POV-Ray : Newsgroups : povray.binaries.images : Problem with the image saved to disk Server Time
18 Feb 2026 23:41:44 EST (-0500)
  Problem with the image saved to disk (Message 1 to 7 of 7)
Subject: Problem with the image saved to disk
Date: 6 Jan 2011 03:35:01
Message: <web.4d257d835ba2b92bb0720d810@news.povray.org>
This image is a windows capture
Download 'imgfrompovwindow.png' (244 KB)
Preview of image 'imgfrompovwindow.png'
Subject: Re: Problem with the image saved to disk
Date: 6 Jan 2011 03:45:01
Message: <web.4d25808c7c2d78a3b0720d810@news.povray.org>
This is the image saved to disk
Download 'imgsavedtodisk.png' (50 KB)
Preview of image 'imgsavedtodisk.png'
Date: 6 Jan 2011 06:30:00
Message: <web.4d25a78b7c2d78a3959c275d0@news.povray.org>
Maybe this helps to illustrate the problem.
I differenced the images in photoshop and raised the contrast.
Download 'difference_exagerated.png' (76 KB)
Preview of image 'difference_exagerated.png'
Date: 6 Jan 2011 07:00:01
Message: <web.4d25aeb67c2d78a35f9997c70@news.povray.org>
OK, I'm just taking a guess here since I just spent a lot of time trying to set
gamma stuff up right - make sure the "display_gamma" and "file_gamma" settings
in your POVRAY.INI file are correct (probably 2.2), and your monitor is adjusted
properly. I'm no expert in this regard but that's something you should check.
The gamma stuff built into POV-Ray is really useful but HAS to be ajusted
correctly.
Dave Blandston
Date: 6 Jan 2011 11:00:00
Message: <web.4d25e6a17c2d78a35f9997c70@news.povray.org>
And make sure you add the line "assumed_gamma 2.2" to your scene file...
Date: 6 Jan 2011 12:35:01
Message: <web.4d25fccf7c2d78a3b0720d810@news.povray.org>
Clarified:
http://news.povray.org/web.4d25b0127c2d78a3b0720d810%40news.povray.org
I think the best photorealistic combination is:
 1 .- "assumed_gamma 1" if you have a calibrated monitor to the sRGB standard.
 2 .- inverse gamma correction to color and texture if needed. This has been
automated with the keyword "srgb".
Date: 6 Jan 2011 15:32:08
Message: <4d2626c8$1@news.povray.org>
Am 06.01.2011 18:33, schrieb zalakainz:
Yup. For photorealism that's the way to go.
(Dave's recommendations for Display_Gamma and File_Gamma still hold though.)
