POV-Ray : Newsgroups : povray.binaries.images : flying police car WIP Server Time
18 Feb 2026 12:59:55 EST (-0500)
  flying police car WIP (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: flying police car WIP
Date: 28 Apr 2013 19:35:01
Message: <web.517db145bc86cde7333f2910@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> A close-up of the windshield area. (Hmm... it looks like the outline needs even
> MORE spheres; or else my technique needs some additional finessing.)
Hi Kenneth,
Nice model, I assume the muffler is the bit at the back towards the bottoms, if
not how did you do that shape in CSG?
As several people have already pointed out, I would go for a blob for the window
surround, I tend to always use blobs for this kind of modelling (unless I can
workout a good spline path for a sphere_sweep). If you can workout the spline
(not one of my strong points) then a sphere sweep would be best.
I have been looking through old unfinished scenes as well, mainly ones I gave up
waiting for the renders to complete due to heavy use of isosurfaces but with a
quad core, POV v3.7 and a bit more patience I may get them finished.
Sean
Date: 29 Apr 2013 02:20:00
Message: <web.517e1051bc86cdec2d977c20@news.povray.org>
> How about blobbing those spheres? A sphere_sweep could also be used here.
> Both would allow you to use less spheres.
Yes, *any* technique to use less spheres (or rather, less scanning/tracing
points in my technique) would be a welcome improvement.
I haven't worked with sphere_sweeps in quite awhile; the artifacts they used to
have (in the v3.6 and 3.61 days) made working with them difficult.  Actually, I
do remember your advice from the past--use *short sections* of sphere_sweeps
(i.e., not too many points) then union those together, which helps eliminate the
artifacts. So I might give that idea a try. It would definitely make a
*smoother* outline than my spheres.
Date: 29 Apr 2013 02:55:00
Message: <web.517e17bdbc86cdec2d977c20@news.povray.org>
It's another sPatch bicubic mesh. (I wouldn't have any clue how to make that
same shape using CSG!!) I still like using sPatch; it's an *old* app and with a
few quirks; but it has a very simple interface, to build objects point-by-point.
It does only one thing--no bells and whistles--but that's a welcome relief from
the usual (and generally complex) 'application that does everything.'
> the window
I have to admit that working with blobs has never been my strong point; it's
been years since I tried them! But I need to re-educate myself--they seem to be
a really powerful modelling tool. (Especially after seeing Nekar Zeno's
wonderful recent 'melting blob-men' image, of his jazz musicians.)
The spline requirement for the sphere_sweep is indeed a tricky thing to come up
with (re: my particular windshield outline.) What I imagine is that the spline
might not end up exactly following the correct curve. But that's just
theorizing; I should give it a chance, to see what happens.
Date: 29 Apr 2013 15:50:32
Message: <op.wwbiqhj7ufxv4h@xena>
On Mon, 29 Apr 2013 08:16:49 +0200, Kenneth <kdw### [at] gmailcom> wrote:
>> here.
> scanning/tracing
> used to
> Actually, I
> sphere_sweeps
> eliminate the
I guess I've just been lucky with the sphere sweeps. The neon lights in my
busker scene is all sphere sweeps.
-Nekar Xenos-
Date: 3 May 2013 07:10:01
Message: <web.51839a01bc86cdec2d977c20@news.povray.org>
OK, I made some subtle changes and improvements:
* added a 'quilted' normal pattern to the flashing lights
* some 'bumpers' onto the front--more traced spheres. (Why a flying police car
would need bumpers is a mystery, though!)
* and finally added some occupants! (My 'generic human' CSG model that I've been
working on for years.) They needed faces, so I used a photo of myself. They're
twins!
And I managed to smooth out the raised outline around the windshield, by
re-writing my eval_pigment 'image_map scanning' code to be more precise. There
are many more spheres now, and no gaps. (Part of the problem was human error--my
top-down windshield image render was made at 3000X3000 pixels, but I was
scanning it at an odd reduced rez.) I wanted to get this code working correctly,
before attempting a different technique for the outline. I think it looks pretty
good as-is, except in extreme close-up.
Download 'police_car_w2.jpg' (328 KB)
Preview of image 'police_car_w2.jpg'
Date: 3 May 2013 07:21:01
Message: <51839d9d$1@news.povray.org>
Better and better indeed.
Something which troubles me: why are those dials *behind* the pilots? I
would expect them in front of them. Also, the pilots appear to be a bit
too large in comparison with the craft.
Date: 3 May 2013 14:47:32
Message: <op.wwiuheraufxv4h@xena>
> There
> error--my
> correctly,
> looks pretty
It's very easy to convert spheres like this into blobs:
Just use "blob{" as you would to make a "union{" of spheres
Then change "sphere{SpherePos, SphereRadius etc}"
to "sphere{SpherePos, SphereRadius, BlobStrength etc}"
Start with a BlobStrength of 1. If it is too thick or thin, change it
accordingly.
-Nekar Xenos-
Date: 3 May 2013 16:50:01
Message: <web.518421e5bc86cde81c811d20@news.povray.org>
> Thomas
And they appear to be naked too.  You can just tell by the way they are avoiding
each other's gaze...
Date: 3 May 2013 18:40:00
Message: <web.51843b71bc86cdec2d977c20@news.povray.org>
Hmm, good point. My 'idea' is that the pilots are supposed to be almost
completely surrounded by dials and gauges and stuff. Honestly, though, I came up
with that conception *after* I added those dials-- just to mentally justify the
addition :-O  Practically speaking, the back wall of the cockpit is the only
location where they can be visible, and it needed some kind of detail there.
> Also, the pilots appear to be a bit too large in comparison with the craft.
Yeah, that's an on-going debate I'm having with myself (which actually has
nothing to do with the police car.) There is another, more 'important' model in
my animated scene, one that also has a human occupant--and he's scaled a certain
way to match that particular model. I'm trying to match the police car occupants
to his scale--without changing the scales of the overall models themselves
(their relative sizes are just the way I want them to be.) Solution: I'll adjust
the scale when I put this police car back into the main scene, where I can see
everything at once.
Date: 3 May 2013 18:55:00
Message: <web.51843f6bbc86cdec2d977c20@news.povray.org>
> accordingly.
Hey, thanks for the example code. I'll try this out and see what happens. I'm
guessing that I don't need to 'scan/trace' my image_map and model at the
high-resolution I've been using, as blobs are joined together smoothly,
automatically filling in the intervening gaps.
BTW (and this is a bit off-topic): For your jazz-musician scene and its
neon-signs (the sphere_sweeps), did you experience any of the 'clipping'
problems that are being discussed? I didn't see any obvious problems in your
renders.
