POV-Ray : Newsgroups : povray.binaries.images : Multi-pass rendering and compositing in POV-Ray Server Time
1 Jan 2026 06:06:14 EST (-0500)
  Multi-pass rendering and compositing in POV-Ray (Message 21 to 28 of 28)
Subject: Re: Multi-pass rendering and compositing in POV-Ray
Date: 11 Mar 2011 03:23:49
Message: <4d79dc15@news.povray.org>
Am 09.03.2011 17:09, schrieb nemesis:
> But really, this is why pov-ray never quite gets much of a foothold:  only
> ingenious guys like you, Sam Benge, Jaime Vives Piqueres and a host of others to
> imagine such tricks.
Actually I think the main reason is simply that POV-Ray does things
differently than all those mesh-and-shader renderers out there.
> it is a well known fact that the multipass approach
> is the way to go and that radiosity does not play fine with reflections,
> refractions, media and now SSS.
Well known maybe - but I doubt that it is a fact. The multipass approach
has its limitations; for instance. AO breaks down for indoor scenes.
When it comes to CG movies, a multipass approach is no doubt a crucial
timesaver, and the action hides the flaws rather easily; but for stills
I'm sure it's not a cure-all.
> So, how about a multipass switch for povray, devs?  I mean, sure there's the
> quality switches going from 1 (plain constant ambient light) to 9 (full with
> radiosity), but the numbers going higher only add more effects, don't isolate
> them from one another.
This thread already spawned some background process in my brain :-) (Of
course don't expect any such thing to appear in the very next release -
I'm not /that/ fast :-P)
> I know it's a postprocess to combine the results and it
> is outside the scope of a raytracer,
I wouldn't really consider that postprocessing.
Date: 11 Mar 2011 05:35:00
Message: <web.4d79f9bd6b0cef9b9a1bcfb90@news.povray.org>
Only because its not true AO, just radiosity under an overcast sky. ;)
It's used in a bunch of radiosity HOF scenes to handle reflections without using
exponentially increased rendertimes and more radiosity artifacts (at least for
older radiosity)...
Also, it's not like as if povray wants to be a physically-based unbiased and
slow raytracer, is it?
http://t1.gstatic.com/images?q=tbn:ANd9GcQzbNX5-6wP4pyz32VitjtJt10WM47OzdGTJdqUcTiNIYpGCb83AA
Better yet. :)
Date: 12 Mar 2011 03:17:52
Message: <4d7b2c30$1@news.povray.org>
Am 11.03.2011 11:30, schrieb nemesis:
So what /is/ true AO? From the little I know it is an effect limited to
a single object, to account for self-shadowing to some degree. Which is
not needed in POV-Ray in the first place as it supports self-shadowing
out of the box - not to mention that the distinction between self- and
non-self shadowing would open up some definition problem as soon as CSG
enters the scene).
> older radiosity)...
Yup, 3.6 radiosity was indeed prone to artifacts when reflections were
involved, and those artifacts were virtually impossible to get rid of.
No such problem in 3.7 anymore, and the new radiosity importance
mechanism may be another useful tool to reduce render times in scenes
with much reflection.
Well, if /I/ am asked, I'd want POV-Ray to become a physically-based
unbiased and /fast/ raytracer :-P
Date: 12 Mar 2011 07:30:01
Message: <web.4d7b66326b0cef9b9a1bcfb90@news.povray.org>
I think you got that wrong.  It's not about self-shadowing, but about accounting
for geometry occluding light from close geometry, like a sphere on the floor
generating shadows on the floor and the floor generating shadows on the sphere.
It also doesn't take light setups into account at all, just how close geometry
is to each other.  That is, it's perfectly possible to have AO in-doors in a
closed room, under a ceiling which is not emitting light (as would be needed in
radiosity).  AFAIK, the calculations needed involve purely the normals between
surfaces, like the shadowing in the corners of rooms where 2 walls join and even
more when floor or ceiling join in as well...
> > older radiosity)...
That's awesome, no doubt!
That would be great.
Date: 12 Mar 2011 09:51:18
Message: <4d7b8866$1@news.povray.org>
> about accounting for geometry occluding light from close geometry,
> like a sphere on the floor generating shadows on the floor and the
> floor generating shadows on the sphere. It also doesn't take light
> setups into account at all, just how close geometry is to each other.
> That is, it's perfectly possible to have AO in-doors in a closed
> in radiosity).  AFAIK, the calculations needed involve purely the
> normals between surfaces, like the shadowing in the corners of rooms
> where 2 walls join and even more when floor or ceiling join in as
> well...
   You're right here... I've researched AO a bit some months ago, and it
is all based on a "distance" parameter. In packages supporting AO, for
indoors, usually you have to set that distance to something less that
the distance between the floor and ceiling.
   BTW, I usually don't like the effect of indoor AO... perhaps because
most people usually abuse it.
http://www.ignorancia.org
Date: 12 Mar 2011 11:05:01
Message: <web.4d7b99a06b0cef9b94d713cc0@news.povray.org>
> enters the scene).
Check out this SIGGRAPH 2008 presentation "Image-Space Horizon-Based Ambient
Occlusion" from nvidia that explains some variations of the process:
http://developer.nvidia.com/object/siggraph-2008-HBAO.html
www.McGregorFineArt.com
Date: 12 Mar 2011 11:20:01
Message: <web.4d7b9d276b0cef9b94d713cc0@news.povray.org>
That would be an awesome addition Christoph!
Date: 13 Mar 2011 17:30:01
Message: <web.4d7d368b6b0cef9b94d713cc0@news.povray.org>
I've just uploaded to p.b.s.f. a code sample that demonstrates my technique for
multipass rendering and compositing directly in POV-SDL.  It's a standard zip
file containing an example multipass scene and an associated compositing scene,
along with my multipass and compositing include files, so please try it for
yourselves. Any suggestions for improvement are certainly welcome.
Also, I made a screen capture video that shows the entire multipass/compositing
process from start to finish. Usually ray tracing is about as fun to watch as
paint drying but I recorded the six render passes at ~11x normal speed. So, it's
actually sort of fun to watch (and it makes me drool for when, a few years from
now, our computers will actually /be/ that fast). Actual render time for all 6
passes was just under 22 min.; the video is just under 3 min.
The compositing part at the end is recorded at normal speed, so you can see the
compositing in real time, which is only a few seconds each. Well, except for the
depth pass; that takes a bit longer because it uses my auto-contrast macro to
loop through all the pixels of the depth pass image to find the darkest &
lightest pixels, and then makes those values 0 and 1 respectively, stretching
the mid tones to fit via linear interpolation. It took 35 seconds for the entire
compositing process.
The video is here: http://vimeo.com/20987441
And here's the result of using the AutoContrast_Grayscale() macro on the depth
pass for my example.
Cheers,
Rob
Download 'autocontrast_grayscale.png' (769 KB)
Preview of image 'autocontrast_grayscale.png'
