Am 21.03.2011 00:07, schrieb Trevor G Quayle:
> Hopefully this is much better.
Hmm, it *is* brighter but I'm not so sure about *better*.
You have some quite distracting color banding on the rear wall and you
are completely loosing the dim movie theater feeling here.
The main problems within your previous version seems to me: almost 50%
of the pixels are pitch black (rgb 0,0,0) and plain black pixels is
something that should (for photorealistic images) be avoided like the
plague.
Even within this brighter version are almost 25% pixels just black (the
upper walls, ceiling, the pylons, the speakers and parts below the seats).
On the over hand you are not using the full dynamic range which makes it
look somehow flat. There is no need to make it overall brighter but
there is some need for bright spots.
> I tried to do some calibration with my monitor.
See my 'Calibration' post, it might help.
-Ive
I've noticed this. This looks like it is coming from the very dim 'fill'
lighting I am using along part of the projector beam. The light intensity is
right near the bottom of the colour depth so it tends to get stepped. I tried
it with HDR image type output and the banding disappears (converting the HDR
back to JPG or PNG reintroduces it). I may either have to adjust how I approach
this light, adjust the texturing to better mask it, or just get rid of it
completely.
> plague.
There is a very good reason for this: durrently those particular parts have a
'rgb 0' pigment attached.
> -Ive
Helps a little. I think the big problem before was my monitor gamma was bumped
way too high. However the brightness setting is something I could not find a
lot of information on previously. When calibrating before and fixing the gamma,
I had bumped this right down (0%), but using your posting I have it somewhat
higher (40%).
-tgq
Am 21.03.2011 14:37, schrieb Trevor G Quayle:
> completely.
For a PNG file without colour banding, you may want to use dithered
output (+TH). (You can also try it for JPG, though I'm not sure whether
that will improve results.)
Alternatively, you can convert the HDR or EXR output using Ive's "IC"
("Image Converter", see http://www.lilysoft.org/IC/ic_index.htm), which
does a much better job at avoiding color banding than most other image
manipulation/conversion software.
> > completely.
I tried the converter, the banding is still there. I may have a look at the
dithering.
-tgq
Am 21.03.2011 16:25, schrieb Trevor G Quayle:
Hum? Actually I can't believe that but it might be my own fault as I
never managed it to write a decent documentation.
In case you use IC for converting some HDR format to PNG it will store
the PNG in 16bps format (to avoid unnecessary loss of information) and
the banding will be introduced again when you use other viewing software.
So you have to reduce the color depth before you actually save the image
file by using the menu item
Image -> Mode -> RGB 8bps
- and make sure within the Options menu that dithering is actually enabled.
-Ive
> -Ive
Maybe a little RTFM on my part...
I do get it to work now. The problem was I didn't set to 8bit, but also I was
saving direct to jpg. I assume then that the dithering doesn't apply to jpg
saving?
-tgq
Am 21.03.2011 17:55, schrieb Trevor G Quayle:
saving?
Dithering works also with jpeg output but as jpeg is always lossy
and most of all the RGB -> YCbCr (the color space internal used by jpeg)
transformation is already lossy it might happen the the dithered color
falls exactly into a gap produced by rounding errors of the lossy color
space transformation, err, if you know what I mean, I'm not very good in
explaining such things.
First try it with the option chroma-subsampling (within the 'Save JPEG
Options' dialog) DISABLED and a quite high quality setting (lets say
95%) if this doesn't help you can try to change the exposure value (just
some barely visible amount increased or decreased) within the
Tonemapping dialog so the dithered colors might miss the 'gaps'.
-Ive
> saving?
> -Ive
It had to do with the quality settings for JPG. Was set to 90%, setting to 100%
works fine. I hadn't found where the settings were before, the Format Option
button was a bit inconspicuous I guess.
Very nice little program.
-tgq
> > > Am 20.03.2011 09:04, schrieb Thomas de Groot:
> > > > I don't see anything... Gamma?
> > > Looks more like an absolute brightness issue to me.
> > I have been having difficulty calibrating my home monitor, so this image was
> > visible to me at my previous settings.
> > I have tried to do some calibration, and I think I have my monitor gamma setting
> > way too high.
> > I'm going to have to try to figure some of this out, but it is difficult to find
> > a difinite source to help me get the settings correct.
> > -tgq
> Hopefully this is much better. I tried to do some calibration with my monitor.
> -tgq
Next update. I moved our guy to a different movie, changed the seat texture, I
changed all wall and roof textures to the same and added a light to the booth as
well.
-tgq
Download 'matineescene 5.jpg' (193 KB)
Preview of image 'matineescene 5.jpg'
> well.
Looking great!
If I were to offer one suggestion, it would be that all the movie theaters I've
been in have a glass window in the projection booth, and the movie, a bit out of
focus, can be seen projected on (or though I guess) the window.
> -tgq
Cheers,
Edouard.
