POV-Ray : Newsgroups : povray.binaries.images : Ariadne's Garden Server Time
28 Sep 2024 07:17:30 EDT (-0400)
  Ariadne's Garden (Message 1 to 9 of 9)
Subject: Ariadne's Garden
Date: 20 Nov 2013 17:55:00
Message: <web.528d3d00ac34ed36a8a8fb540@news.povray.org>
Traditionally I post 1920x1080 wallpaper versions of my TC-RTC entries here. In
this case the total rendering time was about 3 weeks but I had to suspend the
rendering times and again so it took some months for the final wallpaper
version. I know that this image is not really liked by all here than by me but
here it is: Ariadne's Garden.
Best regards,
Michael
Download 'mjf 2013-11-15 ariadnesgarden.jpg' (401 KB)
Preview of image 'mjf 2013-11-15 ariadnesgarden.jpg'
Subject: Re: Ariadne's Garden
Date: 20 Nov 2013 18:15:13
Message: <528d4281$1@news.povray.org>
The stone of the statuary seems a bit too glossy/unstone-like, and I
initially mistook Theseus' roll of twine for a wine-bottle.  Trees on
the left seem a bit evenly-lit, as do the buildings in the background.
Maybe play around with more local lights, if that's something of an
option?  Maybe add small ground-spotlights to the foreground garden, too?
Tim Cook
Date: 20 Nov 2013 18:28:16
Message: <528d4590$1@news.povray.org>
Am 20.11.2013 23:51, schrieb MichaelJF:
The biggest problem I have with the image is that the statues appear
distorted to me, as if the scene was rendered with a wrong aspect ratio.
Date: 21 Nov 2013 05:20:00
Message: <web.528ddd5f4a6f448a3f58a82f0@news.povray.org>
Thank you both for your comments. I'm not quiet sure if I will revisit the scene
very soon, mainly due to the long rendering time. But your comments are valuable
hints for future scenes.
Indeed the lighting is a main problem here. Since it should be at night I cannot
have to much light in the scene. May be that is why Tim mistook the bronze for
stone. If I revisit the scene some day I will place some additional lanterns
behind the camera at least. In the image above there are 14 dim lanterns placed
around the green. The only other light sources are the emissive media within the
building.
As for the wine bottle, I refer to my original comment at the contest:
http://www.tc-rtc.co.uk/imagenewdisplay/stills/index446.html
And as ever Christoph is right completely. The camera was not adjusted
correctly. I ever thought there is something odd but overlooked the obvious.
Best regards,
Michael
Date: 21 Nov 2013 07:21:52
Message: <528dfae0$1@news.povray.org>
PC's get faster all the time ;-)
> building.
I think there is a problem with the /dim/ lanterns then. The scene seems
to be lighted by quite strong projector lights, especially from the
right hand side, casting marked shadows across the garden. If only the
lanterns are the exterior lighting, then the scene should be much darker
imo. Maybe fade_distance and/or fade_power should be adjusted besides
the strength of the lights?
Ah! I am relieved. I thought so too.
Date: 21 Nov 2013 11:50:00
Message: <web.528e39294a6f448a3f58a82f0@news.povray.org>
Thanks Thomas, that gave me the right idea. In fact I adjusted fade_distance and
fade_power, may be not enough. The main problem are the shadows. They stem from
cylinders around the light source. In reality the shadows are nearly invisible
since the bulbs produce no point light. I think adding no_shadow to this
cylinders will reduce the problem a lot - even though they are not visible in
the image. But a revision of this image has no high priority for me.
Best regards,
Michael
Date: 21 Nov 2013 13:55:01
Message: <web.528e56774a6f448a306548240@news.povray.org>
If somebody doesn't like it, that's their problem.
If the statues are supposed to be bronze, they should be a lot darker, although
darker statues would be a lot harder to fit into the composition.
Date: 21 Nov 2013 19:00:00
Message: <web.528e9dd94a6f448a3f58a82f0@news.povray.org>
Thank you for this comment. It is absolutely true. Due to my results within
TC-RTC I hesitated a while to publish this scene here. There is one member who
gives very low votes to images he dislikes and sometimes I'm a little bit
thin-skinned - and sometimes I get a temper. But I'm only a common member of the
(biological) family of hominidae (I learned recently that humans are now
considered part of this family and not considered a family of their own due to
genetic analysis).
For your comment about bronze: Yes it can be darker, but must not. I looked at
various photographs and saw very different brightnesses. A part of this
differences may be explained by different ligthings but I assume another part is
due to the different ratio of copper and tin.
Best regards,
Michael
Date: 22 Nov 2013 03:21:51
Message: <528f141f@news.povray.org>
> genetic analysis).
The infamous TC-RTC voter has rather particular ideas about how the
voting rules should be interpreted or did not understand them well. Just
ignore ;-)
And maybe also differences in patina. Highly polished bronze can look
like gold for instance.
