POV-Ray : Newsgroups : povray.binaries.images : Underwater air bubbles Server Time
22 Apr 2026 08:19:21 EDT (-0400)
  Underwater air bubbles (Message 11 to 20 of 32)
Subject: Re: Underwater air bubbles
Date: 24 Mar 2011 14:22:24
Message: <4d8b8be0$1@news.povray.org>
On 3/23/2011 7:52 PM, Jim Holsenback wrote:
> On 03/23/2011 10:53 PM, Trevor G Quayle wrote:
>> This looks very nice. You were able to get that bubbles rushing to the
>> surface
>> look, as opposed to suspended air bubbles that basic spheres look like.
> agreed ... a cleaver solution that's very natural looking.
I originally tried to use the technique for in-air soap bubbles, but the
inside edges were too thick. Too bad there's not an easier way to model
minimal surfaces...
Date: 24 Mar 2011 14:24:06
Message: <4d8b8c46$1@news.povray.org>
Looks sweet, how is it lit?
> For each blob all other points are tested
if you really mean "all other points", you could probably
optimize this for a large number of bubbles by sorting vertically
in n log(n) time ... so unfortunately no bubble sort :D (*groan*).
Then you only need to test points up to a maximum y distance. Of
course such information might already be available depending how
you generate your points in the first place.
Date: 24 Mar 2011 14:26:41
Message: <4d8b8ce1@news.povray.org>
On 3/23/2011 8:06 PM, nemesis wrote:
> awesome!
> something triggered inside you recently, huh?  non-stop stream of new ideas...
Thanks!
Part of the reason for my increased frequency of postage comes from this
foul weather :/
Date: 24 Mar 2011 14:27:48
Message: <4d8b8d24$1@news.povray.org>
On 3/24/2011 7:45 AM, B. Gimeno wrote:
> hi:
> Only two words: Hall Of Fame!
Thanks, but it's not really a finished scene, just an idea. I wonder
what might be making the bubbles...
Date: 24 Mar 2011 14:29:37
Message: <4d8b8d91$1@news.povray.org>
On 3/24/2011 8:16 AM, Le_Forgeron wrote:
> Le 24/03/2011 15:45, B. Gimeno a écrit :
>> hi:
> Two words... then you mean: "Hollow Foam", right ?
That's funny, since I was originally trying to make foam with this
method. It worked, but not well :(
> It must be the water in my ears. Or the bubbles...
> Really great!
Date: 24 Mar 2011 14:29:57
Message: <4d8b8da5$1@news.povray.org>
On 3/24/2011 1:11 AM, Thomas de Groot wrote:
> "Jim Holsenback"<jho### [at] povrayorg>  schreef in bericht
> news:4d8ab1f2@news.povray.org...
>>> surface
> I join the crowd.
Date: 24 Mar 2011 14:40:01
Message: <web.4d8b8fd7c2e3e88081c811d20@news.povray.org>
> >> surface
> minimal surfaces...
For soap bubbles in the air, usually the bubble surface is thin enough that any
refraction is not noticeable.  I am thinking you could just use the blob, but
without refraction or ior, however this would preclude being able to use fresnel
reflection.
-tgq
Date: 24 Mar 2011 14:44:28
Message: <4d8b910c$1@news.povray.org>
The scene is only lit with a sky_sphere; that's why it rendered so quickly.
This might just work, because the points /are/ created in vertical
succession.
Even better yet would be Voronoi evaluation for all points, then I'd
know the nearest neighbors. Unfortunately, Voronoi calculations for
point sets are still beyond my capabilities :(
The biggest problem I'm having now is choosing when to subtract a
bubble, and when not to. If a bubble resides inside another one, it
currently subtracts that bubble. I need to maybe *add* that inside
bubble, not subtract it.
Date: 24 Mar 2011 15:06:43
Message: <4d8b9643@news.povray.org>
>>>> surface
>> minimal surfaces...
> reflection.
Let's see... I used separate blobs for each bubble and one blob for a
thin film over everything. The latter had a very slight ior. The real
problem was the blobs were making edges that were too rounded. This
might be helped with better neighbor evaluation.
Attached is an image showing how it was turning out. It's not too bad,
better than no bubbles at all I suppose ;)
Sam
Download 'bubbles1.png' (49 KB)
Preview of image 'bubbles1.png'
Date: 24 Mar 2011 16:19:37
Message: <4d8ba759$1@news.povray.org>
Am 24.03.2011 19:27, schrieb stbenge:
>> hi:
I guess maybe I... DON'T WANT TO KNOW! >_<
