POV-Ray : Newsgroups : povray.binaries.images : Lonely tree Server Time
16 Mar 2026 00:41:24 EDT (-0400)
  Lonely tree (Message 1 to 8 of 8)
Subject: Lonely tree
Date: 3 Jul 2012 17:05:01
Message: <web.4ff35dd1ac13458cd19b0ec40@news.povray.org>
I've taken a small break from my busy schedule of playing Diablo III. Here's a
start. Figuring out how to make the ground more hilly.
Download 'tree.jpg' (276 KB)
Preview of image 'tree.jpg'
Subject: Re: Lonely tree
Date: 3 Jul 2012 20:35:01
Message: <web.4ff38ed31b311391d19b0ec40@news.povray.org>
Not so lonely anymore.
Download 'tree.jpg' (312 KB)
Date: 4 Jul 2012 04:02:55
Message: <4ff3f8af$1@news.povray.org>
The start of a forest? ;-)
Somehow, the grass in this second image gives the impression of being an
image map, which it is not? there is a disturbing straight boundary.
Your own tree model?
Date: 4 Jul 2012 12:20:01
Message: <web.4ff46cc11b311391d19b0ec40@news.povray.org>
> Thomas
A forest, eh? Might be a good idea.
Also it's all grass. 6 GB worth of mesh grass.
Date: 5 Jul 2012 03:50:57
Message: <4ff54761$1@news.povray.org>
I thought so too. I think that a bit of vertical random scaling of each
grass patch would improve the scene.
Date: 5 Jul 2012 14:25:00
Message: <web.4ff5db031b311391352a052d0@news.povray.org>
> > Thomas
That's quite insane.  I mean, sure there's a lot of grass blades there, but
aren't they all instances of the same simple geometry?  Why all that data?
BTW, that looks like a Blender exported scene.  Easy to create a grass blade
from a single plane, there's the builtin sapling add-on that creates tree likes
that (weeping lilly is one of the predefined models) and all you'd need is
create a big plane for the floor and in the physics tab apply a particle system
with the blade object as particle.
Date: 6 Jul 2012 06:31:29
Message: <4ff6be81$1@news.povray.org>
Am 05.07.2012 20:20, schrieb nemesis:
Multiple instances of the same mesh only share vertices, UV coordinates,
normals and faces (plus possibly per-triangle or per-vertex textures);
other stuff can be different per instance, and thus require some
per-instance memory overhead, most notably the transformation
information, which requires a whopping quarter kB (4x4 64-bit floats for
the matrix, plus the same for its precomputed inverse). Now multiply
that by two dozen million of grass blades and you're there.
Now you may think that a dozen million grass blades is a lot; but at an
estimated density of one grass blade per cm^2, that's a lousy 60m x 40m
worth of grass.
For more efficient memory use, I'd recommend defining not single grass
blades, but an assorted collection of grass patches, maybe 100 blades
per patch. With an estimated 100 triangles and vertices per blade, and
10 different patches (which you can rotate and flip to give added
variation), the pure mesh data would still remain reasonably "small" (a
guesstimated 15 MB), while cutting down the per-instance overhead by a
factor of 100 (to 60 MB in this case).
Date: 6 Jul 2012 21:30:02
Message: <web.4ff7903c1b311391d19b0ec40@news.povray.org>
It's a lot of grass. I'm using Gilles Tran's grass macro. Tree is from arbaro.
Arbaro is great! Clouds made with some of Gilles Tran's df3 files.
