POV-Ray : Newsgroups : povray.binaries.images : Realistic rusty bearing Server Time
21 Aug 2025 16:52:12 EDT (-0400)
  Realistic rusty bearing (Message 1 to 10 of 14)
Subject: Realistic rusty bearing
Date: 8 Feb 2014 03:00:00
Message: <web.52f5e34c7c18f5697a3e03fe0@news.povray.org>
Hi!
Now Blender2Povray exporter in working order.
On our site users started showing interest to my work and to try to create
scenes.
The rust became the first problem.
I looked at structure of rust in textures.inc and used it for a bearing holder.
Look very bad.
Help us to create, please, a realistic rust on the bearing
Files of a scene are here::
http://news.povray.org/povray.binaries.scene-files/message/%3Cweb.52f5e09fa98583267a3e03fe0%40news.povray.org%3E/#%3Cwe
Subject: Re: Realistic rusty bearing
Date: 8 Feb 2014 04:15:55
Message: <52f5f5cb@news.povray.org>
How about this? Different variations possible (see below). Textures
courtesy of Xplo Eristotle.
//start code
// Metal textures by Xplo Eristotle
// RUST
#declare XE_rust =
	pigment
		granite
		color_map
			[ 0.0 rgb <0.809995, 0.299123, 0.113405>*.8 ]
			[ 0.4 rgb <0.209995, 0.096941, 0.031510>*1.2 ]
			[ 0.6 rgb <0.209995, 0.096941, 0.031510>*1.2 ]
			[ 1.0 rgb <0.569986, 0.052720, 0.005707>*.9 ]
		scale .5
		turbulence 1
	normal { wrinkles }
// IRON
#declare XE_iron =
	pigment { color rgb <0.25, 0.25, 0.25> }
	normal { granite .3  scale .2 }
	finish { roughness .01 specular .5 reflection .05 diffuse .8 }
// IRON WITH RUST FLAKES (TdG)
#declare XE_iron_2 =
	  marble
	  pigment_map {
	    [0.00 color rgb <0.25, 0.25, 0.25>]
	    [0.20 color rgb <0.30, 0.30, 0.30>]
	    [0.45 color rgb <0.809995, 0.299123, 0.113405>*0.8]
	    [0.50 color rgb <0.25, 0.25, 0.25>]
	    [0.65 color rgb <0.23, 0.23, 0.23>]
	    [0.90 color rgb <0.24, 0.24, 0.24>]
	    [1.00 color rgb <0.25, 0.25, 0.25>]
	  scale 0.2
	  warp {turbulence 0.5}
	normal {granite 0.3  scale 0.2}
	finish {
	  roughness 0.01
	  specular 0.5
	  reflection 0.05
	  diffuse 0.8
// RUSTY IRON
#declare XE_rusty_iron =
	bozo
	texture_map
		[ 0.0 XE_rust ]
		[ 1.0 XE_iron ]
	turbulence 1
	omega .3
	lambda 4
	warp { turbulence 1 }
// STEEL
#declare XE_steel =
	pigment { color rgb <0.5, 0.5, 0.5> }
	normal { wrinkles .02 scale .1 }
	finish
		roughness .001
		specular 1
		diffuse .2
		reflection .5
// RUSTY STEEL
#declare XE_rusty_steel =
	bozo
	texture_map
		[ 0.0 XE_rust ]
		[ 0.2 XE_rust ]
		[ 0.5 XE_iron ]
		[ 0.6 XE_steel ]
		[ 1.0 XE_steel ]
	turbulence 1
	omega .6
	lambda 4
//end code
Download 'rusty_bearing.png' (237 KB)
Preview of image 'rusty_bearing.png'
Date: 8 Feb 2014 06:05:01
Message: <web.52f60e4a190970a57a3e03fe0@news.povray.org>
Thomas, thanks!
I will try to use your example for settings in a blender. :)
Date: 8 Feb 2014 07:21:26
Message: <52f62146$1@news.povray.org>
> Thomas, thanks!
You are welcome indeed. As far as my texture collection goes, Xplo's
rust textures are the best I have seen here.
Date: 8 Feb 2014 08:14:46
Message: <52f62dc6@news.povray.org>
Some thoughts about different settings.
ini file: Display_Gamma=1
Using version 3.7, you may want to take advantage of the sRGB colour
space. Personally, I have my Display_Gamma set permanently to: sRGB.
Pigments:
You may want to play with srgb too inside the pigments. Change all 'rgb'
to 'srgb' and see the difference. If you want exactly the same output
you may need to tweak the rgb values, making them lighter.
Textures:
After some more testing and for a better result, I advice to change the
XE_rusty_steel texture to:
	bozo
	texture_map
		[ 0.0 XE_rust ]
		[ 0.2 XE_rust ]
		[ 0.5 XE_steel ]
		[ 1.0 XE_steel ]
	turbulence 1
	omega .6
	lambda 4
Using sRGB colours without changing their values, you get the following
image. Left = XE_rusty_iron; Right = XE_rusty_steel.
Download 'rusty_bearing.png' (553 KB)
Date: 8 Feb 2014 08:40:00
Message: <web.52f63388190970a57a3e03fe0@news.povray.org>
> //start code
> texture {
>  pigment {
>    marble
>    pigment_map {
>    scale 0.2
>  finish {
>    roughness 0.01
>    specular 0.5
>    reflection 0.05
>    diffuse 0.8
> texture {
>  bozo
>  texture_map
>   [ 0.0 XE_rust ]
>   [ 0.2 XE_rust ]
>   [ 0.5 XE_iron ]
>   [ 0.6 XE_steel ]
>   [ 1.0 XE_steel ]
>  turbulence 1
>  omega .6
>  lambda 4
> //end code
> Thomas
XE_iron_2 declare, but not used.
Date: 8 Feb 2014 10:32:31
Message: <52f64e0f$1@news.povray.org>
>> //start code
>> texture {
>>   pigment {
>>     marble
>>     pigment_map {
>>     scale 0.2
>>   finish {
>>     roughness 0.01
>>     specular 0.5
>>     reflection 0.05
>>     diffuse 0.8
>> texture {
>>   bozo
>>   texture_map
>>    [ 0.0 XE_rust ]
>>    [ 0.2 XE_rust ]
>>    [ 0.5 XE_iron ]
>>    [ 0.6 XE_steel ]
>>    [ 1.0 XE_steel ]
>>   turbulence 1
>>   omega .6
>>   lambda 4
>> //end code
>> Thomas
Yes, you can choose your own combinations ;-)
Date: 8 Feb 2014 12:05:01
Message: <web.52f6632f190970a57a3e03fe0@news.povray.org>
> Thomas
I already understood it.
But, it would be desirable to see still options of other users.
Me completely rusty surface interests also.
And, for some reason it seems to me that normal works at the bearing badly.
Date: 9 Feb 2014 03:56:24
Message: <52f742b8@news.povray.org>
In p.b.scene-files I have given a collection of rusty metals by several
authors.
In the image: left = Ke_old_pitted_iron from the collection. normals are
looking 'normal' to my eyes ;-)
Download 'rusty_bearing.png' (702 KB)
Date: 9 Feb 2014 07:58:17
Message: <52f77b69@news.povray.org>
And as I am never entirely satisfied, here is a version with a HDRI
environment.
Left = XE_rusty_steel; Right = Ke_old_pitted_iron
Download 'rusty_bearing.png' (953 KB)
