"jhu" <nomail@nomail> wrote:
> No time for complex images anymore. Simple ones will do for now.
Sometimes simple images are the best. This looks good.
The thimble does look like it is floating or detached from the image. Perhaps
not enough shadow at the base. I assume you are using radiosity, bump down the
diffuse setting on it's material perhaps and rely more on reflective properties.
The wood table top, is it a procedural texture or an image map? If it's
procedural, I'd like to know the coding.
-tgq
Should the three dots not be a single one? The four and three are
supposed to be on opposite sides.
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
Subject: Re: Board game
Date: 28 Mar 2011 05:45:19
Message: <4d9058af$1@news.povray.org>
Nice image! Great wood. Did you model the board texture
as well? The text looks strangely 3d-ish where it is blurred.
Maybe also try a less symmetrical view of the board?
