POV-Ray : Newsgroups : povray.binaries.images : More Gamma Again Server Time
26 Mar 2026 13:39:42 EDT (-0400)
  More Gamma Again (Message 14 to 23 of 33)
Subject: Re: More Gamma Again
Date: 1 Dec 2010 08:20:01
Message: <web.4cf64adda2356450fc413f510@news.povray.org>
> Am 01.12.2010 04:23, schrieb Stephen Klebs:
> > out. When I tried to reproduce in 3.7 Steve Gower's wonderful "Bucket of
> > Seashells", however, using every possible gamma/version/ambience whatever I
> > could think of, I was surprised how dramatically different everything looked.
> > The smooth beach turned into a pile of large boulders. The light on the water
> > looked fake and glaringly over exposed. Parts of the seashells lost all their
> > beautiful gradations and were just black.
> Did it work with 3.6?
Sorry. Post amended:
Yes it worked in 3.6. More or less as #version 3.6. Perfectly as #version 3.0.
Date: 1 Dec 2010 13:55:19
Message: <4cf69a17$1@news.povray.org>
Am 01.12.2010 14:08, schrieb Stephen Klebs:
> No. If someone can get it to work (without playing with it for a week). I'll
> shut up.
Okay, so the problems with Steve Gower's scene are obviously unrelated
to the gamma changes in POV-Ray 3.7.
Date: 1 Dec 2010 15:45:50
Message: <4cf6b3fd@news.povray.org>
Stephen Klebs <skl### [at] gmailcom> wrote:
> What one would expect to be a smooth, linear gradient, becomes in 3.7 a
> parabolic curve, heavily skewed to white.
  I took your gradient image, rotated it 90 degrees and put alternating
horizontal black and white lines of pixels at both sides. Look at the
image from far enough that you don't distinguish the individual lines
but instead it becomes a gray, and then estimate on both sides which
square in the central gradient corresponds to this half-gray area on
the sides. I think it's pretty illuminating.
  With my monitor the photoshop/pov36 part (at the left) has the same
brightness somewhere between the second-to-last and third-to-last square,
while the pov37 part (at the right) as the same brightness somewhere in
the middle, as it should.
Download 'gradient_10_pov.png' (4 KB)
Preview of image 'gradient_10_pov.png'
Date: 1 Dec 2010 15:55:41
Message: <4cf6b64d$1@news.povray.org>
  Oh, and by the way, if the suspicion is that the bright white lines
are "bleeding" over the black lines making them look lighter than they
should (which might be a valid concern especially on a CRT), you can try
zooming the image eg. to 4 times the size (so that each pixel in the
image is scaled to 4x4 screen pixels) to minimize that possibility, and
look at it from even farther away (to "blend" the horizontal lines into
gray). When I do this, it still looks the same.
Date: 1 Dec 2010 19:01:21
Message: <4cf6e1d1$1@news.povray.org>
"Warp"  schreef in bericht news:4cf6b3fd@news.povray.org...
_____________________________________________________
That's odd, because for me the 3.6 side is correct and the 3.7 side is far
too bright.
I've a rather new HD LCD TFT monitor (about 6 months) and adjusted it
conform the windows 7 system with brightness and contrast followed by color
shade correction.
Further the monitor of my laptop (Acer Aspire, 1 year old, crystal clear
display) shows exactly the same picture. Both are driven by the NVidia card
inside the laptop, so they should be the same and for /me/ they are. The
pictures are displayed by Windows Live Mail.
I'm wondering if the default 3.7 approach is correcting the values for a 2.2
gamma display in the file, while the display system thinks it gets lineair
values and correct the values again. That would explain the 3.7 side for me.
(The jpg and png files are the same for me, so that can't be the problem)
By the way, the challenge from clipka is for me a perfect gradient from 0,0
to 1,1 in the XY-plane. I suspect that this picture is made with 3.7, so
that is odd again.
I'm reading the Gamma Stories for months now and all the same I'm confused.
Maybe clipka can answer what is correct:
Povray makes a calculation for a picture and the values of the first three
pixels are 64,64,64 / 128,128,128 / 192,192,192.
As I understand these are the values of PovRay's internal lineair color
space.
My questions are:
A. What values are send to the display system at the moment of rendering:
    1. Gamma corrected values for a 2.2. display, so not the lineair values.
    2. Lineair values and PovRay tells the display system to convert them to
2.2 display values:
B. What values are written in the png file and what is put in the gAMA
chunk.
    1. Same as A.1. and the gAMA chunk tells the values are gamma corrected
for 2.2.
    2. Same as A.2. and the gAMA chunk  tells that the correct values should
be 2.2 corrected values (sounds not correct, but you never can tell).
To complete the story:
C.1. PovRay expects the file for a image-texture on a object to be gamma
corrected (default 2.2) and counter corrects the values for it's lineair
color space.
    2.Same, but the correction depends on the gAMA blok. With no gAMA a 2.2
correction is used.
I think that the answers are A.1 and B.1, but sometimes I begin to doubt
that, as I read these gamma stories.
As far as I've understood C.1 is 3.6 and C.2 is 3.7 policy.
Jaap Frank
Date: 1 Dec 2010 21:05:06
Message: <4cf6fed2$1@news.povray.org>
 > far too bright.
 > color shade correction.
 > card inside the laptop, so they should be the same and for /me/ they
 > are. The pictures are displayed by Windows Live Mail.
Trust me, Warp is correct and if you see it different there is something
screwed up with your display system. One cannot *perfectly* calibrate a
display without usage of some external hardware but for, let's say
hobbyist usage, there are quite a lot tools (and web-pages) around that
allow for visual adjustment but all of them boil down to something
similar Warp has shown.
 > 2.2 gamma display in the file, while the display system thinks it gets
 > lineair values and correct the values again. That would explain the 3.7
 > side for me. (The jpg and png files are the same for me, so that can't
 > be the problem)
 > 0,0 to 1,1 in the XY-plane. I suspect that this picture is made with
 > 3.7, so that is odd again.
confused.
 > three pixels are 64,64,64 / 128,128,128 / 192,192,192.
 > space.
 > My questions are:
 > 2.2 display values:
 > chunk.
 > for 2.2.
 > color space.
 > correction is used.
A.1. but the actual value can be adjusted by the display_gamma setting
with the recommended default of 2.2 (unless you know what you are doing ;)
B.1. but the actual value can be adjusted by the file_gamma setting with
the recommended default of 2.2 (unless you know what you are doing ;-P)
and the exception of high dynamic range formats being always encoded
linear (as they should be by definition).
C.2. is true for POV-Ray 3.7 AND 3.6 and PNG input format except when no
gamma chunk was present when POV-Ray 3.6 did apply no correction at all
(see below).
C.1. is true for POV-Ray 3.7 and any other format than PNG
BUT POV-Ray 3.6 did use the gamma encoded values internally directly
without converting them to linear color space and this was plain wrong!
-Ive (and sorry for sending the mail - this happens to me all the time,
I really should learn how to use Thunderbird)
Date: 2 Dec 2010 04:11:10
Message: <4cf762ae@news.povray.org>
> far too bright.
  Note that at least with some LCD displays (especially on some laptops)
the angle from which you look at the screen affects the brightness. For
example, if I look at the image I posted in a MacBook laptop, I can
"tune" the "gamma correction" of the display by tilting the screen back
or forth (thus changing the vertical angle from which I look at the
screen). At some angles it looks like the brightness of the sides
correspond to the center of the 3.6 gradient (and thus the 3.7 gradient
is too bright), while at other angles it looks like they correspond to
the center of the 3.7 gradient (and thus the 3.6 gradient looks too
dark). (And everything in-between, of course.) This tells me that the
screen on this laptop is an *extremely* poor tool to determine which one
is correct (if either), because I can change it by simply looking at it
from a higher or a lower angle.
  I do understand, however, that many of the more modern and expensive
LCD displays don't suffer from this problem (at least not as badly).
  If I had a working camera I could take photos to corroborate these
findings, but unfortunately I don't.
Date: 2 Dec 2010 04:26:50
Message: <4cf7665a$1@news.povray.org>
Am 02.12.2010 01:01, schrieb Jaap Frank:
> far too bright.
Actually /that/ is odd.
No, it's an image with a "visually linear" gradient created in Photoshop
while working with the sRGB color profile, which I then converted to a
custom color profile with a gamma of 1.0. The challenge is to open this
image in Photoshop and - without converting it to a different color
profile - draw a visually linear gradient over it. I don't know about
newer versions, but in Photoshop 6.0 this will have you end up with a
gradient similar to that created by POV-Ray 3.7.
> space.
No. POV-Ray internally works with floating point numbers.
But let's for now assume that POV-Ray happens to compute 0.25,0.25,0.25
/ 0.5,0.5,0.5 / 0.75,0.75,0.75 for those pixels.
> My questions are:
Yes. In the given case that would be 136,136,136 / 186,186,186 /
224,224,224.
To be precise, the gamma may be the one specified by the Display_Gamma
INI file option, defaulting to 2.2. You can also set
"Display_Gamma=sRGB", in which case you'll get the roughly similar
adjustment specified in the sRGB color space specification ("sRGB
transfer function").
> 2.2 display values:
No.
> chunk.
> for 2.2.
By default, yes. Again, you can specify the gamma using the File_Gamma
INI file option, and once again 2.2 is the default and "sRGB" is a valid
value also.
That would be the case if you set File_Gamma=1.0. But to be precise,
POV-Ray would not tell in the gAMA chunk that the values still need to
be gamma-corrected for 2.2, but rather just tell that the values are
linear, leaving it up to the image viewer to decide for which gamma to
pre-correct the data before sending them to the display.
> color space.
That would be the case for most low dynamic range file formats that do
not carry gamma information (or none that POV-Ray can currently
understand; e.g. BMP or JPEG).
> correction is used.
That would be the case for PNG images, except that an sRGB chunk would
take precedence over a gAMA chunk, and the default would be the sRGB
transfer function, which is close to (but not quite the same as) a gamma
of 2.2.
It's still true nonetheless. The original cause of confusion is
typically the impression that normally pixel values (such as displayed
by Photoshop, or by most color pickers) would be linear. They're not.
Yes and no. In general you're right, but for PNG 3.6 already used gamma
correction if a gAMA chunk was present (it ignored sRGB chunks though,
IIRC).
Date: 2 Dec 2010 08:10:01
Message: <web.4cf79a7ba2356450fc413f510@news.povray.org>
I don't know. I don't know the inner workings of all the changes that have been
made or how they interrelate. Can anyone? POV's turned into a pretty complex
organism. I just couldn't get it to work. And if that doesn't work I'm assuming
there's a lot of other scenes that won't work. They don't have to, of course.
But it worked fine in 3.6 (as #version 3.0). How stuff made in 3.6 will come out
in 3.7 (as #version 3.6) we'll see.
Date: 2 Dec 2010 17:15:01
Message: <web.4cf81a3da2356450fc413f510@news.povray.org>
> On most displays, image "gammachecker_3.6.png" will show a chrome sphere
> on a checkered plane, but there's something wrong here: The checkering
> shouldn't be there - the plain grey tiles have a brightness of 0.5,
> while the striped tiles have alternating lines of 0.0 black and 1.0
> white, so should appear just as bright as the grey if you squint your
> eyes; and in indeed both tiles appear to have the same brightness in the
> reflection, where anti-aliasing computes the correct result.
Your gammachecker_3.6 is fascinating. Is the scene file floating around
somewhere. I assume from the title it's done in 3.6 -- if that makes any
difference.
I don't really understand how this tests gamma, though, which in practical
terms, for how I use it, has to do with the relative relation of highlight and
midtones and shade and shadow, or in Photoshop terms, "curves."
