POV-Ray : Newsgroups : povray.binaries.images : Matinee Server Time
22 Apr 2026 10:00:45 EDT (-0400)
  Matinee (Message 21 to 30 of 53)
Subject: Re: Matinee
Date: 10 Mar 2011 23:23:29
Message: <4d79a3c1$1@news.povray.org>
Am 09.03.2011 22:57, schrieb Trevor G Quayle:
> "Trevor G Quayle"<Tin### [at] hotmailcom>  wrote:
>> I was doing some tooling about with the latest lighting challenge from 3DRender
>> (http://forums.cgsociety.org/showthread.php?f=185&t=955407) which features a
>> movie theatre.  One of the maon aspects of lighting here will be that coming
>> from the screen.  I first started using radiosity with an image projected on the
>> screen, however it was becoming apparent that it may take some really high
>> quality settings to get good results.  I then though of using an array of area
>> lights created from the projector image. I had already done a lot of the
>> mathwork in my lightdome work, so I did some quick conversions to making a
>> planar version of it with some nice results.
>> In the attached image, the first part is radiosity with some low quality
>> settings.  The second is using the arealight array (16 area lights, 4x4 each).
>> -tgq
> Next stage is the projector lighting.  I think this is looking OK.  I don't have
> the screen area light applied, just a single point light to add a little bit of
> additional illumination.  This is the part where I was wondering about the light
> attenuation, realistically speaking, the brightness of the projector in the
> first 1/5 distance is a little too bright (~30%).
Of course you'll want fade_power 2. From my experience, fade_distance
should be roughly the light source size, so I'd try the equivalent of 35mm.
(I'm presuming assumed_gamma 1.0 here; for other gamma values, you'll
get nonsense results no matter what you do.)
I think the projector light is too bright in total, though of course it
all depends on how much dust you want in the air.
Date: 19 Mar 2011 13:15:00
Message: <web.4d84e377f5e1e8f8b05ef170@news.povray.org>
Some adjustments to my scene.  Tweaked the projector lighting a bit to get the
falloff I wanted, added just a touch of fill-type lighting from the projector
beam.  Adjusted the textures a little bit as well, added some specular to the
skin and a fine quilted texture to the seats.  I will probably try a different
seat texture as I don't have it uv mapped so it comes out with some moire-like
artifacting.
-tgq
Download 'matineescene-3.jpg' (96 KB)
Preview of image 'matineescene-3.jpg'
Date: 19 Mar 2011 18:09:23
Message: <op.vsl2h0zpufxv4h@xena>
On Sat, 19 Mar 2011 19:10:15 +0200, Trevor G Quayle
> get the
> projector
> to the
> different
> moire-like
> artifacting.
> -tgq
I like the lighting here.
-Nekar Xenos-
"The spoon is not real"
Date: 20 Mar 2011 04:04:13
Message: <4d85b4fd@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> schreef in bericht
news:web.4d84e377f5e1e8f8b05ef170@news.povray.org...
> the
> projector
> the
> different
> moire-like
> artifacting.
I don't see anything... Gamma?
Date: 20 Mar 2011 05:02:00
Message: <4d85c288$1@news.povray.org>
Am 20.03.2011 09:04, schrieb Thomas de Groot:
Looks more like an absolute brightness issue to me.
Date: 20 Mar 2011 15:20:01
Message: <web.4d865345f5e1e8f8b05ef170@news.povray.org>
I have been having difficulty calibrating my home monitor, so this image was
visible to me at my previous settings.
I have tried to do some calibration, and I think I have my monitor gamma setting
way too high.
I'm going to have to try to figure some of this out, but it is difficult to find
a difinite source to help me get the settings correct.
-tgq
Date: 20 Mar 2011 15:51:03
Message: <4d865aa7$1@news.povray.org>
> way too high.
> -tgq
To me the front row and projector beam are clearly visible if a bit
dark. If I adjust the gamma from 1 to 1.1 then the backsplash from the
projector beam becomes obvious as a circle of light on the back wall.
Regards
Date: 20 Mar 2011 19:10:01
Message: <web.4d868898f5e1e8f8b05ef170@news.povray.org>
> way too high.
> -tgq
Hopefully this is much better.  I tried to do some calibration with my monitor.
-tgq
Download 'matineescene-4.jpg' (160 KB)
Preview of image 'matineescene-4.jpg'
Date: 21 Mar 2011 03:53:39
Message: <4d870403$1@news.povray.org>
news:web.4d868898f5e1e8f8b05ef170@news.povray.org...
> monitor.
Oh yes! This looks *correct* to me. Good work.
Date: 21 Mar 2011 05:29:42
Message: <4d871a86@news.povray.org>
   Definitely.
It looks you at least calibrated it decently: the lighting level is now
what I would expect for such situation.
Jaime Vives Piqueres
http://www.ignorancia.org
