POV-Ray : Newsgroups : povray.binaries.images : More Gamma Again Server Time
19 Mar 2026 22:22:02 EDT (-0400)
  More Gamma Again (Message 31 to 33 of 33)
Subject: Re: More Gamma Again
Date: 3 Dec 2010 12:36:37
Message: <4cf92aa5$1@news.povray.org>
Am 03.12.2010 18:22, schrieb Jaap Frank:
> _______________________________________________
> "clipka" schreef in bericht news:4cf7665a$1@news.povray.org...
> Am 02.12.2010 01:01, schrieb Jaap Frank:
>> That's odd, because for me the 3.6 side is correct and the 3.7 side is
>> far too bright.
> Actually /that/ is odd.
> Please read my reaction on the comment of Warp about the monitors.
>> By the way, the challenge from clipka is for me a perfect gradient from
>> 0,0 to 1,1 in the XY-plane. I suspect that this picture is made with
>> 3.7, so that is odd again.
> No, it's an image with a "visually linear" gradient created in Photoshop
> while working with the sRGB color profile, which I then converted to a
> custom color profile with a gamma of 1.0. The challenge is to open this
> image in Photoshop and - without converting it to a different color
> profile - draw a visually linear gradient over it. I don't know about
> newer versions, but in Photoshop 6.0 this will have you end up with a
> gradient similar to that created by POV-Ray 3.7.
> ___________________________________________________
> How do you do that: ...draw a visually linear gradient over it. Is there
> a choice for this in PSP somewhere?
With normal settings, a standard gradient from black to white should
come close enough to it. Note however that with the color profile
embedded in the image, the result will be strikingly different. My
intention there was to make a point that Photoshop is not a good
benchmark for some stuff.
Date: 3 Dec 2010 15:23:51
Message: <4cf951d7$1@news.povray.org>
On 03.12.2010 18:03, Jaap Frank wrote:
> My conclusion is that the problem lies somewhere else and is NOT a
> problem of the monitors. In another computer with a rather expensive
> BenQ monitor (LCD) the results are exactly the same (Win XP and another
> NVidia card).
You should in any case select sRGB as your working color space as this
is THE standard for the WWW and also JPEG and PNG image files are by
default encoded in sRGB color space and in case they include a different
ICC profile your Windows 7 CMS (err, Color Management System) will
convert them correctly to sRGB.
Then, VERY IMPORTANT, (sorry but I have to use a lot of capital letters
here!) do NOT use the Paint Shop Pro gamma adjustment as THIS IS THE
MOST CRAPPIEST THING I've ever seen (in this regard). Do NOT trust it
and do NOT use it. For nuthin'. NEVER!
OK, do not get me wrong PS Pro is a nice piece of software but it's so
called calibration isn't.
Then go here
http://www.photoscientia.co.uk/Gamma.htm
you may want to read the explanation about gamma (that is quite good)
but please ignore the reasoning for the 1.8 gamma - this is just
outdated (the side is quite old) and I for one did never really agree
with it.
At the bottom of the page choose Gamma 2.2 (and nothing else!) and then
use the color correction panel for your NVidea graphics card and play
with the gamma setting until the *colors* are as close to the gray
background as possible.
This gamma chart is the best one for *visual* gamma adjustment that I am
aware off.
Now you are done ;)
hope this helps
-Ive
Date: 3 Dec 2010 16:38:54
Message: <4cf9636e$1@news.povray.org>
______________________________________________________
"Ive"  schreef in bericht news:4cf951d7$1@news.povray.org...
> NVidia card).
Then go here
with it.
aware off.
Now you are done ;)
hope this helps
-Ive
Thanks again for the swift reaction Ive. I'm going to work with this. I'll
let you know what the result is.
Jaap Frank
