POV-Ray : Newsgroups : povray.binaries.images : POV Logo Wallpaper Server Time
22 Apr 2026 11:47:18 EDT (-0400)
  POV Logo Wallpaper (Message 1 to 10 of 15)
Subject: POV Logo Wallpaper
Date: 29 Dec 2010 08:30:01
Message: <web.4d1b37a958e25535966554e20@news.povray.org>
Hi there,
Here's a variation of Chris Colefax's POV logo. I think it makes a simple but
colorful wallpaper.
Dave Blandston
Download 'povers2.png' (715 KB)
Preview of image 'povers2.png'
Subject: Re: POV Logo Wallpaper
Date: 29 Dec 2010 08:45:01
Message: <web.4d1b3b10bf984996966554e20@news.povray.org>
Whoa!!! Gamma problems again - sorry. If anyone's interested I'll fix it and
re-post the picture.
-Dave
Date: 29 Dec 2010 09:44:38
Message: <4d1b4956$1@news.povray.org>
Am 29.12.2010 14:43, schrieb Dave Blandston:
To me it looked good as posted.
Date: 30 Dec 2010 03:03:09
Message: <4d1c3cbd$1@news.povray.org>
"Dave Blandston" <nomail@nomail> schreef in bericht
news:web.4d1b37a958e25535966554e20@news.povray.org...
> Hi there,
> but
> colorful wallpaper.
Is looking very good. One has to be careful of the needle points though. So
easy to get hurt :-)  Seriuously: maybe they should be a little bit
blunter...?
Date: 31 Dec 2010 01:50:01
Message: <web.4d1d7cacbf984996cb6252d10@news.povray.org>
Internet Explorer shows it washed-out. Only the small preview looks right on my
computer. I'll check my settings...
Message: <web.4d1d7d07bf984996cb6252d10@news.povray.org>
> > Hi there,
> > but
> > colorful wallpaper.
> blunter...?
> Thomas
That's part of the original - I only added the indented glowing parts.
Date: 31 Dec 2010 04:31:05
Message: <4d1da2d9$1@news.povray.org>
Am 31.12.2010 07:48, schrieb Dave Blandston:
 From what I can see in the PNG header, you're using pretty
unconventional gamma settings. For starters, File_Gamma=1.0 is generally
not a good idea as it leads to the Windows Explorer thumbnail preview
appearing differently. And as a matter of fact it's usually the
thumbnail preview that lies to you, unless you have an exceptionally
uncommon display gamma.
My guess is that you're using File_Gamma=1.0 and Display_Gamma=1.0,
while actually having a display with a gamma of around 2.2.
The Display_Gamma=1.0 will make the image look the same in 3.7 beta
preview render as if you had used assumed_gamma 2.2 in 3.6 with
Display_Gamma=2.2, while the File_Gamma=1.0 will not have any visible
effect on PNG files (except for viewers that ignore gAMA chunks, such as
Windows Explorer's thumbnail generator) - it will just make the output
more susceptible to banding artifacts.
While it /may/ be that you adjusted your display for a gamma of 1.0, it
is both uncommon (typical values are around 2.2, give or take) /and/
will make virtually all of your software display nonsense unless you
also informed Windows of the fact (or each piece of software separately,
but only few pieces of SW provide a means to tell them about your
display gamma).
Whatever you're doing there regarding gamma, you're probably doing
/something/ fundamentally flawed.
And it's likely that you have a different taste than me: I do prefer the
washed-out version, especially for a wallpaper.
Date: 3 Jan 2011 01:40:00
Message: <web.4d216c89bf9849965f9997c70@news.povray.org>
> display gamma).
I'm sure I am doing something wrong. In order to get everything looking good on
my monitor (CRT), I set the video card gamma to +1.0. If I set it lower or
higher I CANNOT get things to look right by adjusting the brightness and
contrast settings. If I set my video card to gamma 2.2 it looks absolutely
terrible.
You are right, I'm using POVRAY.INI settings "file_gamma=1.0" and
"display_gamma=1.0." I added "assumed_gamma 1.0" to the scene file. Everything
looks great on my computer (render preview and finished images displayed with
any program other than Internet Exporer) but .png images look washed out when
displayed in Internet Explorer. Between the video card settings, POVRAY.INI
settings, assumed_gamma setting, and monitor brightness settings something must
be wrong. (I don't think Windows XP has any gamma settings other than what the
video card driver adds.) But after lots of experimentation, the only thing that
doesn't work for me is the display of .png files with Internet Explorer so if I
convert to .jpg before posting everything will be fine.
By the way, even when I turn the file_gamma way down the image still appears
washed out in IE. I suspect there's something wrong with the way IE version 7
handles gamma. (At least it's different from all the other display programs I
use.)
Thanks for the tips!
Dave Blandston
Date: 3 Jan 2011 06:19:06
Message: <4d21b0aa@news.povray.org>
Am 03.01.2011 07:36, schrieb Dave Blandston:
> terrible.
There may be a potential for misunderstanding there: Your overall
display gamma is the result of multiple component gammas - including the
monitor, graphics card hardware, graphics card drivers, and even
possibly some OS settings. The video card driver may - or may not - tell
you only the "LUT gamma" (i.e. the graphics card driver's part of the
whole thing). In that case a value of 1.0 is a pretty good setting, but
is /not/ what you need to set POV-Ray's Display_Gamma to.
Did you ever check the gamma with the test images in the documentation,
or some site on the internet? The 3.7.0.RC1 also comes with a section on
gamma handling, and a sample scene to check whether your settings are
"sane".
> use.)
No, IE is probably the only piece of software you have that's doing it
right.
 From all you tell me, I assume that your overall display gamma is
indeed around 2.2, and that you're currently "cheating" your way around
what assumed_gamma 1.0 is intended to do. Note that the combination
Display_Gamma=File_Gamma=assumed_gamma=1.0 is virtually equivalent to
Display_Gamma=File_Gamma=assumed_gamma=2.2 /except for PNG output/.
So here's what you should do:
(1) Check your display gamma, using one of the many gamma test patterns
out there, such as the image in section 3.1.2.3.2 "Setting your Display
Gamma" of the POV-Ray 3.6 docs, or using the sample scene mentioned in
the tutorial section "Gamma Handling" of the 3.7.0.RC1 docs. I suspect
you'll learn that your display gamma /is/ around 2.2.
(2) Set Display_Gamma=2.2 and File_Gamma=2.2
(2.1) Note that this will /always/ give you that washed-out appearence
you're currently seeing with .png in IE.
(3) To compensate, either (a) go back to using assumed_gamma 2.2 (*), or
(b) learn how to texture and illuminate your scene for physically
accurate rendering, and/or (c) get used to the more washed-out look and
learn to like it.
(* As of 3.7.0.RC1, assumed_gamma is no longer considered deprecated; to
the contrary, it will be /mandatory/ in the future; and while the
recommendation to use a value of 1.0 is still maintained for /physically
accurate/ renders, it is now acknowledged that people may prefer other
properties over physical accuracy. The new gamma handling features have
also been adapted to play nice with assumed_gamma.)
Date: 3 Jan 2011 07:05:11
Message: <4d21bb77@news.povray.org>
> terrible.
   While I agree totally with clipka remarks, I think perhaps your CRT
is also to blame here... your issues remember me of my problems many
years ago with a faulty Samsung monitor. I suspect this is why you see
as "washed out" what others see as "correct", and also why others see as
"too dark" what you see as "correct".
   Look for example at this old image of mine, which I created while
using the flawed monitor:
   http://www.ignorancia.org/uploads/images/persiana/persiana.jpg
   Back then it looked fine to me: I was even able to see the plant on
the corner! Now, with a properly calibrated monitor, I can barely see
anything else than the sunlit parts and a little radiosity near them.
How do you see it? ...do you see the plant on the corner?
Jaime Vives Piqueres
