POV-Ray : Newsgroups : povray.binaries.images : Toroidal Planet Server Time
4 Apr 2026 07:14:28 EDT (-0400)
  Toroidal Planet (Message 31 to 33 of 33)
Subject: Re: Toroidal Planet
Date: 15 Nov 2012 08:05:01
Message: <50a4e87d$1@news.povray.org>
On 15-11-2012 13:22, Stephen wrote:
> "Bill Pragnell" <bil### [at] hotmailcom> wrote:
>>>> Stephen <mca### [at] aolcom> wrote:
>>>>> Fair point Bill. But Ed said "It should spin in about 12 hours or 24
>>>>> hours or so."
>>>> Which is not fast enough for significant centrifugal effects -
>>> Are you sure, are my calculations wrong?
>> Um, I didn't check. Quick calculation of my own, assuming a torus minor diameter
>> the same as the earth, which gives a major radius of about 6 earths (~77,000km),
>> spinning once per 12 hours, I get a centripetal acceleration of about 1.6
>> ms-2... ok, a bit more significant than I thought, that's about 1/6th of a g
>> more on the inner surface and less on the outer surface.
> Oops! I forgot to divide bt 9.81 and called m/s^2 g :-(
>> Athletes from the inner provinces would trounce their opponents from the outer
>> lands :)
>>>>> Personally I prefer the Culture Orbitals. ;-)
>>>> Me too. Mostly for the amenities :)
>>> And the snappy repartee. ;-)
>> and let's not forget the parties!
> If you can remember the parties then you wern't there. ;-)
I see that on my travels, jumping through hoops with my spacecraft, I
missed all the fun... :-)
Date: 15 Nov 2012 11:20:00
Message: <web.50a515ef9fede59878641e0c0@news.povray.org>
> A planetary magnetic field is not needed to protect life on the planet's
> surface, you only need a thick enough athmosphere.
However, a magnetic field may be needed to protect the /atmosphere/ itself.
Mars once had a much thicker atmosphere, and the going hypothesis is that it was
blown away by the solar wind after Mars' core solidified.
Date: 16 Nov 2012 14:53:59
Message: <50a699d7$1@news.povray.org>
Mars is also about half the Earth's radius, making it 1/8th the mass and
a much lower surface gravity. Been farther from the sun makes it cooler
and reduce the athmospheric evaporation that was greatly increased by
the lower mass. Mars DOES slowly loose some of it's athmosphere, mostly
light gases like oxygen and nitrogen, at a greater rate, leaving about
only carbon dioxide.
Now, take a planet with an average density of about 3, compared to
around 5 for the Earth, and increase it's radius to get a surface
gravity of 0.9g. Take it slightly farther from the Sun.
That planet could have a surface athmosphere similat to Earth, but it
would extent much higher, making it thicker. The planet been farther
from the sun receive less energy, compensating the higher thermal retention.
The Solar wind effect on it would be rather negligeable even without any
magnetic field. At the same time, that planet can actualy collect stray
gases, and some mass from the solar wind, to replentish itself.
On such a planet, nights would be warmer than on Earth and, for the same
axis tilt, you'd expect less contrasted seasons as the athmosphere would
have more thermal inertia.
