POV-Ray : Newsgroups : povray.binaries.images : Going the other way Server Time
25 Mar 2026 02:12:04 EDT (-0400)
  Going the other way (Message 1 to 10 of 12)
Subject: Going the other way
Date: 21 Jul 2013 09:45:01
Message: <web.51ebe3d3858dd1ead7c119640@news.povray.org>
Hi all,
A typical way of using with POV-Ray is the following. You take something from
the real world, say, a hammer that you really like, and model it in POV-Ray.
Subsequently, you use the model to create one or more images. You can, however,
also go in the opposite direction. Model an object in POV-Ray, and use that
model to realize the object in the real world, for example via 3D printing.
I recently did this, and the attached image shows the result. To be absolutely
clear, before anyone starts complimenting me on my wood and metal texturing
skills, the image is a photograph. It is not a render.
The image shows a 3D-printed object, which when viewed from the right direction
looks like an impossible triangle. It has been printed in stainless steel, with
a Bronze Plate finish. In the background you see an image created by POV-Ray.
Both the 3D-printed object and the background image were created from the same
POV-Ray based model. Custom macros were used to calculate each point in the
mesh. Parameters control amongst others the granularity of the mesh and the
number of cubes in the model. To convert the model to a format suitable for
3D-printing, the mesh was exported to file and further processed via MeshLab and
Sketchup.
I have put the object up for sale at Shapeways [1]. I am curious to see if there
will be any takers, but not getting my hopes up too high.
Kind regards,
Erwin
[1] https://www.shapeways.com/shops/eriban
Download 'dscn0101a.jpg' (110 KB)
Preview of image 'dscn0101a.jpg'
Subject: Re: Going the other way
Date: 21 Jul 2013 14:07:56
Message: <op.w0k3a4hyufxv4h@xena>
On Sun, 21 Jul 2013 15:42:04 +0200, Eriban
<pov### [at] spamgourmetcom> wrote:
> Hi all,
> from
> POV-Ray.
> however,
> that
> printing.
> absolutely
> texturing
> direction
> steel, with
> POV-Ray.
> the same
> the
> the
> for
> MeshLab and
> Sketchup.
> if there
> Kind regards,
> Erwin
Cool!
-Nekar Xenos-
Date: 21 Jul 2013 18:34:37
Message: <51ec61fd$1@news.povray.org>
nice work!
Date: 22 Jul 2013 03:00:51
Message: <51ecd8a3@news.povray.org>
Very nice indeed.
Question:
/printed in stainless steel/ ?? I think you mean something else than I
do read... :-)
Date: 22 Jul 2013 04:09:21
Message: <51ece8b1@news.povray.org>
Am 22.07.2013 09:00, schrieb Thomas de Groot:
> Very nice indeed.
> Question:
>> direction
>> steel, with
>> POV-Ray.
> do read... :-)
That's the marvels of modern 3D printing.
AFAIK shapeways actually print a wax model, and then die-cast it in
bronze steel; but there are 3D printers out there that work directly
with bare metal, using either sintering or depositing processes.
You can also get your stainless steel with a gold plating, and solid
sterling silver is another option (they do use some direct process for
the latter). Or how about glazed ceramic?
Date: 22 Jul 2013 07:27:29
Message: <51ed1721@news.povray.org>
Really? I thought it went through a casting process... But then of
course, I have not been following closely the developments of the
technique.
Date: 22 Jul 2013 07:58:22
Message: <51ed1e5e$1@news.povray.org>
> technique.
> Thomas
all kinds of things can be 3D printed now-a-days :
http://www.youtube.com/watch?v=82t84VIwlTE
Date: 22 Jul 2013 09:21:28
Message: <51ed31d8$1@news.povray.org>
> do read... :-)
Google "DMLS" - most rapid prototyping houses will do it, our local one
does.
Date: 22 Jul 2013 11:20:01
Message: <web.51ed4d97cab559a4d7c119640@news.povray.org>
> technique.
> Thomas
For creating objects from stainless steel, Shapeways actually does not use a
die-cast either. As far as I understand it, glue is printed on thin layers of
metal powder, which results in a fragile structure. This then is post-processed
into a strong metal object. I assume by first removing unused powder and next
hardening it, presumably by applying heat, but now I am just guessing. Some
details can be found here: https://www.shapeways.com/materials/steel
Anyway, I find it fascinating that you can model something from your own home,
and have it subsequently realized in 3D, in a whole range of materials. This was
the first object I had printed in stainless steel, but I have used 3D printing
before to prototype a puzzle I designed. At that time, I used a cheaper, plastic
material. Cool stuff.
Erwin
Date: 23 Jul 2013 03:41:05
Message: <51ee3391$1@news.povray.org>
>> do read... :-)
> does.
I am showing my age... ;-)
