POV-Ray : Newsgroups : povray.binaries.images : SSLT test Server Time
20 Apr 2026 19:00:07 EDT (-0400)
  SSLT test (Message 45 to 54 of 54)
Subject: Re: SSLT test
Date: 31 Jan 2014 01:23:42
Message: <52eb416e$1@news.povray.org>
On 28/01/2014 1:03 PM, Doctor John wrote:
> "I couldn't have put it better myself"
> - William Shakespeare
Thou spaketh crap.
  - Kit Marlowe
Regards
Date: 31 Jan 2014 03:15:50
Message: <52eb5bb6$1@news.povray.org>
Maybe the texture is a bit distracting? Looks good however; have you
tried to play with less translucency too?
Like with my tuit, I am a bit worried about sslt and text. I would like
some learned comments on that particularly.
Date: 31 Jan 2014 06:00:45
Message: <52eb825d$1@news.povray.org>
On 31/01/14 08:15, Thomas de Groot wrote:
> <snip> I would like
Well, you aren't going to get anything learned from Stephen or me :-)
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 31 Jan 2014 07:14:01
Message: <52eb9389$1@news.povray.org>
>> <snip> I would like
I already lost that hope indeed ;-) but there are those who keep their
learned knowledge jealously to themselves...
Date: 31 Jan 2014 07:55:00
Message: <web.52eb9c86eff39d867f6b03a40@news.povray.org>
I agree but I just modified a texture that, that I liked, which I had made for
the RC4 SSLT. The original translucency was too high and the value here is a
tenth of what it was.
The colours are too dark for expensive jade and need to be lightened.
Indeed, I thought that I would try to sink the text into the body for a
comparison.
> I would like
Your text seems to be almost placed on the cylinder and not a part of it. I
assume that you use a merge. Since my model has lots of differences, (I
differenced the basic model from a blank, to create a mould. Then differenced
that from another one to get rid of the internal structure.
Date: 31 Jan 2014 08:05:55
Message: <52eb9fb3$1@news.povray.org>
> comparison.
>> I would like
I also sank the text into the body, both positioned at the origin for
the z-axis, and using a merge to get rid of the internal geometry. As
the geometry of the letters is much smaller than the tuit's object, I
concluded that they would need a smaller mm_per_unit value but I am not
sure if I am right with that assumption.
Date: 31 Jan 2014 14:24:41
Message: <52ebf879$1@news.povray.org>
>> comparison.
>>> I would like
>> it. I
>> differenced
> Thomas
It's not because some details are small that you need to reduce mm_per_unit.
That value need to reflect the actual scalling of your scene.
The default of 10 mean that each pov unit is actualy 1cm whide.
Setting it to 1 mean that one unit is 1mm whide and a value of 25.4 is
good for a scene constructed in inches.
Date: 31 Jan 2014 14:39:45
Message: <52ebfc01$1@news.povray.org>
Am 31.01.2014 14:05, schrieb Thomas de Groot:
That assumption is absolutely...
... wrong :-P
Having two different mm_per_unit values wouldn't make any sense.
Date: 1 Feb 2014 03:30:21
Message: <52ecb09d$1@news.povray.org>
> ... wrong :-P
My explanation was ambiguous at best ;-) As the total object is a merge
of tuit + text, there is also only /one/ mm_per_unit value.
What I am struggling with is the /meaning/ of mm_per_unit. I am
understanding the sense of it but am unsure how to interpret it in a
scene. I need to ponder Alain's answer above a little longer, if my
brain accepts to fire up...
...so it doesn't matter what the /size/ of the object is as long as you
fix for yourself what a pov unit corresponds to in the scene. OK, fair
enough. In most of my scenes I have a clear idea about this. However, in
a test scene like this I just meddle around without clear notion about
true sizes. With sslt I should thus start with determining that beforehand.
Thanks! Much cleared now. I supposedly did not read the docs well enough
in the first place it seems.
Date: 1 Feb 2014 04:22:45
Message: <52ecbce5@news.povray.org>
Revisited the scene; set mm_to_unit to 10; scaled the tuit to be 3cm
across. Rendered with and without sslt.
Download 'round tuit.png' (430 KB)
Preview of image 'round tuit.png'
