POV-Ray : Newsgroups : povray.binaries.images : A method creat uniform thick shell Server Time
18 Mar 2026 00:14:35 EDT (-0400)
  A method creat uniform thick shell (Message 36 to 45 of 45)
Subject: Re: A method creat uniform thick shell
Date: 29 Jul 2018 12:26:39
Message: <5b5deabf$1@news.povray.org>
On 7/28/2018 3:18 PM, Tor Olav Kristensen wrote:
> "And" <49341109@ntnu.edu.tw> wrote:
>> #local h=0.00001;
>> #local normalized_function =
>> function(var1,var2,var3)
>> input_function(var1,var2,var3)
>> /sqrt(
>> pow((input_function(var1+h,var2,var3)-input_function(var1,var2,var3))/h,2)
>> +pow((input_function(var1,var2+h,var3)-input_function(var1,var2,var3))/h,2)
>> +pow((input_function(var1,var2,var3+h)-input_function(var1,var2,var3))/h,2)
> And, there is a macro in math.inc that can create the gradient function for your
> denominator: fn_Gradient()
> Here's how you can use it:
> #include "math.inc"
> SetGradientAccuracy(h)
> #local GradientFn = fn_Gradient(input_function)
>    function { input_function(x, y, z)/GradientFn(x, y, z) }
> I suspect that this will be a little faster, since fn_Gradient() uses f_r()
> instead of sqrt() and pow() and since the division by h (or 2*h in fn_Gradient)
> is moved outside.
> Here's the relevant documentation pages:
> http://www.povray.org/documentation/view/3.6.1/460/
> http://www.povray.org/documentation/3.7.0/r3_4.html#r3_4_9_1_12_3
> Tor Olav
> http://subcube.com
I am using these functions:
#declare f_test = function(var1,var2,var3,varA,varB,varC)
{pow(var1,2)+pow(var2,2)+pow(var3,2)-1-0.5*f_noise3d(var1*varA,var2*varB,var3*varC)}
#declare f_normalized = function(var1,var2,var3,varA,varB,varC)
{f_test(var1,var2,var3,varA,varB,varC)/sqrt(4*pow(var1,2)/pow(varA,4)+4*pow(var2,2)/pow(varB,4)+4*pow(var3,2)/pow(varC,4))}
How would I rewrite them using fn_Gradient()?
Thanks.
Date: 29 Jul 2018 12:42:25
Message: <5b5dee71$1@news.povray.org>
Le 18-07-29 à 09:36, Mike Horvath a écrit :
> On 7/28/2018 11:43 AM, Alain wrote:
>> If you reduce the ior, then, the reflection will also go down.
>> The minimum reflection is to high at 0.2.
>> Try :
>> reflection{0, 1 fresnel}
>> or simply
>> reflection{1 fresnel}
>> Try this interior :
>> interior{
>>   ior 1.5
>>   dispersion 1.05
>>   fade_colour Col_Ruby fade_distance 0.1 fade_power 1001
>> Col_Ruby is the same as Col_Glass_ruby but without the filter component.
>> With this pigment :
>> pigment{rgbt 1}
> The dispersion really causes the render times to increase. I don't know
> if I have the patience.
> Mike
It's obvious that dispersion cause increased render time, for each
incident ray, it generate dispersion_samples outgoing rays with a
default of 7.
Date: 29 Jul 2018 16:00:00
Message: <web.5b5e1c39dce0719add67a8b80@news.povray.org>
> > #include "math.inc"
> I don't understand the syntax.
> I did not know one could pass one function to another in this manner. I
> thought it was necessary to pass x, y, z instead. I.e.
> #local GradientFn = fn_Gradient(x,y,z)
fn_Gradient() is not a function. It is a macro within math.inc. When you pass a
function to this macro it will create and return a new function that estimates
the magnitude of the gradient of the function that you passed to it.
The function that you pass to this macro must take 3 arguments; usually x, y and
z (but their names doesn't really matter). And the function that it returns
takes 3 arguments.
Tor Olav
http://subcube.com
Date: 29 Jul 2018 17:25:00
Message: <5b5e30ac$1@news.povray.org>
> takes 3 arguments.
> Tor Olav
> http://subcube.com
I tried this code:
#declare f_test = function(var1,var2,var3)
{pow(var1,2)+pow(var2,2)+pow(var3,2)-1-0.5*f_noise3d(var1*3,var2*3,var3*3)}
{f_test(var1,var2,var3)/sqrt(4*pow(var1,2)/pow(varA,4)+4*pow(var2,2)/pow(varB,4)+4*pow(var3,2)/pow(varC,4))}
and this code:
SetGradientAccuracy(0.0001)
#declare f_test= function {x*x+y*y+z*z-1-0.5*f_noise3d(x*3,y*3,z*3)}
#declare f_input = function {f_test(x,y,z)}
#declare GradientFn = fn_Gradient(f_input)
#declare f_normalized = function {f_input(x,y,z)/GradientFn(x,y,z)}
And the latter was much slower. Is there a way to speed it up?
Mike
Date: 29 Jul 2018 22:30:01
Message: <web.5b5e768edce0719a79917fa00@news.povray.org>
> > takes 3 arguments.
> > Tor Olav
> > http://subcube.com
> I tried this code:
> and this code:
Those two code snippets does not calculate the same.
I do not know what is calculated in the denominator in
f_normalized() in the the first expression. (I even suspect that
it is not a useful calculation to do.)
But in the denominator in f_normalized() in the second expression,
the magnitude of the gradient for the f_test() function is
calculated - and this is a somewhat expensive calculation.
Note that there is no need to embed the f_test() function into
another function; f_input(), that just calls f_test(). The
fn_Gradient() macro can deal with f_test() directly, like this:
#include "math.inc"
#declare f_test =
    function { x*x+y*y+z*z-1-0.5*f_noise3d(x*3,y*3,z*3) }
#declare f_gradient = fn_Gradient(f_test)
    function { f_test(x,y,z)/f_gradient(x,y,z) }
Note that pow(x, 2) may be faster to evaluate than x*x.
Also note that if there is no argument list after function,
then function(x, y, z) { } is assumed.
Your code can be made easier for others to read if you
present it with some consistent indentation and extra white
space. (It will then also be easier for others to help you.)
E.g. like this:
#declare D = 3;
#declare E = 3;
#declare F = 3;
#undef f_test // To allow for a new version
#declare f_test =
    function {
        pow(x, 2) + pow(y, 2) + pow(z, 2) - 1
        -0.5*f_noise3d(D*x, E*y, F*z)
#undef f_normalized // To allow for a new version
    function(x, y, z, a_, b_, c_) {
        f_test(x, y, z)
        sqrt(
             4*pow(x, 2)/pow(a_, 4)
            +4*pow(y, 2)/pow(b_, 4)
            +4*pow(z, 2)/pow(c_, 4)
If your varA, varB and varC values are constants at render-time,
then they do not need to be in the argument list of
f_normalized(). This function can then be written like this:
// You'll have to fill in the numbers you want here:
#declare A = 1.0;
#declare B = 0.7;
#declare C = 1.0;
#declare AA = pow(A, 2);
#declare BB = pow(B, 2);
#declare CC = pow(C, 2);
#undef f_normalized
    function {
        f_test(x, y, z)
        sqrt(
             4*pow(x, 2)/pow(AA, 2)
            +4*pow(y, 2)/pow(BB, 2)
            +4*pow(z, 2)/pow(CC, 2)
- or like this:
#undef f_normalized
    function {
        f_test(x, y, z)
            2*
            sqrt(
                 pow(x/AA, 2)
                +pow(y/BB, 2)
                +pow(z/CC, 2)
The f_r() function can be found in functions.inc.
It can be used instead of the sqrt() and pow() expressions above.
Documentation for f_r():
http://www.povray.org/documentation/view/3.7.0/448/
#undef f_normalized
    function {
        f_test(x, y, z)/(2*f_r(x/AA, y/BB, z/CC))
Now onto the macros for estimating the magnitude of the gradient
for 3D-functions.
Here's some reading that is relevant:
Numerical differentiation of functions:
https://en.wikipedia.org/wiki/Numerical_differentiation
The gradient of functions:
https://math.oregonstate.edu/home/programs/undergrad/CalculusQuestStudyGuides/vcalc/grad/grad.html
As you can read in the Wikipedia article, there are several ways
to estimate the derivative of a function.
Below are some example macros for doing this with a passed
function.
The 3b macro below, which is very simular to the fn_Gradient()
macro in math.inc, is the one to use for most accurate results.
But it does return a function that takes longer time to
evaluate than the functions returned from the 1b or 1c macros.
#macro MakeGradientMagnitudeFunction_1a(Fn, h)
   function {
      sqrt(
          pow((Fn(x + h, y, z) - Fn(x, y, z))/h, 2)
         +pow((Fn(x, y + h, z) - Fn(x, y, z))/h, 2)
         +pow((Fn(x, y, z + h) - Fn(x, y, z))/h, 2)
#end // MakeGradientMagnitudeFunction_1a
#macro MakeGradientMagnitudeFunction_2a(Fn, h)
   function {
      sqrt(
          pow((Fn(x, y, z) - Fn(x - h, y, z))/h, 2)
         +pow((Fn(x, y, z) - Fn(x, y - h, z))/h, 2)
         +pow((Fn(x, y, z) - Fn(x, y, z - h))/h, 2)
#end // MakeGradientMagnitudeFunction_2a
#macro MakeGradientMagnitudeFunction_3a(Fn, h)
   function {
      sqrt(
          pow((Fn(x + h, y, z) - Fn(x - h, y, z))/(2*h), 2)
         +pow((Fn(x, y + h, z) - Fn(x, y - h, z))/(2*h), 2)
         +pow((Fn(x, y, z + h) - Fn(x, y, z - h))/(2*h), 2)
#end // MakeGradientMagnitudeFunction_3a
Now replace sqrt() and pow() with f_r().
As long as h (or h2) is positive we can divide by h (or h2)
outside the f_r() expression.
#macro MakeGradientMagnitudeFunction_1b(Fn, h)
   function {
      f_r(
         Fn(x + h, y, z) - Fn(x, y, z),
         Fn(x, y + h, z) - Fn(x, y, z),
      )/h
#end // MakeGradientMagnitudeFunction_1b
#macro MakeGradientMagnitudeFunction_2b(Fn, h)
   function {
      f_r(
         Fn(x, y, z) - Fn(x - h, y, z),
         Fn(x, y, z) - Fn(x, y - h, z),
      )/h
#end // MakeGradientMagnitudeFunction_2b
#macro MakeGradientMagnitudeFunction_3b(Fn, h)
   #local h2 = h*2;
   function {
      f_r(
         Fn(x + h, y, z) - Fn(x - h, y, z),
         Fn(x, y + h, z) - Fn(x, y - h, z),
      )/h2
#end // MakeGradientMagnitudeFunction_3b
In the 1b macro there are 6 calls to Fn(), where 3 of these
calls return the same value. If we rewrite this macro we can
reduce this to 4 calls to Fn().
But then we must add a call to a helper function, so we may
not gain much...
#macro MakeGradientMagnitudeFunction_1c(Fn, h)
    #local G_Fn_ =
        function(f_, fx_, fy_, fz_) {
            f_r(fx_ - f_, fy_ - f_, fz_ - f_)/h
    function {
        G_Fn_(
            Fn(x    , y    , z    ),
            Fn(x + h, y    , z    ),
            Fn(x    , y + h, z    ),
            Fn(x    , y    , z + h)
#end // MakeGradientMagnitudeFunction_1c
// Here's some tests of the macros above:
#include "functions.inc"
#declare A = 3;
#declare B = 3;
#declare C = 3;
#undef f_test
#declare f_test =
    function {
        - 0.5*f_noise3d(A*x, B*y, C*z)
#declare H = 1e-5;
#declare Fn1a = MakeGradientMagnitudeFunction_1a(f_test, H)
#declare Fn1b = MakeGradientMagnitudeFunction_1b(f_test, H)
#declare Fn1c = MakeGradientMagnitudeFunction_1c(f_test, H)
#declare Fn2a = MakeGradientMagnitudeFunction_2a(f_test, H)
#declare Fn2b = MakeGradientMagnitudeFunction_2b(f_test, H)
#declare Fn3a = MakeGradientMagnitudeFunction_3a(f_test, H)
#declare Fn3b = MakeGradientMagnitudeFunction_3b(f_test, H)
#declare P = <12, -4, 3>;
#declare G1a = Fn1a(P.x, P.y, P.z);
#declare G1b = Fn1b(P.x, P.y, P.z);
#declare G1c = Fn1c(P.x, P.y, P.z);
#declare G2a = Fn2a(P.x, P.y, P.z);
#declare G2b = Fn2b(P.x, P.y, P.z);
#declare G3a = Fn3a(P.x, P.y, P.z);
#declare G3b = Fn3b(P.x, P.y, P.z);
#debug "\n\n"
#debug concat("G1a: ", str(G1a, 0, -1), "\n")
#debug concat("G1b: ", str(G1b, 0, -1), "\n")
#debug concat("G1c: ", str(G1c, 0, -1), "\n")
#debug "\n"
#debug concat("G2a: ", str(G2a, 0, -1), "\n")
#debug concat("G2b: ", str(G2b, 0, -1), "\n")
#debug "\n"
#debug concat("G3a: ", str(G3a, 0, -1), "\n")
#debug concat("G3b: ", str(G3b, 0, -1), "\n")
#debug concat("(G1b+G2b)/2: ", str((G1b + G2b)/2, 0, -1), "\n")
#debug "\n\n"
And finally...
If you really need a, b and c to be in the argument list for
the passed function, then the macro can be written like this:
#macro MakeGradientMagnitudeFunction(Fn, h)
      f_r(
         Fn(x + h, y, z, a_, b_, c_) - Fn(x, y, z, a_, b_, c_),
         Fn(x, y + h, z, a_, b_, c_) - Fn(x, y, z, a_, b_, c_),
         Fn(x, y, z + h, a_, b_, c_) - Fn(x, y, z, a_, b_, c_)
      )/h
- But then it does not make sense, and it will not work, if the
f_test() function does not also have them in its argument list...
#undef f_test
#declare f_test =
    function(x, y, z, a_, b_, c_) { ... }
#declare f_gradient_magnitude =
    MakeGradientMagnitudeFunction(f_test, H)
#undef f_normalized
        f_test(x, y, z, a_, b_, c_)
        f_gradient_magnitude(x, y, z, a_, b_, c_)
Tor Olav
http://subcube.com
Date: 29 Jul 2018 22:50:31
Message: <5b5e7cf7$1@news.povray.org>
Thanks!!
Could you bundle this into an INC file please? Then I can link to the
newsgroup message URL from within my scene.
Mike
Date: 30 Jul 2018 10:15:00
Message: <web.5b5f1c89dce0719aa47873e10@news.povray.org>
I thought that the opposite was true, that x*x would be less 'computationally
expensive' than invoking the  pow  function. I honestly don't know for sure; but
I recall something being said about this in an older thread.
Date: 30 Jul 2018 17:16:03
Message: <5b5f8013@news.povray.org>
I have messed around with this, and I would not call the thickness
exactly uniform. Is it impossible to do?
Mike
Download 'offset_surface_save_06.png' (60 KB)
Preview of image 'offset_surface_save_06.png'
Date: 1 Aug 2018 01:15:00
Message: <web.5b6141abdce0719a553b3a4d0@news.povray.org>
> > #local h=0.00001;
> > /sqrt(
> #include "math.inc"
> is moved outside.
> Tor Olav
> http://subcube.com
Oh, okay.
Date: 1 Aug 2018 01:35:01
Message: <web.5b61463cdce0719a553b3a4d0@news.povray.org>
> > takes 3 arguments.
> > Tor Olav
> > http://subcube.com
> I tried this code:
> and this code:
> Mike
No no
If you would like to create a constant thickness shell. You must use the second
code.
