Hi all, over the last couple of days I've been playing with photons again; going
for something like a moving "swimming pool" caustics effect.
Somehow I ended up with this idea for rendering a short HD animation of photon
caustics emanating from 3 colored "water" blocks - here are some "time-lapse"
stills (I should have the final HD version posted on Vimeo tomorrow).
Cheers,
Rob
www.McGregorFineArt.com
Download 'rgbwaterblocks.jpg' (232 KB)
Preview of image 'rgbwaterblocks.jpg'
> "Robert McGregor"<rob### [at] mcgregorfineart com> wrote:
>> Thomas de Groot<tenDOTlnDOTretniATtoorgedDOTt> wrote:
>>> This would indeed be excellent for a swimming pool scene or any shallow
>>> water one of course. I like it.
>>> Thomas
>> Thanks Thomas :)
>> My animation is now available on Vimeo, here:
>> http://vimeo.com/34064748
>> Happy Holidays!
> Excellent, would it be possible to get an idea of your settings and rendertime
> for a frame?
> I have many troubles to find acceptable settings for caustics.
You don't use the caustics keyword, but photons.
You start with a realistic ior, like 1.333 for water or 1.5 for some
average glass. You may add some dispersion if you are ready for the
added time requirement.
Then, it's just a case of shooting enough photons at your objects.
A photons block in the global_settings.
A photon block for the relevent objects, here, you need something like:
photons{target refraction on collect off}
You don't need any photons block for the lights as they all have
photons{refraction on reflection on} by default except for shadowless
ones. An area_light may need photons{area_light}.
NO photons block on the objects that receive the photons.
> for a frame?
I used pretty high radiosity settings, an area light, EXR environment, and focal
blur (mostly for antialiasing) and was getting a render time of ~4min/frame
@1280x720px on my i7 with 8 render threads, but here is the bare bones scene
code for just the aqua water box:
#version 3.7
background { rgb 0.5 }
global_settings {
assumed_gamma 1
max_trace_level 20
radiosity {
photons { spacing 0.02 }
location vnormalize(<-6, 8, -9>)*100
look_at <-20, 10, 0>
angle 55
rotate <0, 20, 0>
light_source { <20, 30, 15> rgb 1
area_light <1, 0, 0>, <0, 0, 1>, 6, 6
orient
circular
area_illumination on
fade_distance 20
fade_power 2
// floor
plane { y, 0 hollow pigment { srgb <236,220,196>/255 } }
// aqua box
box { -0.5, 0.5
scale <10, 20, 5>
rotate <110, 90, 0>
translate <10, 15, 17>
pigment { rgbt 1 }
normal {
bozo
scale 1
turbulence 0.5
bump_size 2
finish { specular 0.2 roughness 0.2
reflection { 0, 1 fresnel on } conserve_energy }
interior { ior 1.33
fade_color srgb <223,248,255>/255
fade_power 1001
fade_distance 1
photons {
target
refraction on
reflection on
collect on
