POV-Ray : Newsgroups : povray.binaries.images : Matinee Server Time
22 Apr 2026 13:52:10 EDT (-0400)
  Matinee (Message 14 to 23 of 53)
Subject: Re: Matinee
Date: 8 Mar 2011 16:05:01
Message: <web.4d769966f5e1e8f886ff1d480@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote:
> As for John Carpenter, not sure which legendary one as there are many (Escape
> from New York, They Live, Halloween)
"The Thing" for sure!
www.McGregorFineArt.com
Date: 8 Mar 2011 23:10:02
Message: <web.4d76fd57f5e1e8f8b05ef170@news.povray.org>
Download 'matineescene1thing1.jpg' (125 KB)
Preview of image 'matineescene1thing1.jpg'
Date: 8 Mar 2011 23:55:00
Message: <web.4d77077cf5e1e8f894d713cc0@news.povray.org>
> The 2nd Blade Runner scene you picked gives a nice effect, due to the
> difference in color between both left & right side.
I totally agree, the lighting is really nice and looks like maybe he should be
wearing those old-school red/blue 3d glasses. Maybe that's why he's so
enthusiastic, a cheesy 3d spear just came out of the screen at him or
something...
Date: 9 Mar 2011 10:35:01
Message: <web.4d779d20f5e1e8f881c811d20@news.povray.org>
> I guess the area lights array is the way to go for the primary
> illumination - though I'd suggest to not go without radiosity entirely,
> as I guess it might give an added touch.
Yes, I may add that in for some subtle addition, but remove the screen image
from affecting it directly.
> When using radiosity, don't forget that theaters typically use pretty
> dark materials. Looks like you're using some bright grey for now, which
> makes the radiosity scene unrealistically "light-flooded".
I am using my default diffuse white texture at present for light testing.  I
will add textures still.
> In case you want to give radiosity-only illumination another try, don't
> forget that you can prioritize objects: Use "radiosity { importance 1.0
> }" for the screen, and - say - "radiosity { importance 0.01 }" in the
> #default block, then crank up the global settings' radiosity count.
Hmm.  Is this a new addition?  Don't recall it from before.  Have to see how it
affects it maybe.  It may still be a bit of a problem, as the screen isn't a
small light source relative to the scene size.
-tgq
Date: 9 Mar 2011 17:00:01
Message: <web.4d77f7e2f5e1e8f881c811d20@news.povray.org>
> I was doing some tooling about with the latest lighting challenge from 3DRender
> (http://forums.cgsociety.org/showthread.php?f=185&t=955407) which features a
> movie theatre.  One of the maon aspects of lighting here will be that coming
> from the screen.  I first started using radiosity with an image projected on the
> screen, however it was becoming apparent that it may take some really high
> quality settings to get good results.  I then though of using an array of area
> lights created from the projector image. I had already done a lot of the
> mathwork in my lightdome work, so I did some quick conversions to making a
> planar version of it with some nice results.
> In the attached image, the first part is radiosity with some low quality
> settings.  The second is using the arealight array (16 area lights, 4x4 each).
> -tgq
Next stage is the projector lighting.  I think this is looking OK.  I don't have
the screen area light applied, just a single point light to add a little bit of
additional illumination.  This is the part where I was wondering about the light
attenuation, realistically speaking, the brightness of the projector in the
first 1/5 distance is a little too bright (~30%).
-tgq
Download 'matineescene1.jpg' (117 KB)
Preview of image 'matineescene1.jpg'
Date: 10 Mar 2011 13:19:11
Message: <4d79161f@news.povray.org>
> -tgq
Yes, from the last 1 or 2 3.7 betas, maybe a little more.
With that, you can have samples 10000 for your radiosity, but only for
the objects that realy need that. With a default importance on 0.01,
you'll get an average of 100 samples for most of the scene and up to
10000 for the more important objects.
Date: 10 Mar 2011 13:22:03
Message: <4d7916cb$1@news.povray.org>
>> -tgq
> -tgq
It don't look to bright to me.
Date: 10 Mar 2011 23:23:29
Message: <4d79a3c1$1@news.povray.org>
Am 09.03.2011 22:57, schrieb Trevor G Quayle:
>> -tgq
Of course you'll want fade_power 2. From my experience, fade_distance
should be roughly the light source size, so I'd try the equivalent of 35mm.
(I'm presuming assumed_gamma 1.0 here; for other gamma values, you'll
get nonsense results no matter what you do.)
I think the projector light is too bright in total, though of course it
all depends on how much dust you want in the air.
Date: 19 Mar 2011 13:15:00
Message: <web.4d84e377f5e1e8f8b05ef170@news.povray.org>
Some adjustments to my scene.  Tweaked the projector lighting a bit to get the
falloff I wanted, added just a touch of fill-type lighting from the projector
beam.  Adjusted the textures a little bit as well, added some specular to the
skin and a fine quilted texture to the seats.  I will probably try a different
seat texture as I don't have it uv mapped so it comes out with some moire-like
artifacting.
-tgq
Download 'matineescene-3.jpg' (96 KB)
Preview of image 'matineescene-3.jpg'
Date: 19 Mar 2011 18:09:23
Message: <op.vsl2h0zpufxv4h@xena>
On Sat, 19 Mar 2011 19:10:15 +0200, Trevor G Quayle
> get the
> projector
> to the
> different
> moire-like
> artifacting.
> -tgq
I like the lighting here.
-Nekar Xenos-
"The spoon is not real"
