POV-Ray : Newsgroups : povray.binaries.images : conserve_energy and fade_color bug Server Time
22 Apr 2026 01:40:28 EDT (-0400)
  conserve_energy and fade_color bug (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: conserve_energy and fade_color bug
Date: 26 Jan 2012 07:02:01
Message: <4f2140b9$1@news.povray.org>
On 26-1-2012 10:45, nemesis wrote:
> Seems to me that he forgot to set ior>  1 in the interior block.
I don't know, but I prefer some explanations or code about what is wrong...
Date: 26 Jan 2012 12:08:18
Message: <4f218882@news.povray.org>
Thomas de Groot escreveu:
ugh, sorry.  I previously saw the picture from my small smartphone
screen.  Looking now, it's sure he uses ior > 5.
Date: 26 Jan 2012 15:55:01
Message: <web.4f21bcf978f75b11e04b7a3c0@news.povray.org>
Excuse me for the missing explanation here, but I posted something in the bug
reports group. Ior is 1.41 in both images (I'm not a complete fool though :) ),
but the thing that disturbs me is that conserve_energy does not seem to work
correctly in combination with fade_color. Is this a known issue or has nobody
tried it before? Or is there probably a workaround or something else to achieve
the desired effect?
Regards Florian
Date: 26 Jan 2012 20:05:27
Message: <4f21f857$1@news.povray.org>
Am 26.01.2012 21:52, schrieb Florian Siegmund:
> the desired effect?
Well, it would have been helpful to *see* your full material statement
but anyway for dielectrics like glass something like this has always
worked for me:
#macro Dielectric (COLOR, IOR, TRANSLUCENCY)
   material {
       pigment {rgb COLOR filter 1}
       finish {
         ambient 0  diffuse 0
         reflection {0,1 fresnel on} conserve_energy
     interior {
       ior IOR
       fade_power 1001
       fade_distance TRANSLUCENCY
       fade_color rgb <pow(COLOR.red,3),
		      pow(COLOR.green,3),
		      pow(COLOR.blue,3)>
note that this "fade_power 1001" statement is an old (and really dirty
as it lacks any logic) hack that is part of POV-Ray since ages to turn
realistic fade power calculation on.
The value for TRANSLUCENCY depends on your general scene scale and just
to mention it: make sure your max_trace_level is high enough for all the
internal bounces.
-Ive
Date: 27 Jan 2012 16:00:01
Message: <web.4f230fa178f75b117f9181390@news.povray.org>
> worked for me:
>    material {
>      texture {
>        finish {
>          ambient 0  diffuse 0
>      interior {
>        ior IOR
>        fade_power 1001
>         pow(COLOR.green,3),
>         pow(COLOR.blue,3)>
> #end
> internal bounces.
> -Ive
This is the full material statement I used for the bowl,
max_trace_level = 20 (I already know the trick with "fade_power 1001", thank you
anyway!):
    material {
            pigment {color rgbf 1}
            finish {
                ambient 0
                diffuse 0
                reflection {1  fresnel}
                conserve_energy
        interior {
            ior 1.41
            fade_color color rgb <0, 0.15, 0.02>
            fade_power 1001
            fade_distance 1
It's almost similar to the one you posted, the only thing I did differently is
the pigment. I don't want really "colored" glass, rather clear glass like this
one: http://www.indigorenderer.com/materials/materials/1026
I did another render with reduced fade_distance so you can better see what
disturbs my eye..
Florian
Download 'glass_bowl_dark.jpg' (462 KB)
Preview of image 'glass_bowl_dark.jpg'
Date: 29 Jan 2012 11:35:01
Message: <web.4f25746d78f75b117713244c0@news.povray.org>
*absorbing media* are the magic words. Although I'm not sure if it uses a
physically correct distance formula, the material looks better now.
Florian
Download 'glass_bowl_media.jpg' (247 KB)
Preview of image 'glass_bowl_media.jpg'
Date: 29 Jan 2012 19:35:14
Message: <4f25e5c2$1@news.povray.org>
Am 27.01.2012 21:58, schrieb Florian Siegmund:
> disturbs my eye..
Those artifacts look weird indeed.
Could it be that you have some coincident-surfaces problem? Is the
bottom of the bowl's "foot" coincident with the plane on which it sits?
If so, the artifacts aren't all that surprising, and lifting the bowl a
bit off the plane should solve the issue.
Date: 30 Jan 2012 03:29:10
Message: <4f2654d6$1@news.povray.org>
This is looking very good. No artefacts.
Date: 30 Jan 2012 11:10:01
Message: <web.4f26c04078f75b111fea7c900@news.povray.org>
No coincident surfaces, as far as I know. I am aware of this 'resident evil' and
I fight it wherever I can :)
The only thing I still have to work on is the bowl's curvature. At the touching
points of some csg objects the surface doesn't look smooth and flowing yet; the
refraction still looks a bit 'broken' in certain areas - between the rim and the
'body', for instance.
Florian
Date: 30 Jan 2012 11:30:01
Message: <web.4f26c57c78f75b1178641e0c0@news.povray.org>
I like absorbing media because it makes more intuitive sense to me how it
relates to physical reality.  (I have trouble making sense of fade_color.)
The problems are that absorbing media are slower and (ironically to your
experience) I find them prone to artifacts.
