POV-Ray : Newsgroups : povray.binaries.images : Aurora Land mass test Server Time
7 May 2026 00:20:18 EDT (-0400)
  Aurora Land mass test (Message 1 to 7 of 7)
Subject: Aurora Land mass test
Date: 13 Apr 2012 14:25:03
Message: <web.4f886e6a7366f660f158abba0@news.povray.org>
Testing things I'll need to build land masses for the Aurora world where the
Singularity travels about.
This is a 1km x 1km chunk.  I added a monastery object I had to show scale.
I really need some kick-a** textures for the stone blob base.... anyone have
something that would work better than the granite gray?  I'm looking for
something that gives it the impression that it is a chunk of the earth sliced
out and floating about.
Download 'landtest1.jpg' (169 KB)
Preview of image 'landtest1.jpg'
Subject: Re: Aurora Land mass test
Date: 13 Apr 2012 17:41:54
Message: <4f889da2$1@news.povray.org>
Le 13/04/2012 20:20, Becraft, Robert nous fit lire :
Desert valley like texturing. (horizontal/perturbed bands of
orange/red/...dark)
Date: 14 Apr 2012 02:35:01
Message: <web.4f891a42feffd0c11b310e2f0@news.povray.org>
Hi Robert,
look at the old LOTW2 project pages of Christoph Hormann
(http://www.imagico.de/lotw2/history.php).
Here you can find tons of nice procedural textures - but you have to extract the
texture definitions from the files and includes...
Norbert Kern
Date: 14 Apr 2012 02:53:49
Message: <4f891efd$1@news.povray.org>
A banded texture - slightly inclined - like suggested by Le_Forgeron,
maybe with a vertical gradient too (darker below, lighter top; although
the opposite would probably work well too...)
Date: 16 Apr 2012 04:09:11
Message: <4f8bd3a7@news.povray.org>
Nice to play again with those landscapes. They stimulate ideas for
future scenes.
I have "improved" the sky/Sun code for the LOTW scenes (see image
below). The following code can be used for all of them I suppose, just
copy and past the relevant section in the LOTW scene files. You need the
CIE.inc file though, which can be found here:
http://www.ignorancia.org/en/index.php?page=Lightsys
//start code
// --- part written by skies.inc ---
//  >>>> skysphere sky <<<<
#include "CIE.inc"
#declare SunColor = Blackbody(2800)*1;  //2800=red; 7500=white blue
#declare Azm = 20;
#declare Alt = 5;
#declare fn_horizon=function { max(z, 0) }
#declare fn_sun=
   function {
     pattern {
       spherical
       scale 3
       translate y
       rotate x*Alt
       rotate z*Azm
sky_sphere {
     function { pow(fn_horizon(x,y,z)*(1-fn_sun(x,y,z)), 0.400) }
     color_map {
       [0.000 color SunColor]
       [0.426 color rgb <0.200, 0.300, 0.800>]
// --- part written by lighting.inc ---
light_source {
  <0,0,0>
  color SunColor
  translate 10e5*y
  rotate x*Alt
  rotate z*Azm
sphere {
   0, 1
   hollow on
   no_shadow
   pigment { rgbt 1 }
   interior {
     media {
       emission SunColor/1000
       density {
         spherical
         poly_wave 4
         density_map {
           [0.0 rgb 0]
           [0.5 color rgb <0.3, 0.3, 0.3>]
           [1.0 color rgb <1, 1, 1>]
       samples 100 confidence .1
   scale 24000
   translate 10e5*y
   rotate x*Alt
   rotate z*Azm
//end code
Enjoy!
Download 'lotw 34_18_var.png' (483 KB)
Preview of image 'lotw 34_18_var.png'
Date: 17 Apr 2012 15:10:01
Message: <web.4f8dbff5feffd0c1f550c1b0@news.povray.org>
> future scenes.
> //start code
> #include "CIE.inc"
> #declare Azm = 20;
> #declare Alt = 5;
> #declare fn_sun=
>    function {
>      pattern {
>        spherical
>        scale 3
>        translate y
>        rotate x*Alt
>        rotate z*Azm
> sky_sphere {
>    pigment {
>      color_map {
> light_source {
>   <0,0,0>
>   color SunColor
>   translate 10e5*y
>   rotate x*Alt
>   rotate z*Azm
> sphere {
>    0, 1
>    hollow on
>    no_shadow
>    pigment { rgbt 1 }
>    interior {
>      media {
>        density {
>          spherical
>          poly_wave 4
>          density_map {
>            [0.0 rgb 0]
>    scale 24000
>    translate 10e5*y
>    rotate x*Alt
>    rotate z*Azm
> //end code
> Enjoy!
> Thomas
I tried this Thomas... the scenes come out very grainy and dim.  Even moving the
Alt and Azm around, I couldn't get anything very good out of the render.
The other link to Christoph's textures and such gave me a texture I used here...
Download 'landtesta1.jpg' (204 KB)
Preview of image 'landtesta1.jpg'
Date: 18 Apr 2012 03:23:57
Message: <4f8e6c0d$1@news.povray.org>
I did not tell but should have mentioned: The code is for the LOTW
scenes which are oriented with the z-axis *up*!! So this code works for
those scenes but for the conventional left-handed POV-Ray scenes, you
have to switch "z" and "y". Also note that in order to keep the Sun
above the horizon you can either translate the Sun first in the +z
direction and use Alt as a negative multiplicator to x, or translate
towards -z and use Alt as a positive multiplicator to x. The reason why
I have chosen for a negative Alt here is because I also use SunPos.inc
which translates the Sun towards +z. Here is the relevant code for
left-handed scenes:
//start code
#declare fn_horizon=function { max(y, 0) }
#declare fn_sun=
   function {
     pattern {
       spherical
       scale 3
       translate z
       rotate -Alt*x
       rotate Azm*y
light_source {
  <0,0,0>
  color SunColor
  translate 10e5*z
  rotate -Alt*x
  rotate Azm*y
sphere {
   0, 1
   hollow on
   no_shadow
   pigment { rgbt 1 }
   interior {
     media {
       density {
         spherical
         poly_wave 4
         density_map {
           [0.0 rgb 0]
   scale 24000
   translate 10e5*z
   rotate -Alt*x
   rotate Azm*y
//end code
Hope this helps
