POV-Ray : Newsgroups : povray.binaries.images : Some Metals in Scene Server Time
23 Mar 2026 05:51:38 EDT (-0400)
  Some Metals in Scene (Message 1 to 8 of 8)
Subject: Some Metals in Scene
Date: 5 Sep 2013 11:45:04
Message: <web.5228a665262ece98d8cf5f1f0@news.povray.org>
Here an image of a fish nest (where fish can live).
Download 'fish_nest.bmp.dat' (2901 KB)
Subject: Re: Some Metals in Scene
Date: 6 Sep 2013 03:18:01
Message: <522981a9$1@news.povray.org>
This is not bad at all. Excellent work on the corroded metals. May we
have a peak at them? ;-)
How did you build the steel mesh? CSG? mesh2?
Date: 6 Sep 2013 07:00:01
Message: <web.5229b4e4b7059a87d8cf5f1f0@news.povray.org>
> Thomas
Thanks, the big object was modeled with Wings3D, the wall and the ground are CSG
and the wiring on the ground is made by a modified version of knot of... I can(t
remember where I have got this...
The metals are layered textures with some iridescence.
Date: 6 Sep 2013 07:10:01
Message: <web.5229b74fb7059a87d8cf5f1f0@news.povray.org>
The wiring is made with a (slightly) modified version of celtic knot bt Mike
Williams.
The last picture posted was in BMP format, here is a JPEG.
Download 'fish_nest.jpg' (494 KB)
Preview of image 'fish_nest.jpg'
Date: 6 Sep 2013 07:16:24
Message: <5229b988$1@news.povray.org>
> Williams.
Of Course; I should have guessed ;-)
You know that you can set the default output in POV-Ray? In povay.ini
add/edit the line:
Output_File_Type=N
where:
; See section 3.1.2.4.1 (Output File Type) of the Documentation for more
info:
; S= BMP, N=PNG, T=TGA (uncompressed), C=TGA (compressed), E=openEXR
(High Dynamic Range); H=HDR (High Dynamic Range)
Date: 6 Sep 2013 07:30:01
Message: <web.5229bbcab7059a87d8cf5f1f0@news.povray.org>
> add/edit the line:
> Output_File_Type=N
> where:
> info:
> Thomas
I know this option exist (even in command line, no? But I don't know how change
this - see the doc!) but I always use BMP format (lazyness...).
Date: 6 Sep 2013 08:02:50
Message: <5229c46a$1@news.povray.org>
>> add/edit the line:
>> Output_File_Type=N
>> where:
>> info:
>> Thomas
either one of two things ... you're setting Output_File_Type to bitmap
somewhere or you're not using 3.7 because the default (across all
platforms) is PNG
Date: 9 Sep 2013 01:33:41
Message: <522d5db5$1@news.povray.org>
>> add/edit the line:
>> Output_File_Type=N
>> where:
>> info:
>> Thomas
In version 3.6.x, edit the povray.ini file to add a line with +fn.
Now, all your renders will be as PNG files.
"+fn" will also work on the command line.
Beter solution: upgrade to version 3.7RC7 where the default format is PNG.
As a bonus, irid now works correctly and you will be able to use all
cores on a multicores computer.
