Hi people.
Usually I'm not doing any kind of advertising, but here I have to do;)
It's a texture-tool, able to reconstruct the 3D structure of a surface. It
creates a 3D-shape of the surface, a displace-map, a normal map, a specular-map,
an occlusion map, a diffuse map, a bump map and (dono, what for) a limited
displace map.
What you see here, is an highfield, using the displace-map and as a texture the
diffuse map, the occlusion map and the bump map.
It's rendered, using MC-Pov. Please note, I've used the .BMP-format in windows.
So the statement is "SYS"-format for the maps. If you using Linux, you should
use .PNG instead.
The texture is one of the samples, coming with the software.
Here the code:
#declare Clock=0.45; //clock;
global_settings {
assumed_gamma 1
location <-3+6*Clock, 0.0, -3.0>
direction 1.5*z
look_at <0.0, 0.0, 0.0>
sphere {0,1
color rgb 1
finish{montecarlo{mc_diffuse{1 1 1}} diffuse 0 ambient 2 }
montecarlo{mc_sky{100}}
hollow
scale 100000
plane{y,-0.65 pigment{color rgb 1}
finish{montecarlo{mc_diffuse{1 1 1}} diffuse 1}
#declare P=pigment{image_map { sys "diffuse.bmp" map_type 0 interpolate 2 once
#declare N=normal{bump_map { sys "bump.bmp" map_type 0 interpolate 2 once
bump_size 1}}
#declare L=texture{
material_map{
sys "occlusion.bmp" map_type 0 interpolate 2 once
#declare T=0;
#while (T<256)
pigment{P}
finish{
diffuse 1-1/pow(T,1.75)
reflection {(1/pow(T,4))/40,0}
normal{N}
#declare T=T+1;
rotate x*90}
height_field{
sys "displace.bmp"
texture{L}
translate <-0.5,-0.5,-0.5>
rotate x*-90
scale <1,1.6,0.25>
Here the Software, have fun :)
It produces only 8-bit files :( but maybe it's because, it's a demo..?
http://www.photosculpt.net/
Download 'render.jpg' (73 KB)
Preview of image 'render.jpg'
On 5/17/2012 2:39 PM, H. Karsten wrote:> Hi people.
surface. It
Actually, that's really cool! :D
~Mike
