Hi(gh)!
On 03.02.2014 13:41, Thomas de Groot wrote:
> parsing.
In this context, this is almost a pun!
Thomas de Groot <tho### [at] degroot org> wrote:
> On 3-2-2014 16:04, Thomas de Groot wrote:
> > Not really an issue, but an even better version would be obtained with
> > an uv_mapped image_map on the height_field.
> ...however, as was concluded in the thread:
http://news.povray.org/povray.newusers/thread/%3Cweb.4f943e8d8677299d5d50475e0%40news.povray.org%3E/?ttop=390889&toff
=50
> this is not possible to do. A pity.
> Thomas
In Blender3D Height Field can try to imitate creating new mesh on UV of initial
object
For this purpose it is necessary to think and write a python-code for the
exporter.
Such task wasn't set for me :)
Render mesh would be much faster, than a render of Height Field
Of course. For such objects as carpets, I normally use a mesh object and
not a height_field. It just happened that I tested with a height_field
here. ;-)
HF_square() could be an alternative but it has some troubles of its own,
when transforming it (i.e. it has no well-defined origin).
> Hi(gh)!
>> parsing.
<grin>
> =50
>> Thomas
> object
> exporter.
I'm not sure that a mesh would render faster than a height field.
After all, a hight field is realy a specialised form of mesh...
Hi(gh)!
On 08.02.2014 09:24, Thomas de Groot wrote:
It's Persian, meaning "I will see you in Khyberspace"!
See you in Khyberspace!
Yadgar
I should have known :-)
dude.
this rocks.
keep up the good work.
peter
"LanuHum" <Lan### [at] yandex ru> wrote:
> Persian carpet. It is created in Blender3D. Povray counted in 45 seconds!
> I am happy!
> Thanks to all who helps me to study Povray
