clipka <ano### [at] anonymous org> wrote:
> Am 21.03.2011 14:37, schrieb Trevor G Quayle:
> > Ive<ive### [at] lilysoft org> wrote:
> >> You have some quite distracting color banding on the rear wall and you
> > I've noticed this. This looks like it is coming from the very dim 'fill'
> > lighting I am using along part of the projector beam. The light intensity is
> > right near the bottom of the colour depth so it tends to get stepped. I tried
> > it with HDR image type output and the banding disappears (converting the HDR
> > back to JPG or PNG reintroduces it). I may either have to adjust how I approach
> > this light, adjust the texturing to better mask it, or just get rid of it
> > completely.
> For a PNG file without colour banding, you may want to use dithered
> output (+TH). (You can also try it for JPG, though I'm not sure whether
> that will improve results.)
> Alternatively, you can convert the HDR or EXR output using Ive's "IC"
> ("Image Converter", see http://www.lilysoft.org/IC/ic_index.htm), which
> does a much better job at avoiding color banding than most other image
> manipulation/conversion software.
I tried the converter, the banding is still there. I may have a look at the
dithering.
-tgq
Am 21.03.2011 16:25, schrieb Trevor G Quayle:
Hum? Actually I can't believe that but it might be my own fault as I
never managed it to write a decent documentation.
In case you use IC for converting some HDR format to PNG it will store
the PNG in 16bps format (to avoid unnecessary loss of information) and
the banding will be introduced again when you use other viewing software.
So you have to reduce the color depth before you actually save the image
file by using the menu item
Image -> Mode -> RGB 8bps
- and make sure within the Options menu that dithering is actually enabled.
-Ive
> -Ive
Maybe a little RTFM on my part...
I do get it to work now. The problem was I didn't set to 8bit, but also I was
saving direct to jpg. I assume then that the dithering doesn't apply to jpg
saving?
-tgq
Am 21.03.2011 17:55, schrieb Trevor G Quayle:
saving?
Dithering works also with jpeg output but as jpeg is always lossy
and most of all the RGB -> YCbCr (the color space internal used by jpeg)
transformation is already lossy it might happen the the dithered color
falls exactly into a gap produced by rounding errors of the lossy color
space transformation, err, if you know what I mean, I'm not very good in
explaining such things.
First try it with the option chroma-subsampling (within the 'Save JPEG
Options' dialog) DISABLED and a quite high quality setting (lets say
95%) if this doesn't help you can try to change the exposure value (just
some barely visible amount increased or decreased) within the
Tonemapping dialog so the dithered colors might miss the 'gaps'.
-Ive
> saving?
> -Ive
It had to do with the quality settings for JPG. Was set to 90%, setting to 100%
works fine. I hadn't found where the settings were before, the Format Option
button was a bit inconspicuous I guess.
Very nice little program.
-tgq
> > > Am 20.03.2011 09:04, schrieb Thomas de Groot:
> > > > I don't see anything... Gamma?
> > > Looks more like an absolute brightness issue to me.
> > I have been having difficulty calibrating my home monitor, so this image was
> > visible to me at my previous settings.
> > I have tried to do some calibration, and I think I have my monitor gamma setting
> > way too high.
> > I'm going to have to try to figure some of this out, but it is difficult to find
> > a difinite source to help me get the settings correct.
> > -tgq
> Hopefully this is much better. I tried to do some calibration with my monitor.
> -tgq
Next update. I moved our guy to a different movie, changed the seat texture, I
changed all wall and roof textures to the same and added a light to the booth as
well.
-tgq
Download 'matineescene 5.jpg' (193 KB)
Preview of image 'matineescene 5.jpg'
> well.
Looking great!
If I were to offer one suggestion, it would be that all the movie theaters I've
been in have a glass window in the projection booth, and the movie, a bit out of
focus, can be seen projected on (or though I guess) the window.
> -tgq
Cheers,
Edouard.
>>> way too high.
>>> -tgq
>> -tgq
> well.
> -tgq
yep ... better seat texture (fabric) ... but maybe a tad too saturated
on the plastic, bloom is good though
> > well.
> Looking great!
> > -tgq
> Cheers,
> Edouard.
My next stage. I added the glass for the movie to project on. It isn't out of
focus, but the focal blur will hopefully take care of that. The screen image
and projector beam, is a point light behing a filtered image, so it ends up
being in focus the whole length. I would have to do some real tweaking to get a
true out-of-focus to focus projector beam. I adjusted the skin and seat
textures a bit and added a bit of radiosity (the screen image is excluded, as I
already have that as an area light array instead).
And just ignore that guy in the next row...
-tgq
Download 'matineescene 6.jpg' (165 KB)
Preview of image 'matineescene 6.jpg'
>>> well.
>> Looking great!
>>> -tgq
>> Cheers,
>> Edouard.
> -tgq
It's been fun watching the progression of things ... I like the irony of
Darth Vader watching a Star Wars movie ... nice touch!
