POV-Ray : Newsgroups : povray.binaries.images : Isosurface bricks Server Time
6 May 2026 21:30:35 EDT (-0400)
  Isosurface bricks (Message 1 to 9 of 9)
Subject: Isosurface bricks
Date: 29 Oct 2012 04:20:01
Message: <web.508e3b63dd2b8c90d97ee2b90@news.povray.org>
For the past several days, I've been trying to come up with a method for making
nice-looking isosurface brick walls.  I was hoping to use them in a halloween
themed scene, but I'm not sure I'll have it presentable in time, now... :(
anyway... The bricks look sorta nice, so I thought I'd share.
A.D.B.
Download 'workshop2.png' (511 KB)
Preview of image 'workshop2.png'
Subject: Re: Isosurface bricks
Date: 29 Oct 2012 10:48:38
Message: <508e9746@news.povray.org>
> Regards,
> A.D.B.
Very cool. (Really. I can feel the grain of the bricks)
Now a few points:
* where is the mortar ? (for halloween, the mortar was made of icing
sugar... all leached... ;-) )
 (more seriously, there is about 10 geometry for the mortar, each with a
purpose or a usage:
http://www.bontool.com/knowledge_center/KC_Mortar_Joints.asp
and do not ask how & why I know that page!)
* too much random variation of colours: colour of bricks came from the
temperature in the oven, nearby bricks in the oven get the same kind of
colour... and nearby bricks in the oven ends up as nearby bricks in the
package... then nearby bricks in the package ends up on the same row or
nearby rows (unless you are a Netherlander, in which case you might have
a white package and a red package to pick from in order to make some
motifs).
* no burning remains on each bricks... too uniform colour of each bricks
Date: 30 Oct 2012 00:50:08
Message: <web.508f5bcf1f1a289ed97ee2b90@news.povray.org>
> > Regards,
> > A.D.B.
> Now a few points:
> purpose or a usage:
> motifs).
The bricks are a simple f_rounded_box with irregular scaling based on a wrinkles
pattern multiplied by a scaled cells pattern to vary the brick depth.
The coloring is similar to a method by Jeff Lee, which can be found here:
http://www.shipbrook.net/jeff/raytrace/bricks.html
his doesn't have as much variation in the colors as mine does, though.  Probably
because he uses a bozo pattern, where I use a cells pattern (I find the cells
pattern easier to scale to the proper dimensions, whereas he uses the default
brick sizes)
What I'd really like to do, however, is model the entire wall as a continuous
isosurface.  Ive had -some- success with this using a warped checker pattern as
the base and filling the squares with a scaled boxed pigment, but the problem is
that when I scale the resulting pigment to match the dimensions of the bricks,
the mortar gets squashed vertically and stretched horizontally, and it throws
off the spacing of the pigment overlay... It's something I'll need to work with
a bit more.
Perhaps if I were to use a pair of gradients with a triangle_wave modifier, I
could calculate the falloff of the color maps so that it scales to the proper
dimensions...
anyway, I'm glad that someone likes it.
A.D.B.
Date: 30 Oct 2012 04:00:56
Message: <508f8938$1@news.povray.org>
>> [snip]
>> motifs).
Fwiw, sometimes a large variation is intentional. My own house has such
a large variation (not as shown here though) and it has a different
visual impact compared to other houses in the neighbourhood.
Ah! I thought it looked familiar ;-) While a bit extreme imo, I always
liked those shades.
Oh, without a doubt.
Date: 30 Oct 2012 05:02:36
Message: <508f97ac$1@news.povray.org>
>>> motifs).
Right. When intentional. But the OP seems just to have used random...
and it was unlikely (so much as too push me into the disbelieve valley),
at least with such dispersion without a bit of control.
And Fwiw, I bet you have been contaminated by the Dutch (no offence
intended). Of course, your own house is an architect's house, so it
cannot be as the other houses! ( ;-) )
Date: 30 Oct 2012 08:37:12
Message: <508fc9f8$1@news.povray.org>
> intended).
Well, as I /am/ Dutch and living in the Lowlands too... ;-)
> Of course, your own house is an architect's house,  so it cannot be as
It is a fairly standard design for the region, with variations, amongst
others, of brick use. And there are many possible variations :-)
Date: 30 Oct 2012 10:56:49
Message: <508feab1$1@news.povray.org>
>> Regards,
>> A.D.B.
> Now a few points:
> purpose or a usage:
> motifs).
The colour variations in this image are very similar to those I see
every day in my, and several others, neibourhood. The colour variation
don't come only from the cooking temperature but also from the pigment
used, and how well mixed in it was, and variations in the clay used.
Older houses have much more variation than recent ones reflecting both
hovens having a more uniform temperature and improved mixing equipment.
Here again, I need to disagree with you. Most bricks I see every days
are almost identical to those.
Date: 30 Oct 2012 11:14:28
Message: <508feed4$1@news.povray.org>
Am 30.10.2012 15:56, schrieb Alain:
>> motifs).
Mixing of different batches of bricks may also have been common in large
European (especially German) cities after WW2, when people gathered
intact bricks from the ruins. (Those bricks might also have been subject
to fires, which might have introduced additional color variations via
soot and heat.)
Date: 30 Oct 2012 11:36:37
Message: <508ff405$1@news.povray.org>
>>> motifs).
> soot and heat.)
We never had that in Montréal... No major war and no massive destruction
in this area in about 200 years :)
But, yes, deliberate mixing is sometimes evident, like that house in
front of mine where dark bricks dominate in the bottom of the wall and
lighter ones in the top with a gradual shift.
