POV-Ray : Newsgroups : povray.binaries.images : basaltic columns Server Time
18 Feb 2026 08:51:51 EST (-0500)
  basaltic columns (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: basaltic columns
Date: 5 Jun 2013 16:00:01
Message: <web.51af989be9c4aeff1027a5320@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote:
> Since you want to basaltic columns, if you want to randomize them a bit more,
> you probably still want a general six-sidded shape.
Well from looking at images some are less but I think that would just over
complicate things so six sides are fine ;-)
> One way you can do this is:
> 1. Generate a hexagonal array of points at the average offset/size you want
> 2. Apply a random small x and y offset to each
> 3. creat prisms based on a voronoi tesselation of the points
> - for each point, find the distance and direction to each of its 6 neighbours
> - for each of these pairs, create a plane at the exact midpoint, and
> perpendicular to the direction vector
> - you will have 6 vertical planes for each point, create a CSG intersection of
> the 6 planes (plus a top height plane).
> - this should result in having a six sided array with no gaps, bu the hexagons
> won't be perfect hexagons
Hmm, not sure if my math skills are up to this, I am sure it is not that
complicated but I never paid enough attention in this subject, if only they had
used POV back then to make it more interesting..
> The next difficult step is determining hor to make rounded or chamfered edges to
> these shapes if you want.
The current columns are made from intersecting 7 height fields (one for the top)
so similar to what you are referring to above with planes but with the obvious
advantages. I am rounding/beveling the edges by combining the granite/wrinkles
pigments with a gradient pattern to raise the edges of the hieght fields then
sizing them appropriately so the raised edges meet up. The top one has a granite
and sperical pattern to get the raised or sunk look for the puddles.
I will have to have a go at this but fear it may take me the 70 odd days to the
deadline to work it out ;-)
Thanks
Sean
Date: 5 Jun 2013 16:21:59
Message: <op.wx72uubrufxv4h@xena>
>> more,
> over
>> want
>> neighbours
>> intersection of
>> hexagons
> they had
>> edges to
> the top)
> obvious
> granite/wrinkles
> then
> granite
> to the
Try adding a small random component to the rotation of each plane.
For instance if you have the following:
plane{z, 0 rotate y*60}
first declare a seed
#declare RandSeed=97531;
change your plane as follows
plane{z, 0 rotate y*(60+5*rand(RandSeed))
-Nekar Xenos-
Date: 9 Jun 2013 10:00:02
Message: <web.51b48a1ae9c4aeffe52a27db0@news.povray.org>
Don't think I am fully using the technique mentioned above but it got me far
enough to randomise the shapes as in the attached. Also took the hint from
Thomas to change the edges of causeway to make it less even.
I did not add the clouds/sun/fog etc in this image it was just to check the
shape of the causeway and columns. Still more work to do but I am much happier
with this part of the scene.
Thanks
Sean
Download 'giants_new_shape.jpg' (640 KB)
Preview of image 'giants_new_shape.jpg'
Date: 9 Jun 2013 10:36:57
Message: <51b49309$1@news.povray.org>
Oooh! Looking awfully good!
Date: 13 Jun 2013 05:24:34
Message: <51b98fd2$1@news.povray.org>
I really like it,
   Paolo
Date: 16 Jun 2013 12:50:35
Message: <51bdecdb$1@news.povray.org>
I love your picture, realistic textures and greatly done, god job !
Date: 16 Jun 2013 13:02:22
Message: <51bdef9e$1@news.povray.org>
LOL
God job! :-D
Regards
Date: 16 Jun 2013 19:33:04
Message: <51be4b30@news.povray.org>
Thanks, I am still working on this one just trying to get a decent
looking sky, this is turning out to be one of my weaker skills though..
Sean
Date: 17 Jun 2013 01:25:02
Message: <op.wys5bydhufxv4h@xena>
> Sean
mediasky.pov in scenes/advanced could be a good start.
-Nekar Xenos-
Date: 17 Jun 2013 15:05:01
Message: <web.51bf5d43e9c4aeffe52a27db0@news.povray.org>
> -Nekar Xenos-
Thanks for the hint, that is an intersting scene. I have managed to get a sky I
like from running lots of fairly slow test renders, the problem now is that when
I add it to my scene and try to render with focal blur/radiosity etc it is so
slow. Think I will have to be very patient with this one.. At least there is
still plenty of time to the competition deadline.
Sean
