>SharkD on date 24/06/2011 06:30 wrote:
> Changed the way the panels are done, added some details.
Ok, where can we buy the tickets?
Paolo
Le 2011/06/24 00:32, SharkD a écrit :
> On 6/23/2011 11:49 PM, Alain wrote:
>> The fuel tanks for the attitude thrusters are relatively small as they
>> are relatively rarely used, and for only short times. They can logicaly
>> be located inside the outer shell.
>> Get rid of the solar pannels? Why?
>> Solar energy is the ONLY resource that is not scarse up there. You want
>> to get as much of it as possible. For that reason, I think that the
>> solar pannels sould be at least 10 to 100 times larger.
>> Having extra energy allows for beter recycling of the air and water,
>> improve food production and greatly helps producing the manufactured
>> goods you need. It can also help with your trusters by using ion based
>> thrusters or chimical thrusters fitted with some overheating device to
>> greatly increase ejection speed, and thus, get more thrust from the same
>> amount of propellant. Use smaller fuel storage, and make it last much,
>> much longer.
>> Alain
> Well, I just thought both a reactor and solar panels were a bit redundant.
In space, redundancy is an absolute must!
If you must shut down the reactor for any reason, you realy do need some
other power source. The solar pannels will support the station during
that time.
If the solar pannels are damaged, the reactor will take the relay.
Then, you have some fuel cells and some alternate, emergency, power sources.
You need fuel for the reactor, that fuel must be imported = bad. The
solar pannels never need any fuel =good.
The reactor need to be able to support all of the station's power needs,
and the same old true for the solar pannels.
> that time.
> sources.
> Alain
OK, awesome! I feel better!
Mike
http://isometricland.com
I made the living area about 75% bigger.
Download 'gh_scene_spinner_cutaway_temp_013.jpg' (141 KB)
Preview of image 'gh_scene_spinner_cutaway_temp_013.jpg'
I like the new panels, definitely an improvement. Are you planning on doing a
render with radiosity or are the areas that are totally black intended to stay
that way? (I think it looks good how it is but am curious as to how it would
look with radiosity on.)
I was planning on giving it a try. I think I will do that now.
Mike
Here's a quick render with radiosity turned on. Note that the white
background was added by XnView not POV-Ray. The original had an alpha
channel before conversion to JPG.
Download 'gh_scene_spinner_cutaway_temp_016.jpg' (113 KB)
Preview of image 'gh_scene_spinner_cutaway_temp_016.jpg'
Am 24.06.2011 06:30, schrieb SharkD:
Looks like the thrusters will now be able to cope with every attitude
problem.
Some more tweaks.
Download 'gh_scene_spinner_cutaway_temp_021.jpg' (191 KB)
Preview of image 'gh_scene_spinner_cutaway_temp_021.jpg'
Made it narrower, and took the image from a higher angle.
Download 'gh_scene_spinner_cutaway_046_2400_text.jpg' (797 KB)
Preview of image 'gh_scene_spinner_cutaway_046_2400_text.jpg'
