POV-Ray : Newsgroups : povray.binaries.images : Another casualty of the change to crackle Server Time
20 Apr 2026 19:00:06 EDT (-0400)
  Another casualty of the change to crackle (Message 11 to 15 of 15)
Subject: Re: Another casualty of the change to crackle
Date: 28 Dec 2013 11:45:02
Message: <web.52befed313cbdeae306548240@news.povray.org>
"Fractracer" <lg.### [at] gmailcom> wrote:
> And second Pov3.7:
> A lot of differences!
Ah, that's because CIE_Skylight.inc uses ambient 1 on the sky dome, which
doesn't work in POV-Ray 3.7 when radiosity is used.  (This is an example of why
I used Version=3.5 on the command line instead of Version=3.7.)
For public include files and demo scene files, I suggest changing all
occurrences of ambient 1 to:
  #if (version < 3.7)
    ambient 1
  #else
    ambient 0 emission 1
Of course, for your own scene files, where you know you'll be using 3.7, you can
just use emission 1.
Date: 28 Dec 2013 11:50:01
Message: <web.52bf002613cbdeae306548240@news.povray.org>
> Hmm... /this/ is what I get however.
> Only added the version and uncommented the assumed_gamma. Did you make
> other adaptations?
Hey, when I change the camera location to <0,25,-100> and set Version=3.6 (to
keep the skylight), my result is identical to yours (save for the aspect ratio)!
Date: 28 Dec 2013 12:45:01
Message: <web.52bf0da913cbdeaeafc53f4d0@news.povray.org>
> > What you posted looks similar to my POV-Ray 3.6.1 run, but the trees are in
> > different locations, the grassy terrain is different, there is no cliff to the
> > right of center, and there is a path going from the center to the lower right.
> That path is a cliff similar to the one in my image but at another
> position. I cannot explain the differences.
> Thomas
Hmm, at the moment I have no resources left to play with things. In the first
thread to this topic by Cousin Ricky from October 2011
(http://news.povray.org/povray.beta-test/thread/%3Cweb.4e8cedc01e77e1ef78641e0c0@news.povray.org%3E/)
Christoph replied
>In a sense yes - the crackle pattern has changed. The general properties
>of the pattern haven't though, so the description in the docs is still
>valid.
>There are a few other random-determined patterns that have changed as
>well in a similar manner. I can't tell off the top of my head though
>which those are.
I have no idea what he ment with "in a sense" really. The crackle pattern is
based upon the calculation of Voronoi diagrams, a (very) well defined issue
within computational geometry. May be the algorithm to calculate Voronoi
diagrams was exchanged with a better one. But as Christoph continues "other
random-determined patterns [...] have changed as well in a similar manner" (the
random part with crackle is the positioning of the points in space to calculate
the Voronoi diagram). That gave me the suspicion that not the pattern are
changed but the noise generator again (last official change after 3.1). That
would explain a lot of the issues you all report here. But it is only a guess
finally.
Best regards,
Michael
Date: 28 Dec 2013 20:38:32
Message: <52bf7d18@news.povray.org>
Am 28.12.2013 18:43, schrieb MichaelJF:
>> valid.
>> which those are.
> finally.
I can confirm that it's not just a guess - it is indeed exactly what is
happening.
(I must confess though that I'm not into details /why/ the random
generator was changed. Supposedly it was necessary to make the whole
crackle mechanism work with multithreading at reasonable speed.)
Date: 29 Dec 2013 03:08:07
Message: <52bfd867$1@news.povray.org>
>> other adaptations?
What I had not consciously realized before was that the camera in your
image happened to be /below/ the landscape. Michael's and Clipka's
explanation about the random generator make a lot of sense now imho.
