POV-Ray : Newsgroups : povray.binaries.images : SSLT candle experiment Server Time
14 Mar 2026 03:26:44 EDT (-0400)
  SSLT candle experiment (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: SSLT candle experiment
Date: 18 Feb 2011 07:17:47
Message: <4d5e636b$1@news.povray.org>
Am 18.02.2011 07:35, schrieb Bruno Cabasson:
> Is this one better?
Hell, yeah!
Date: 18 Feb 2011 07:20:39
Message: <4d5e6417$1@news.povray.org>
Am 18.02.2011 11:03, schrieb Bruno Cabasson:
> I also set the fade_distance in the same order of magnitude than the area light
> (twice). I am a bit confused by the fact that the dome is so barely visible,
> despite 4 candles. But, after all, they are small (the biggest is 16 cm high)
> and the dome is 5 metre from there. Maybe relative illuminations are correct.
I never liked that dome anyway :-P
Date: 18 Feb 2011 08:20:01
Message: <web.4d5e712744aed71b4aa45fdf0@news.povray.org>
Nor did I... It was just a basic checkered texture (dome was not the purpose of
the scene). Floor was plain white for tweaking lighting/shadows/radiosity. I'll
have another go with something more acceptable. Thinking of some igloo with SSLT
snow blocks, why not ...
Date: 19 Feb 2011 22:20:16
Message: <4d608870@news.povray.org>
> "Edouard"<pov### [at] edouardinfo>  wrote:
>>> Is this one better?
>> The wax looks just right, you can see the sizes just at a glance by the SSLT!
>> Cheers,
>> Edouard.
> In this experiment, I intended to make the size of the flame proportional to the
> size of the candle. So, I adjusted the lights powers according to the sizes
> proportionally, ie: *2 for the biggest, *1, *1/2, *1/4 respectively. I don't
> know the law for the illumination of flames wrt their size. I suppose the
> illumination comes from the surface of the flame, and therefore follows a
> quadratic law. My powers are surely wrong for flame powers proportional to the
> flame sizes.
> However, in RL, the size of the flame is generally not proportional to the size
> of the candle ...
In a flame, the light comes from the whole volume, and the flame is
essentialy transparent.
Make this test: light a candle and light some other light, place them to
project the shadow on a wall or similar surface. Now, take a look of the
shadow of the candle and it's flame. It's only effect on the light
passing through it is from it's lower than air ior.
Even the flame of a camp fire is essentialy transparent. You see it only
because the gaz of the flame is incandescent and emit light.
Same thing with the flame from a gaz stove.
Model those flames using emissive media, without absorbtion nor
scattering media.
Date: 20 Feb 2011 17:00:00
Message: <web.4d618eac44aed71bf7fe15af0@news.povray.org>
> >>> Is this one better?
> >> Cheers,
> >> Edouard.
> > flame sizes.
> > of the candle ...
> scattering media.
> Alain
Thanks for advise.
Do you have such a model you can share?
I think however that the incandescent particles in the flame scatter the light
of the others, and that they are also somewhat opaque and have an absorbing
behaviour. Other particles or atoms might also scatter their light. It seems
that a flame is quite a complex object.
Date: 20 Feb 2011 17:24:21
Message: <4d619495$1@news.povray.org>
Am 20.02.2011 22:59, schrieb Bruno Cabasson:
That is indeed the case for sooty flames. A cleanly burning candle flame
won't show much of that effect though.
Date: 21 Feb 2011 17:43:45
Message: <4d62eaa1@news.povray.org>
>>>>> Is this one better?
>>>> Cheers,
>>>> Edouard.
>>> flame sizes.
>>> of the candle ...
>> scattering media.
>> Alain
> Thanks for advise.
Siory, I don't have a ready made flame model at the moment.
In a clean flame, the particles are the same, or about the same,
dimentions as the molecules from the surounding air. They are small
molecule sized. So, the flame is about as "opaque" as the air itself.
Sample: candle flame, alchool flame, Bunsen burner, gaz stove burner,
soldering torch, plasma torch and cutters, controled light oil flame,
and any oxygen rich flame.
In a camp fire, the top of the flame can contain some sooth and smoke.
The bottom parts are quite transparent.
Date: 22 Feb 2011 00:55:03
Message: <web.4d634e6344aed71bb05ef170@news.povray.org>
If you want a candle flame, here is one I developed a number of years ago based
on many photos of flames, and had posted here somewhere before.
I always found that people tend to not get the colours right, especially the
purple and blues near the bottom.  This is purely emissive media and has
turbulence added in.  (the turb_translate macro within the macro is to back
check the flame base point so it is still centred where it should be. don't set
the turbulence level too high or it can fail at finding the point and
get stuck in an infinite loop, the sample image is set to 0.3).
sample usage:
union{
    cylinder{0 y*100 10 pigment{rgb 1}}
    cylinder{0 y*106 0.5 pigment{rgb 0}}
    object{Flam(0.3) scale 15 translate y*(108)}
    light_source{0
      rgb <1,.5,0>
      translate <0,117,0>
      media_attenuation on
      fade_power 2
      fade_distance 100
//START
#macro Flam (Turb)
  #local R1=seed(2);
  #local OS=rand(R1)*50;
  #local Flam1 = function(x,y,z)
{pow(pow(pow(3*x,2)+pow(0.8*y-0.2,2)+pow(3*z,2),3)+pow(max(1-sqrt(pow(5*x,2)+pow(y+.5,2)+pow(5*z,2)),0),2))}
  #local Flam2 = function(x,y,z)
{floor(pow(sqrt(pow((3.5*x),2)+pow((0.4*y+0.6),2)+pow((3.5*z),2)),2))}
  #local FlamF = function(x,y,z) {min(max(Flam1(x,y,z),Flam2(x,y,z)),1)}
  #macro turb_translate (tTurb,tOcta,tLamb,tOmeg,P0,Acc)
    #local PC=P0;
    #local Dir=<0,0,0>;
    #local V0=vlength(vturbulence(tLamb, tOmeg, tOcta, P0)*tTurb);
    #local Step=V0/2;
    #macro AB(PC,Step,d,Dir,V0)
      #local P1=PC+Step*d;
      #local V1=vlength(P1+vturbulence(tLamb, tOmeg, tOcta, P1)*tTurb-P0);
      #if (V1<V0 | d.x=1)
        #local Dir=d;
        #local V0=V1;
    #while (V0>Acc)
      #local DrP=Dir;
      AB(PC,Step, x,Dir,V0)
      AB(PC,Step,-x,Dir,V0)
      AB(PC,Step, y,Dir,V0)
      AB(PC,Step,-y,Dir,V0)
      AB(PC,Step, z,Dir,V0)
      AB(PC,Step,-z,Dir,V0)
      #if (vlength(DrP+Dir)=0)
        #local Step=Step/2;
      #else
        #local Step=V0/2;
      #local PC=PC+Step*Dir;
    PC
  #local tOcta=7;
  #local tLamb=1.32;
  #local tOmeg=0.35;
  sphere{0 1.1 scale <1/2,1,1/2> translate y*(0.15+OS)
    hollow
    pigment{rgbt <1,1,1,1>}
    interior{
      media{
        emission rgb 0.3
        method 3
        intervals 2
        density{
          function{FlamF(x,y-OS,z)}
          color_map{
            [0.00 rgb <1,1,.5>]
            [0.20 rgb <1,.5,0>]
            [0.60 rgb <1,.1,0>]
            [0.78 rgb <0,0,0>]
            [0.90 rgb <0,0,0>]
            [0.94 rgb <0,0,1>]
            [0.98 rgb <0,0,1>]
            [1.00 rgb <0,0,0>]
          warp{
            turbulence Turb
            octaves tOcta
            lambda tLamb
            omega tOmeg
    no_shadow
    translate turb_translate(Turb,tOcta,tLamb,tOmeg,y*(0.75-OS),0.001)
//END
Download 'candleflame.jpg' (396 KB)
Preview of image 'candleflame.jpg'
Date: 22 Feb 2011 05:25:01
Message: <web.4d638e2e44aed71b4aa45fdf0@news.povray.org>
Good job!
Here is a more modest code snippet with emission-only media in a simple ovus
container (could be an animatable blob)
global_settings
    assumed_gamma 1
#declare FLAME_COLOR1 = (2*Firebrick+Goldenrod)/3;
#declare FLAME_COLOR2 = (2*Orange+Goldenrod)/3;
camera
    location -10*z
    angle 40
sphere
    0, 1
    hollow
    pigment {brick scale 0.5*x scale 1/250 warp {spherical}}
    scale 30
ovus
    1, 0.6
    pigment {rgbt 1}
    hollow
    interior
        media
            samples 5
            emission 6
            //scattering {1, White}
            //absorption 4
            density
                spherical scale 2
                translate -1.5*y
                color_map
                    [0 FLAME_COLOR1]
                    [0.25 FLAME_COLOR2/8]
                    [0.30 FLAME_COLOR2/8]
                    [0.40 MediumBlue/4]
                    [0.45 MediumBlue/10]
                    [0.6 rgb 0]
    scale 1.5*y
    scale 1/(1.3*1.5)
Download 'flame.png' (50 KB)
Preview of image 'flame.png'
Date: 22 Feb 2011 06:20:00
Message: <web.4d639bd644aed71b4aa45fdf0@news.povray.org>
Searching the web for informations about flame structure and properties, I found
this paper: http://www.newton.dep.anl.gov/askasci/chem00/chem00873.htm
