POV-Ray : Newsgroups : povray.binaries.images : Spinner scene, continued Server Time
22 Apr 2026 08:28:49 EDT (-0400)
  Spinner scene, continued (Message 31 to 40 of 43)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Spinner scene, continued
Date: 23 Jun 2011 23:49:20
Message: <4e040940$1@news.povray.org>
Le 2011/06/23 20:07, SharkD a écrit :
> On 6/23/2011 7:03 PM, clipka wrote:
>> Am 23.06.2011 23:53, schrieb SharkD:
>>> Exterior view. Not very exciting.
>> The attitude control system lacks thrusters tangential to the cylinder,
>> to stabilize the station with regard to axial rotation.
> Yeah. Not sure where to put the fuel tanks for the thrusters then though.
> Also, I want to add a reactor for the lamp lighting the station. What
> should it look like, and should I get rid of the solar panels?
The fuel tanks for the attitude thrusters are relatively small as they
are relatively rarely used, and for only short times. They can logicaly
be located inside the outer shell.
Get rid of the solar pannels? Why?
Solar energy is the ONLY resource that is not scarse up there. You want
to get as much of it as possible. For that reason, I think that the
solar pannels sould be at least 10 to 100 times larger.
Having extra energy allows for beter recycling of the air and water,
improve food production and greatly helps producing the manufactured
goods you need. It can also help with your trusters by using ion based
thrusters or chimical thrusters fitted with some overheating device to
greatly increase ejection speed, and thus, get more thrust from the same
amount of propellant. Use smaller fuel storage, and make it last much,
much longer.
Date: 24 Jun 2011 00:31:16
Message: <4e041314@news.povray.org>
Changed the way the panels are done, added some details.
http://isometricland.com
Download 'gh_scene_spinner_cutaway_044_2400_text.jpg' (895 KB)
Preview of image 'gh_scene_spinner_cutaway_044_2400_text.jpg'
Date: 24 Jun 2011 00:32:37
Message: <4e041365$1@news.povray.org>
> much longer.
> Alain
Well,  I just thought both a reactor and solar panels were a bit redundant.
Date: 24 Jun 2011 04:28:00
Message: <4e044a90$1@news.povray.org>
Ok, where can we buy the tickets?
Paolo
Date: 24 Jun 2011 17:22:46
Message: <4e050026@news.povray.org>
>> much longer.
>> Alain
In space, redundancy is an absolute must!
If you must shut down the reactor for any reason, you realy do need some
other power source. The solar pannels will support the station during
that time.
If the solar pannels are damaged, the reactor will take the relay.
Then, you have some fuel cells and some alternate, emergency, power sources.
You need fuel for the reactor, that fuel must be imported = bad. The
solar pannels never need any fuel =good.
The reactor need to be able to support all of the station's power needs,
and the same old true for the solar pannels.
Date: 24 Jun 2011 22:25:12
Message: <4e054708$1@news.povray.org>
> that time.
> sources.
> Alain
OK, awesome! I feel better!
Mike
Date: 24 Jun 2011 22:26:19
Message: <4e05474b@news.povray.org>
I made the living area about 75% bigger.
Download 'gh_scene_spinner_cutaway_temp_013.jpg' (141 KB)
Preview of image 'gh_scene_spinner_cutaway_temp_013.jpg'
Date: 25 Jun 2011 01:15:07
Message: <web.4e056e51a93c74e4988b44580@news.povray.org>
I like the new panels, definitely an improvement. Are you planning on doing a
render with radiosity or are the areas that are totally black intended to stay
that way? (I think it looks good how it is but am curious as to how it would
look with radiosity on.)
Date: 25 Jun 2011 13:20:51
Message: <4e0618f3$1@news.povray.org>
I was planning on giving it a try. I think I will do that now.
Mike
Date: 25 Jun 2011 14:32:49
Message: <4e0629d1@news.povray.org>
Here's a quick render with radiosity turned on. Note that the white
background was added by XnView not POV-Ray. The original had an alpha
channel before conversion to JPG.
Download 'gh_scene_spinner_cutaway_temp_016.jpg' (113 KB)
Preview of image 'gh_scene_spinner_cutaway_temp_016.jpg'
