POV-Ray : Newsgroups : povray.binaries.images : colored leaves Server Time
29 Mar 2024 09:23:32 EDT (-0400)
  colored leaves (Message 1 to 10 of 21)
Subject: colored leaves
Date: 15 Mar 2012 15:30:00
Message: <web.4f624250b5209546dc4ffc880@news.povray.org>
i want to share a nice trick.
One of the disadvantages of tree modelers using imagemap based leaf textures is
the uniformity of the foliage.
On the other hand the first leaves getting colored in autumn are the outer ones.
So the task was to get an existing mesh recolored based on a pattern like onion
or projection (mlpov or megapov).
Using a texture_pattern was awfully slow, so I decided to find a way to save the
color information.
So I used an old Poseray version, which opens mesh2 files and is able to save in
the old mesh formate (Poseray 3.8.7).
Then I read the first triangle coordinate and saved the color value derived by
the projection pattern in a different file. After some copy and paste I had a
mesh with three different imagemap based leaf textures (red, yellow and green).
As a demonstration file I used a nice backlit scene inspired by a romantic
painting I found on the web long time ago.
Only the two big trees use the projection pattern trick.
Norbert Kern
Subject: Re: colored leaves
Date: 15 Mar 2012 15:35:04
Message: <web.4f6243b5985f1ee4dc4ffc880@news.povray.org>
hmm, here is the image...
Download 'colored_trees.jpg' (369 KB)
Preview of image 'colored_trees.jpg'
Date: 15 Mar 2012 15:48:22
Message: <4f624786$1@news.povray.org>
Am 15.03.2012 20:32, schrieb Norbert Kern:
Nice one; what did you use to make this picture - acrylic or oil colors? :-D
Honestly, this is fantastic.
Date: 15 Mar 2012 16:15:01
Message: <web.4f624d37985f1ee4d25d21bf0@news.povray.org>
Hm, seems to be povray
fantastic
Date: 16 Mar 2012 03:59:03
Message: <4f62f2c7$1@news.povray.org>
Excellent technique and very beautiful image indeed!
On 15-3-2012 20:29, Norbert Kern wrote:
> Hi,
> [snip]
Ah this is nice! Might be a good reason to ask FlyerX to add a
mesh/mesh2 save option, with mesh2 as default.
I am not entirely sure how you did this but the result is spectacular
and convincing.
Date: 16 Mar 2012 04:33:03
Message: <4f62fabf@news.povray.org>
> Norbert Kern
Impressive.
Paolo
Date: 18 Mar 2012 05:00:01
Message: <web.4f65a3c1985f1ee41dab3f8c0@news.povray.org>
thank you very much!
Date: 18 Mar 2012 05:00:03
Message: <web.4f65a3eb985f1ee41dab3f8c0@news.povray.org>
> fantastic
Thanx!!
Date: 18 Mar 2012 05:10:01
Message: <web.4f65a5fb985f1ee41dab3f8c0@news.povray.org>
> and convincing.
I will add a simple demonstration file to povray.binaries.scene-files, where the
several steps are shown.
As you can see, saving a mesh saves a lot of render time, but there is a
disatvantage too - sharp leaf texture changes can happen within one leaf.
Of course this trick can be useful for several kinds of slow textures applied to
a mesh...
Norbert
Download 'projection pattern trick.jpg' (142 KB)
Preview of image 'projection pattern trick.jpg'
Date: 18 Mar 2012 05:10:02
Message: <web.4f65a627985f1ee41dab3f8c0@news.povray.org>
Paolo Gibellini <p.g### [at] gmailcom> wrote:
> Impressive.
> Paolo
