Poser hair guides on the left, "proof of concept" test render of 500 red,
randomly placed sphere_sweep "hairs" on the right (the Poser hair guide splines
used for interpolation are thicker and darker).
The process in a nutshell is:
For each hair -
1) From bounding box center of the follicleSurface mesh outward in some
random direction.
2) If the ray hits the mesh then that trace point becomes the root of a hair.
3) interpolate a new, distance-weighted spline (hair) between the two guide
hair splines having roots closest to the traced root.
With these large "wires" going into the scalp it seems a bit android-like; gives
me so many side-tracking new ideas...
www.McGregorFineArt.com
Download 'poserhairguidestointerpolatedspheresweeps.jpg' (192 KB)
Preview of image 'poserhairguidestointerpolatedspheresweeps.jpg'
Subject: Re: Poser dynamic hair guides spline interpolation
Date: 18 Feb 2014 03:38:49
Message: <53031c19$1@news.povray.org>
> For each hair -
> random direction.
Interesting! So, to see if I understand correctly, what you are saying
is that you /only/ use the guide hairs from Poser and
generate/extrapolate the hairdo from there? No need to use the fully
populated Poser hair? That is a great approach and probably faster than
generating sphere_sweeps from /all/ the individual Poser hairs, which
was the thought I was following until now. Well done!
That's correct Thomas, it allows creation of any number of hairs. In this
example I randomly interpolated between 2, 3 or 4 nearest guides to get
different "layers" of hair. These even more android-like R, G and B tubes are:
Red - interpolate nearest 2 guides
Green - interpolate nearest 3 guides
Blue - interpolate nearest 4 guides
Just having fun experimenting with this right now; I see the potential for many
other applications of this basic technique.
Download 'poserhairtest_3shell.png' (567 KB)
Preview of image 'poserhairtest_3shell.png'
Date: 18 Feb 2014 10:12:22
Message: <53037856$1@news.povray.org>
Fascinating! This is going much better than I ever dreamed. It is going
to make use of Poser dynamic hair much easier and much better.
>> for many
Seconded! More power to your elbow.
Regards
