POV-Ray : Newsgroups : povray.binaries.images : Another casualty of the change to crackle Server Time
25 Mar 2026 00:05:58 EDT (-0400)
  Another casualty of the change to crackle (Message 1 to 10 of 15)
Subject: Another casualty of the change to crackle
Date: 26 Dec 2013 14:55:01
Message: <web.52bc89306c004246306548240@news.povray.org>
The optimizations to the crackle pattern in POV-Ray 3.7 had the side effect of
changing the pattern.  (See "Crackle change?" in p.beta-test.)
I just rendered the Lightsys IV examples using POV-Ray 3.7, and this is how
demo_outdoor.pov rendered:
Download 'demo_outdoor.v3.7.jpg' (29 KB)
Preview of image 'demo_outdoor.v3.7.jpg'
Subject: Re: Another casualty of the change to crackle
Date: 27 Dec 2013 03:14:01
Message: <52bd36c9@news.povray.org>
Hmm... /this/ is what I get however.
Only added the version and uncommented the assumed_gamma. Did you make
other adaptations?
Download 'demo_outdoor.png' (261 KB)
Preview of image 'demo_outdoor.png'
Date: 27 Dec 2013 03:21:28
Message: <52bd3888@news.povray.org>
> other adaptations?
PS: additionally changing rgb to srgb results in this.
Download 'demo_outdoor.png' (233 KB)
Date: 27 Dec 2013 19:25:05
Message: <web.52be193813cbdeae306548240@news.povray.org>
> other adaptations?
I made no changes to the scene description file.  I put Version=3.5 on the
command line.  In my version of demo_outdoor.pov, dated 2009 August 11 19:21:16
(11:21:16 pm UT), the assumed_gamma is not commented out.
What you posted looks similar to my POV-Ray 3.6.1 run, but the trees are in
different locations, the grassy terrain is different, there is no cliff to the
right of center, and there is a path going from the center to the lower right.
Download 'demo_outdoor.jpg' (56 KB)
Preview of image 'demo_outdoor.jpg'
Date: 27 Dec 2013 19:40:01
Message: <web.52be1d0713cbdeae306548240@news.povray.org>
The Lightsys calculations used to derive those colors all work in linear space,
so they need no srgb conversion.  (It also looks like you missed the pigment{rgb
Cl_trees} statement.)
Date: 28 Dec 2013 03:24:15
Message: <52be8aaf$1@news.povray.org>
>> other adaptations?
why version 3.5? It seems to me that if you want the scene rendered in
POV-Ray 3.7 that should be the version number... or do I miss something
here?
That path is a cliff similar to the one in my image but at another
position. I cannot explain the differences.
Date: 28 Dec 2013 03:54:49
Message: <52be91d9@news.povray.org>
>>> other adaptations?
>> the
>> 19:21:16
I have to agree with Cousin Ricky. I attach two images. The first is
rendered using v3.7 (setting #version 3.7;) and the second using v3.6.1
(setting #version 3.6;)
I also attach the original scene file (without #version)
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Download 'demo_outdoor.png' (54 KB) Download 'demo_outdoor_36a.png' (226 KB) Download 'us-ascii' (3 KB)
Preview of image 'demo_outdoor_36a.png'
Date: 28 Dec 2013 10:55:01
Message: <web.52bef40e13cbdeae90cbcd420@news.povray.org>
> >>> other adaptations?
> >> the
> >> 19:21:16
I try to render the scene with a modification of camera position ( location
<0,24,-100>*<1,1.25,1> ), here are the two versions of the scene:
First pov3.6
Download 'outdoor_demov36.png' (382 KB)
Preview of image 'outdoor_demov36.png'
Date: 28 Dec 2013 11:00:00
Message: <web.52bef48d13cbdeae90cbcd420@news.povray.org>
And second Pov3.7:
A lot of differences!
Download 'outdoor_demov37.png' (424 KB)
Preview of image 'outdoor_demov37.png'
Date: 28 Dec 2013 11:00:37
Message: <52bef5a5@news.povray.org>
>> the
>> 19:21:16
> here?
Because it was written /for/ version 3.5--or at least seemed so until I
discovered that the modification date was in 2009.  The intention was to
invoke any available backward compatibility concessions so that the
scene would render as intended at the time it was written.  But 2009 was
during the 3.6 time frame, which shouldn't make all that much of a
difference from 3.5.
The point is that backward compatibility is not available for the
crackle pattern, which was the basis for defining the land form.
Anyhow, here is a comprehensive set of POV-Ray 3.7 runs:
demo_outdoor-v3.7-noset.jpg  - no Version on the command line
demo_outdoor-v3.7-set3.5.jpg - Version=3.5 on the command line
demo_outdoor-v3.7-set3.6.jpg - Version=3.6 on the command line
demo_outdoor-v3.7-set3.7.jpg - Version=3.7 on the command line
The only differences I can see are to the brightness of the scene.
Download 'demo_outdoor-v3.7-noset.jpg' (25 KB) Download 'demo_outdoor-v3.7-set3.5.jpg' (33 KB) Download 'demo_outdoor-v3.7-set3.6.jpg' (32 KB) Download 'demo_outdoor-v3.7-set3.7.jpg' (24 KB)
Preview of image 'demo_outdoor-v3.7-noset.jpg'
Preview of image 'demo_outdoor-v3.7-set3.5.jpg'
Preview of image 'demo_outdoor-v3.7-set3.6.jpg'
Preview of image 'demo_outdoor-v3.7-set3.7.jpg'
