"Eriban" <pov### [at] spamgourmet com> wrote:
> Attached is a new version, updated to take into account various comments
> Cheers,
> Erwin
Nifty - It started out very nice and got even better. Now you're entering the
phase I often have the most trouble with myself - deciding when to stop tweaking
and just declare it DONE. ;-)
(You're already guaranteed a success in any case.)
Best Regards,
Mike C.
Hi all,
I am much humbled by the praise on the latest version of the image. I am happy
to hear that the changes are indeed considered improvements and that the
resulting image is to your liking. :-)
I won't have much time over the next couple of weeks to work on the image, but
when I have the time, I will apply the necessary finishing touches. In
particular, I need to refactor it to cut down the rendering time.
Meanwhile, please find below my responses to specific comments and suggestions.
Alain <aze### [at] qwerty org> wrote:
> For your fog, are you using a media? Use a simple fog instead. fog is
> much faster than media, and in this case, should be a very good alternative.
Unfortunately, simple fog does not work here because of the way I achieved the
illusion. Not all objects are at the distance they seem to be. However, I
started faking the fog by putting up a transparent screen with varying
transparancy and that seems to work. It achieves the desired fade out and
renders faster.
Thomas de Groot <tenDOTlnDOTretniATtoorgedDOTt> wrote:
> One comment though (forgive me!).
No problem, comments are always welcome.
> If you move the sun a tiny bit so that
> the shadow of the leftmost column falls behind the central column, the
> illusion will be even better I believe.
I see what you mean, however, I am not sure if shifting the light is the best
way. I would like to leave sufficient room between the shadows of the pillars.
Also, I quite like how the front wall does not fully cast a shadow on the base
of the frontmost pillar. Nevertheless, I will see what I can do to improve the
illusion.
Christian Froeschlin <chr### [at] chrfr de> wrote:
> As Alain mentioned, using media may be overkill for this kind of fog.
> Apart from that, it might be possible to cut up the grass object into
> one part that interacts with the rest of the scene (monument shadow)
> and another part that doesn't, and use light_group's to restrict
> the use of the area light to the part that needs it.
Ah, I did not know about the light group feature, but that should do the job
perfectly. I will definitely try this. Thanks for the suggestion.
Well, the main tweaking I cannot avoid is refactor the scene to get bearable
render times. It currently takes nearly 8 minutes on my machine to render a
single line of the anti-aliased 640x800 image, which is way too much, especially
given the fact that I want to render it at 2400x3200.
"gregjohn" <pte### [at] yahoo com> wrote:
> I think the coolest improvement is the shadow inside the structure; it removes
> focus from what I thought was the biggest flaw: the way the round part abruptly
> changes from the straight about mid-height.
This transition from round to straight is actually not as abrupt as it seems.
The transition starts pretty much at the bottom of the pillars and continues all
the way up to the top. However, I fully agree, that's not how it appears.
Cheers,
Erwin
Final update: For those interested, please find attached the final version of
this image, properly anti-aliased. I managed to get the rendering time down to
acceptable levels (2400x3600 in just under 24 hours). Two things did the trick.
The use of a light_group to avoid using an area light for the top part of the
image resulted in a significant speed up. Secondly, I noticed that I had been
using non-default anti-aliasing settings. I cannot remember changing it, but
restoring the threshold from 0.1 to 0.3 really helped, especially the parts of
the scene where rendering had slowed down to a crawl.
Once again thanks for all suggestions. These definitely helped to improve the
image.
Cheers,
Erwin
Download 'failure-1_10.jpg' (280 KB)
Preview of image 'failure-1_10.jpg'
> image.
> Cheers,
> Erwin
Very nice indeed. Thanks for sharing the image and its development with us.
Best Regards,
Mike C.
