The author's display gamma.
Just as you can't be sure /you're/ seeing what's officially encoded in
the .png file unless /your/ display is calibrated, you can't be sure
that what's officially encoded in the .png is what the /author/ was
seeing unless /their/ display is calibrated as well. However, in most
cases this is obviously outside your area of influence.
(D) Your display's "black level".
Your display may be unable to show the same level of black that the
original author saw, which might "drown" some almost-but-not-quite black
details. However, while this is a common issue with LCDs, it is rarely
seen in CRT displays.
In real life it's typically a combination of (A)-(C), as well as (D) for
people who have an LCD.
> This dark appearance shows up in a range of applications, not just a specific
> one-- the latest Firefox (v28.0); my older Photoshop; and in Windows' Picture
> And Fax Viewer. My own .png images made in POV-Ray look fine on my system, as do
> ...jpegs.
> To better show this, I've made .jpeg screenshots of two recent uploaded images,
> by FractRacer and Pekka Aho. They are accurate reproductions of how the .png
> originals appear on my end. Can someone compare my .jpegs to the original
> uploads, to see if they visually match?
How on earth do you know that those JPEGs are "accurate reproductions of
how the .png originals appear on [your] end"? After all, you'd need a
calibrated display in the first place to be sure that what's encoded in
the JPEGs accurately reproduces what you saw.
>> computer/monitor
>> POV-Ray users
>> no idea
>> brighter,
> less contrast.
> onboard.
(E) Your display's "white" level.
Many CTRs tend to get blurry when the white level is set moderately
high. This forces the user to greatly reduce the overall brightness,
often to the minimum possible level, to prevent the bluring of text and
the eye strain it will cause.
