POV-Ray : Newsgroups : povray.binaries.images : Underwater air bubbles Server Time
24 Jun 2025 00:37:36 EDT (-0400)
  Underwater air bubbles (Message 1 to 10 of 32)
Subject: Underwater air bubbles
Date: 23 Mar 2011 20:50:01
Message: <web.4d8a94d263bfe2d8e1fc6c440@news.povray.org>
High! :-)
This is just a quick test of an idea I had for underwater air bubbles.
There's a point set of 4D vectors containing bubble positions and sizes. For
each
bubble there is a blob. For each blob all other points are tested, and if
another
bubble comes close to the current bubble, a blob is subtracted from it. A
duplicate blob is also subtracted from underneath each bubble. Parse times
aren't
so horrible for low-count point sets (<250), and the render times aren't bad at
all.
The first part of the basic idea came from someone from these newsgroups, but I
can't remember who it was :(
The initial render (/the/ render) took less than 50 seconds with max_trace_level
set at 10. In-POV post-processing luminous bloom and chromatic aberration
effects
were applied. Textured fog was also used.
The arrangement of the bubbles was the hardest part, as there needs to be a
logical progression of large->small bubbles.
There's more that can be done, such as having the larger bubbles capsizing into
numerous smaller ones below, but I'm not quite sure how to script that yet...
~Sam
Download 'underwater-air-bubbles.jpg' (125 KB)
Preview of image 'underwater-air-bubbles.jpg'
Subject: Re: Underwater air bubbles
Date: 23 Mar 2011 21:55:01
Message: <web.4d8aa421c2e3e880b05ef170@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote:
> High! :-)
> each
> another
> aren't
> all.
> effects
> ~Sam
This looks very nice.  You were able to get that bubbles rushing to the surface
look, as opposed to suspended air bubbles that basic spheres look like.
-tgq
Date: 23 Mar 2011 22:52:34
Message: <4d8ab1f2@news.povray.org>
agreed ... a cleaver solution that's very natural looking.
Date: 23 Mar 2011 23:10:00
Message: <web.4d8ab548c2e3e8804f17b3b30@news.povray.org>
awesome!
something triggered inside you recently, huh?  non-stop stream of new ideas...
Date: 24 Mar 2011 04:11:58
Message: <4d8afcce$1@news.povray.org>
"Jim Holsenback" <jho### [at] povrayorg> schreef in bericht
news:4d8ab1f2@news.povray.org...
>> surface
I join the crowd.
Date: 24 Mar 2011 05:22:35
Message: <op.vsucbxkkufxv4h@go-dynamite>
On Thu, 24 Mar 2011 02:49:55 +0200, Samuel Benge <stb### [at] hotmailcom>
wrote:
> High! :-)
> For
> each
> another
> times
> aren't
> bad at
> all.
> newsgroups, but I
> max_trace_level
> effects
> be a
> capsizing into
> yet...
> ~Sam
Wow!
-Nekar Xenos-
Date: 24 Mar 2011 10:50:00
Message: <web.4d8b5919c2e3e88055226b1c0@news.povray.org>
hi:
Only two words: Hall Of Fame!
B. Gimeno
Date: 24 Mar 2011 11:16:30
Message: <4d8b604e$1@news.povray.org>
Le 24/03/2011 15:45, B. Gimeno a écrit :
> hi:
Two words... then you mean: "Hollow Foam", right ?
It must be the water in my ears. Or the bubbles...
Really great!
Date: 24 Mar 2011 14:18:36
Message: <4d8b8afc@news.povray.org>
Thanks. It's getting there...
Date: 24 Mar 2011 14:21:14
Message: <4d8b8b9a$1@news.povray.org>
> hi:
> B. Gimeno
That's 3 words...
Great iamge.
