POV-Ray : Newsgroups : povray.binaries.images : beginner first attempt at creating an industrial landscape scene Server Time
22 Dec 2025 20:10:35 EST (-0500)
  beginner first attempt at creating an industrial landscape scene (Message 1 to 4 of 4)
Subject: beginner first attempt at creating an industrial landscape scene
Date: 25 Jan 2012 23:50:02
Message: <web.4f20da4e35c654685d50475e0@news.povray.org>
Hello, in fact it's my first "real" scene. but i am not satisfied with it.
I have a lot to correct :
-realistic scales (real life sizes for objects)
-gamma
-realistic railroad powerlines
-better choice of textures for the cooling towers
-perturbations in the road texture, and just a bit on the concrete of the
buildings
-focal blur (but since the field is wide i dont know if it is necessary
-the fog is just here to block the view at the horizon. I will have to put big
mountains at long range or maybe some skyscrapers
-terrain unrealistic, will try geomorph or a macro to put boulders and rocks on
top of the normal.
-best practices for optimizations for quicker render (unions, etc...)
More objects, like an oil refinery on the side (looks beautiful at night)
I have the feeling that an open landscape is in some ways harder to get ok than
little scale object with a limited field of view.
-if anyone has some simple advices, i will be glad to read them !
last thing :
what i love with povray is that it stimulates a lot the brain spatial abilities
to perform translations, rotations and some long forgotten math. :)
image contains some macros of f-lohmueller (thanks) and skies from Mike Kost
(thanks).  trees from Gilles Tran. (Thanks)
Download 'rail0232.zip' (1494 KB)
Subject: Re: beginner first attempt at creating an industrial landscape scene
Date: 27 Jan 2012 23:10:13
Message: <4f237525@news.povray.org>
It makes things esier to work with, but is not needed. Just keep a
concistent scalling.
> -gamma
Should be set to 1
> buildings
For that kind of view, minimal to no focal blur. All distances are very
large relative to the aperture.
> top of the normal.
> last thing :
Why put your image in a ZIP file with zero compression, you should have
posted the image by itself. Anyway, a PNG is already compressed and
practicaly don't compress.
Street lamps on during the day?
Turn them off or keep them on and do a night scene.
If the lights are off, it will render faster at there will be less
shadow tests.
Try to add some variety in the vegetation, or make it denser. Use some
random rotations and some slight, possibly uneven, scalling to hide the
similarities. rotate, uneven scale, rotate again.
The railway power line normaly also have another cable over the actual
power cable connected by numerous vertical lines used to hold it
straight. That superior cable do curve like a catenary.
Whenever several share the same texture, put them in an union and apply
the texture to the union, not the objects.
If the objects have several textures, apply the dominant/most used one
to the union.
Date: 29 Jan 2012 19:57:49
Message: <4f25eb0d$1@news.povray.org>
Am 28.01.2012 05:10, schrieb Alain:
>> it.
>> -gamma
> Should be set to 1
To prevent confusion:
- assumed_gamma scene setting should be set to 1.
- Display_Gamma ini file setting should match your display's gamma (2.2
is a good solid guess; if using POV-Ray 3.7, you should be fine without
explicitly specifying this setting).
- File_Gamma ini file setting should be left alone (in POV-Ray 3.6 it
doesn't exist, while in POV-Ray 3.7 the default is usually the best choice).
I actually do like the colors. While they're unrealistic (and even
though in my renders I usually strive for photorealism), it gives the
image some surrealistic touch.
Rule of thumb: If using focal blur, set aperture size to whatever
POV-Ray units would match a size of somewhere around 1 cm (somewhere
between the size of a human's pupil and the apparent size of a camera's
aperture as seen through the lens). Significantly higher values will
make your scene look like a miniature.
Date: 7 Feb 2012 01:55:06
Message: <web.4f30ca6311dffed65d50475e0@news.povray.org>
> >> it.
> >> -gamma
> > Should be set to 1
thanks for all the info.
i will update the catenary for the railroad power lines, with two parallel
cables.
In fact, i noticed that railroad power lines have no slack so there is no need
to use a catenary function and a sphere sweep. a simple cylinder will do
i felt inspired however to play with catenaries so
I added a real high voltage power line and a catenary with slack. the result is
good.
