POV-Ray : Newsgroups : povray.binaries.images : Glass balls, via bullet physics Server Time
6 May 2026 18:43:26 EDT (-0400)
  Glass balls, via bullet physics (Message 1 to 10 of 23)
Subject: Glass balls, via bullet physics
Date: 25 May 2013 20:50:01
Message: <web.51a15af5cf3ed9044b5561b0@news.povray.org>
I finally made time to try out Koppi's bullet physics playground. It compiled
fine (on Ubuntu 12.04), although I had to run ldconfig before it would start up
- it might be worth mentioning that in the instructions.
Usage seems straightforward, especially with the demo scripts for reference. I
like the way it reruns the script with every keypress - pretty fun tweaking a
parameter and watching objects instantly start pouring into the simulation!
need to play more :)
Subject: Re: Glass balls, via bullet physics
Date: 25 May 2013 21:05:01
Message: <web.51a15fa1628c53be44b5561b0@news.povray.org>
also need to actually attach the image
Download 'glassballs.jpg' (144 KB)
Preview of image 'glassballs.jpg'
Date: 25 May 2013 21:45:00
Message: <web.51a1689c628c53befbb05f650@news.povray.org>
Pretty! I would love to see a larger version, perhaps with some dispersion :D
I had wished to try Koppi's bullet playground myself, but the building
requirements seemed high at the time.
Lately I've been running tests with Blender 2.67. Awesome, awesome app. You can
easily shatter any object into Voronoi cells, and apply physics to them. Then,
with the Cycles render engine, you can trace the scene with believable GI, with
focal blur coming cheap. But Blender's Cycles implementation still needs to
support more features to truly compete with POV-Ray :)
Sam
Date: 26 May 2013 06:30:01
Message: <web.51a1e361628c53be44b5561b0@news.povray.org>
I'll see what I can do ;) This version doesn't even use area light photons so I
could definitely crank it up a bit. Might tighten the view angle too.
I've seen some demos on youtube, it certainly is impressive... although the
cells in the videos I saw seemed a little uniform to be completely realistic. I
intend to get to grips with Blender at some point, but I feel I'll need a few
days solid work to really consolidate the basics, especially since I've not
really tried any triangle modellers properly before. I just can't seem to find
the time at the moment! The bullet playground at least is quite an easy tool to
quickly fire up for simple piles of stuff. I'd like to try some animation with
it too.
I'd be interested to see your blender physics tests, as I'm sure others would
too...!
Bill
Date: 26 May 2013 07:58:28
Message: <51a1f8e4$1@news.povray.org>
This is true. I spent a week just looking at tutorials before I tried to
build a model (Dan Dare's Anastasia). Although, I have still not come to
grips with Blender's Materials and Textures. Once you get to grips with
the controls Blender is, well I won't say easy to use, but very
workable. I found that it is straightforward to correct mistakes. It
does have CSG functionality but it is not as accurate as a pure
mathematical approach. As for Blender cycles I gave up on it as it is
Internal renderer.
Once you have your meshes PovRay materials can be used.
> too...!
Me too.
Regards
Date: 26 May 2013 12:05:01
Message: <web.51a2326a628c53be44b5561b0@news.povray.org>
Good to know.
> Internal renderer.
Hmm, not the best, I'd be using it on a Macbook which I think has an Intel
integrated GPU, so no dice.
This. It is often said that POV-Ray's texturing is one of its greatest
strengths, so as long as I can learn to uv-map properly in Blender I think I
would always return to POV-Ray for final renders.
Anyway, I'm ready to have a bash in theory - I've already got a second usb
keyboard+mouse so I just need a favourable conjunction of inclination and time!
Bill
Date: 26 May 2013 12:46:38
Message: <51a23c6e@news.povray.org>
> Good to know.
Especially the correcting mistakes bit. ;-)
>> Internal renderer.
Cycles is out then as it is with me. :-(
The Blender folk say that soon there will be no support for Blender
Internal but I've been told not to hold my breath for that to happen.
My plan as well. UV mapping seems straight forward. (But that could be
the simplicity of ignorance.) You can map a whole object in one step
and/or groups of faces by selecting them and adding a material.
I need something to build and model my scenes, a replacement for Moray
and Bishop3D. I hope that Blender can do that albeit in meshes and Nurbs.
> keyboard+mouse
O_O
Whit? You can use two keyboards and mice at the same time?
Oh, a numeric keyboard is very very useful.
Yes that is most important.
And may the Gods of Comp Grafiks smile on you. :-)
Regards
Date: 26 May 2013 13:20:01
Message: <web.51a243e2628c53becbc083be0@news.povray.org>
Uniform in size? One thing I learned is that the cells' sites can be based on a
child object's vertices or particles. So if you have some tiny spheres parented
to a larger cube, the cube can be broken up based on points from the spheres.
The cells' grouping can be easily controlled in this manner, and you won't end
up with a bunch of like-sized objects.
> I intend to get to grips with Blender at some point, but I feel I'll need a few
> it too.
Blender is definitely worth your time, whenever you can spare it. It really has
come a long way in recent years, and is valuable even if used only for its
modeling capabilities.
> too...!
I'll see what I can do :)
Sam
Date: 26 May 2013 13:35:01
Message: <web.51a24691628c53becbc083be0@news.povray.org>
> Internal renderer.
I have an NVidia GeForce, but it's too old for Cycles :( In fact, my entire
computer is over 6 years old. Cycles is fast in certain ways, and slow in
others. Relatively fast when combining radiosity + focal blur + light-emitting
geometry, slow when rendering glassy materials with caustics. I could really use
a new system :)
That reminds me, I can't for the life of me get POV-Ray to work with Blender!
When attempting to render a scene, I just get an unfilled checkerboard pattern.
Seems there's no way to tell Blender, "here is the POV-Ray executable." I may
have to edit the addon's source code...
Sam
Date: 27 May 2013 03:49:51
Message: <51a3101f@news.povray.org>
>> Internal renderer.
> a new system :)
Don't we all need a new system.
Well it is a bit soon for me to be using PovRay as a renderer. I want to
be able to use Blender properly first. But you intrigued me.
I downloaded the latest version of Blender (2.67a)
In User Preferences > Renderer. Enable POV-Ray 3.7
Expand the section and in Preferences (at the bottom of the section)
Set the location of the PovRay exe.
//..\..\..\..\..\..\Program Files\POV-Ray\v3.7 RC7\bin\pvengine64.exe
Save User settings.
In Blender set PovRay as the render engine and render.
I got that chequerboard pattern screen then PovRay started and the scene
rendered in PovRay. When I closed Pov the image appeared in Blender.
I actually had pvengine.ini open in the PovRay editor (Windows) and this
entry changed.
[LastRender]
SceneFile=QUICKRES
HistogramFile=
IniOutputFile=
CurrentDirectory=C:\Program Files\Blender Foundation\Blender
SourceFile=C:\Program Files\Blender Foundation\Blender\tmpoluh0u.pov
I changed PovRay's behaviour to close on completion and the whole cycle
took about 4 seconds for a simple scene.
Regards
