POV-Ray : Newsgroups : povray.binaries.images : Untitled S.F. [W.I.P] take 2 Server Time
17 Mar 2026 17:14:15 EDT (-0400)
  Untitled S.F. [W.I.P] take 2 (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Untitled S.F. [W.I.P] take 2
Date: 31 May 2011 11:59:10
Message: <4de5104e$1@news.povray.org>
On 31/05/2011 7:15, RobF wrote:
> Hi Anthony,
> Since your planet is far away, you may also want to consider using the aoi
> pattern to fake an atmospheric glow. Although it doesn't give that soft/hazy
> look, it renders very fast.  Here's a code snippet and an example of what it
> looks like (with the USS Enterprise, of course! :-)
you could give it a soft/hazy look, even with some atmospheric
discoloration near the terminator:
--- START CODE ---
#version 3.7;
global_settings {
   assumed_gamma 1
#local SunLocation=<500,300,200>*1000;
   location -z*3
   look_at 0
light_source {
   SunLocation
   rgb <1.5,1.4,1.3>
// the planet itself
sphere {0,1 pigment {crackle solid scale .1} finish {ambient 0}}
//the atmosphere
#local Atmosphere=<.4,.5,.9>;
sphere {
   0,1
     pigment_pattern {
       slope {point_at SunLocation}
       pigment_map {
         [.5 rgb 1]
         [1 rgb 0]
     poly_wave 2
     pigment_map {
       [.5
         pigment_pattern {
           pigment_pattern {aoi color_map {[0 rgb 1][.5 rgb 0][1 rgb 1]}}
           color_map {
             [0 rgb 0]
             [.15 rgb 1]
             [.5 rgb 0]
         color_map {
           [0 rgb Atmosphere transmit 1]
           [1 rgb .25+Atmosphere transmit .35]
         poly_wave 2
       [1
         pigment_pattern {
           color_map {
             [0 rgb 0]
             [.15 rgb 1]
             [.5 rgb 0]
         color_map {
           [0 rgb 1-Atmosphere transmit 1]
           [1 rgb .25+(1-Atmosphere) transmit .35]
         poly_wave 2
   finish {diffuse 1 ambient 0}
   scale 1.02
--- END CODE ---
(It's the technique I used in my Babylon-video)
cu!
ZK
Date: 31 May 2011 14:35:01
Message: <web.4de533c3d55febdd9c4fb0ad0@news.povray.org>
> Nice.
> I am still surprised at the render time. My planets with the given *Tek
> atmosphere*, render in less than an hour....
> Thomas
I'm going to guess that your planets are all unit spheres, or not much bigger.
My planet has a radius of 63730 units: 1 unit = 100m, the atmosphere is 1000
units - 100 scale km - thick (density varies appropriately, 99% is below 36km,
50% is below 5.5km).  I'm not terribly concerned about the render time, although
it would be impossible to animate.
As for it being flat and textureless: It isn't.  The planet is a combination of
isosurfaces, one for land, one for ocean, and the water is my best water texture
yet (although I did remove the dispersion).
So, maybe it's a bit overkill, but I like it.
I appreciate all the advice, it's been very helpful.
A.D.B.
Date: 31 May 2011 18:33:08
Message: <4de56ca4@news.povray.org>
Am 31.05.2011 20:30, schrieb Anthony D. Baye:
> "Thomas de Groot"<tDOTdegroot@interDOTnlANOTHERDOTnet>  wrote:
>> Nice.
>> Thomas
Note that absolute scale doesn't affect render time.
With a density distribution like that, you'll probably be able to reduce
your render time by clipping the atmosphere at 36 km or even less
without any noticeable impact (except for a good deal of render speedup
Uh... given the scales you are using, are you sure you need the
isosurfaces? I guess a bump map should do the job just as well.
Heh, yeah. I know that feeling :-)
Date: 31 May 2011 20:24:54
Message: <4de586d6$1@news.povray.org>
"RobF" <nomail@nomail> wrote in message
news:web.4de47962d55febdd7ab7c0b80@news.povray.org...
> Hi Anthony,
> soft/hazy
> it
> #declare p_planet_atmosphere =
>      pigment {rgbt <0.5,0.5,0.5,0.5>}; // adjust transparancy component to
> change atmospheric translucency
> #declare p_planet_atmosphere_glow =
>    pigment {rgb <0.9,0.95,1>*1.8}; // atmospheric glow
> pigment {
>  aoi
>  pigment_map {
>  [0.5 p_planet_atmosphere_glow]
>  [0.7 p_planet_atmosphere]
> #declare t_planet_atmosphere =
>      texture {pigment {p_planet_atmosphere}
>              finish {ambient 0}
>    union {
>      sphere {0,3   texture {T_Stone22  finish {phong 0 ambient 0
> reflection 0}}
> }  // planet surface
>      sphere {0,3.0001 texture {t_planet_atmosphere}}
>   // planet atmosphere
> // need a bright light to make it glow
> Rob.
> Rob Fitzel
> www.fitzel.ca/dart
That background media looks amazing!  Is there any chance you could share
that code snippet too?  I've been struggling getting a nice looking cloud
like that.
Thanks!
Cheers Dre
Date: 1 Jun 2011 02:00:10
Message: <web.4de5d4d4d55febdd7ab7c0b80@news.povray.org>
> like that.
> Thanks!
> Cheers Dre
Thanks for the feedback.
I've posted a prototype of my Space Scene Generator in povray.text.scene-files
It should draw the same background as my sample image. The nebulae are built-in
stone/granite textures mapped onto a couple of concentric sphere centered on the
camera.
All the elements in that scene are controlled by random seeds. It took more than
a few tries before I got a nebula that I liked! See the comments in the scene
file to learn how to modify the random seeds. It renders very quickly, so I
usually base the main randomizer on "clock" to render dozens of completely
different random scenes.
Cheers,
Rob.
Rob Fitzel
www.fitzel.ca/dart
Date: 1 Jun 2011 03:05:01
Message: <web.4de5e372d55febdd57c642360@news.povray.org>
Well, it *looks* flat and textureless. And that's what it comes down to after
all, isn't it?
Isosorfaces for the planet? Seriously?
If you enjoy waiting 14+ hours for a render that *looks* like a 30 seconds
render: Go ahead! :D
Date: 1 Jun 2011 03:39:18
Message: <4de5eca6$1@news.povray.org>
"Anthony D. Baye" <Sha### [at] spamnomorehotmailcom> schreef in bericht
news:web.4de533c3d55febdd9c4fb0ad0@news.povray.org...
> combination of
> texture
Yes it is overkill. I would suggest using a spherical height_field (which I
use) if you really want some relief to show.
Date: 1 Jun 2011 03:57:05
Message: <4de5f0d1$1@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> schreef in bericht
news:4de5104e$1@news.povray.org...
Excellent code! Thanks for sharing.
Date: 1 Jun 2011 04:12:34
Message: <4de5f472@news.povray.org>
"RobF" <nomail@nomail> schreef in bericht
news:web.4de5d4d4d55febdd7ab7c0b80@news.povray.org...
Great stuff! Competes successfully with ChrisColefax's galaxy.inc.
Keep up the work.
Date: 1 Jun 2011 18:16:47
Message: <4de6ba4f@news.povray.org>
>> like that.
>> Thanks!
>> Cheers Dre
> built-in
> on the
> camera.
> more than
> scene
> I
> Cheers,
> Rob.
> Rob Fitzel
> www.fitzel.ca/dart
Thats great, thanks very much!
I'll certainly be playing around with this :)
Cheers Dre
