POV-Ray : Newsgroups : povray.binaries.images : Lathe problems. Server Time
21 Apr 2026 20:31:33 EDT (-0400)
  Lathe problems. (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Lathe problems.
Date: 17 Oct 2012 10:16:13
Message: <507ebdad$1@news.povray.org>
I am frankly at a loss for a solution, but some questions impose
themselves maybe.
1) are the two ends overlapping?
2) the ends do not seem to be exactly parallel, (outer) edges flowing
smoothly into one another.
3) could the effect be due to refraction?
Date: 17 Oct 2012 11:20:00
Message: <web.507ecbe7a5d212b1f2eb76540@news.povray.org>
> themselves maybe.
> Thomas
The lathes were built with the lowest point on the ground plane then rotated 90
degrees. The other bulb is mirrored so the edges should be coincidental.
Although I can see that there is not a smooth transition between them in the
opaque image. The inner lathe extends past the outer one and the highest level
CSG is a merge so there should be no internal surfaces.
Well the IOR is quite high for glass, greater than 1.5 IIRC. I was wondering
about internal reflections as well.
Date: 17 Oct 2012 11:35:01
Message: <web.507ecf4da5d212b1ed8e7a0@news.povray.org>
> > > So I then created a second lathe object, making sure that it was inside the
> > > first and that the thickness was as constant as I could make it then referenced
> > > it to make the hourglass. Now there looks like there is flaring at the join.
> >  The final two images are closeups of the join area. The first unfinished one
> > (12.5 hours) shows what looks like a disc around the join and the second is the
> > same scene with an opaque material
> > One image at a time, it seems
> Now the opaque one
I suggest you render a cross-section, preferably highlighting the cutaway
surface (i.e. intersection { <hourglass> plane { -z, 0 pigment { rgb x } } } ).
But I think most of your problems come from using a spline type where you can't
control the gradient where the mirrored bulbs meet. So either don't mirror them,
and use a curve that describes both bulbs of the hourglass, or use a
bezier_spline and place the control point tangentially to the desired curve to
get a smooth transition.
Or you could download the source for my "Sands Of Time" IRTC entry:
http://exether.free.fr/irtc/index.php?sub=pg2004&lang=en&year=2004&month=8&typ=S&mrk=C
Tek
Date: 17 Oct 2012 16:01:49
Message: <507f0ead$1@news.povray.org>
Yes, I think that is the way to go. It has been ages since I have used
SORs or Lathes and I am quite lazy. :-)
I was using a cubic curve but my endpoint wasn't making making the joint
take the right angle.
Strange that you say that, Norbert suggested it too.
I found it interesting that you could use so few points and get such a
good curve.
Regards
Date: 17 Oct 2012 16:15:53
Message: <507f11f9@news.povray.org>
> themselves maybe.
I checked and they were. :-(
Even after correcting that. The gold ring was still there but much
diminished.
Too true, I used a poor end point.
Yes, I think so. When I commented out the sand. The ring was still there
but much less visible.
Ah! Well. Back to the drawing board.
Regards
Date: 17 Oct 2012 20:42:30
Message: <507f5076$1@news.povray.org>
You could try to reshape the curve in the center so it is not
a hard edge but rather a little rounded. If this is two pieces
joined together you'll want the end to have vertical/horizontal
tangents. BTW you can post more than one image when using a
newsreader such as Thunderbird.
Date: 18 Oct 2012 05:15:01
Message: <web.507fc835a5d212b1ed8e7a0@news.povray.org>
> good curve.
That's why I love bezier curves. You can describe a nice "S" bend using 2 points
plus 2 control points.
Download 'bezier_graph.png' (9 KB)
Preview of image 'bezier_graph.png'
Date: 18 Oct 2012 05:20:01
Message: <web.507fc91aa5d212b1ed8e7a0@news.povray.org>
> > good curve.
Doh! I just realised my hourglass *doesn't* use bezier splines! Hah. Well, it
would if they were available for a sor, because I like beziers...
Date: 18 Oct 2012 13:55:48
Message: <508042a4$1@news.povray.org>
And I thought that a SOR was linear. Ah! Well, you re-learn something
every day.
Regards
Date: 18 Oct 2012 13:58:21
Message: <5080433d$1@news.povray.org>
> tangents.
Thanks but I will give up on joining two halves and try a continuous curve.
I know but I have to use the web interface when at work.
Regards
