POV-Ray : Newsgroups : povray.binaries.images : SSLT naive question Server Time
7 May 2026 06:20:53 EDT (-0400)
  SSLT naive question (Message 1 to 6 of 6)
Subject: SSLT naive question
Date: 19 Feb 2011 11:50:00
Message: <web.4d5ff45454ea12cdf7fe15af0@news.povray.org>
The right slab is the same as the left, plus subsurface with 'classic' wax SSLT
parameters. I am discovering SSLT, but what happened to the texture?
Bruno
Download 'ssltslab.png' (54 KB)
Preview of image 'ssltslab.png'
Subject: Re: SSLT naive question
Date: 19 Feb 2011 13:36:21
Message: <4d600da5$1@news.povray.org>
Am 19.02.2011 17:48, schrieb Bruno Cabasson:
It is being ignored.
The apparent color of an SSLT-enabled material is solely the result of
the SSLT parameters ("[reduced] scattering coefficient" and "absorption
coefficient").
Future versions of POV-Ray will "reverse engineer" those SSLT parameters
from the pigment and a kind of "translucency parameter".
Date: 19 Feb 2011 13:50:00
Message: <web.4d60100c1bd29a8394d713cc0@news.povray.org>
> Bruno
For some reason the current SSLT implemtation negates the pigment (if other than
a solid color). With layered textures you can work around this.
Try using a solid base pigment and SSLT finish in the lowest layer, and then
another texture on top of it, with the pigment's filter=1, and a standard normal
and finish, e.g.:
sphere { 0, 0.5
   translate -y*0.5
      pigment { rgb 1 }
      finish {
         // potato
         subsurface { <0.68, 0.70, 0.55>, <0.0024, 0.0090, 0.12> }
         bozo color_map {[0 srgb<1,0,0> filter 1][1 srgb<0,1,0>  filter 1] }
         scale 0.25
      normal { agate 0.02 scale 0.125 }
      finish { specular 0.25 roughness 0.02 }
   interior { ior 1.54  }
www.McGregorFineArt.com
Date: 19 Feb 2011 13:55:00
Message: <web.4d60112b1bd29a8394d713cc0@news.povray.org>
> coefficient").
Ah, well there's the "for some reason" ;)
Date: 19 Feb 2011 16:50:00
Message: <web.4d603adb1bd29a83f7fe15af0@news.povray.org>
> > coefficient").
Thanks for explanations!! I feel less stupid... Current implementation does good
job (still playing with candles ... and having fun!), congrats, and also well
done Robert for your code.
I also noticed that pigment appears with metallic specularity.
I long for POV's SSLT next episode.
PS: Am turning mad: I see SSLT everywhere now. When I see a vase or go to
toilets, I think 'SSLT'. Shoot me please ...
Date: 25 Feb 2011 22:34:06
Message: <4d6874ae$1@news.povray.org>
You're not nuts. Many materials do indeed have a translucency, light
falls just under the surface and scatters. This is why often rendered
images don't look quite right for some materials (especially ceramics,
some plastics, skin and other natural materials) I think this will bring
images even closer to realism than before, and POV-Ray has produced some
incredible images in its time.
