POV-Ray : Newsgroups : povray.binaries.images : Light Challenge Server Time
22 Apr 2026 14:43:31 EDT (-0400)
  Light Challenge (Message 25 to 34 of 34)
Subject: Re: Light Challenge
Date: 17 Jun 2010 08:50:00
Message: <web.4c1a19e7ad2ae755c59235590@news.povray.org>
"waggy" <hon### [at] handbasketorg> wrote:
> I grew up learning the basics: that framing is by far the most important skill
> to master.  In a real world, if you look hard enough you can find a good shot
> anywhere.  Lighting and lens tricks can certainly improve the quality of a
> photograph and help bring the the story to life.
This is great advice.  You've done an excellent job coming up with a great story
for this boring test scene.  I'm impressed!
> My radiosity skills are near to nonexistent, but I decided to try lighting the
> scene by using the cone as a light source.  I cheated a bit by adding no_image
> no_shadow objects to the looks_like of the lights used, and added a similar
> large sphere around the scene to contain some absorbing media and tone down the
> ambient contribution of the plane in the distance.  Due to my ignorance, for the
> textures to (almost) work, I ended up jacking up almost all of the radiosity
> values to near their highest quality (except recursion_limit, which is 2), and
> the scene took about forever to render.
I like the way this turned out.  The use of absorbing media is very subtle -- I
wouldn't have known it was there if you hadn't mentioned it.
Date: 17 Jun 2010 08:55:01
Message: <web.4c1a1a54ad2ae755c59235590@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> That's a ring of 30 coloured lights
Clever idea!
My eye is continually drawn to the dark center of the torus.  :)
Date: 17 Jun 2010 09:00:00
Message: <web.4c1a1b27ad2ae755c59235590@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote:
> Fun idea! Here's my try:
Beautiful!  Thanks for this, Sam.  I'm learning a lot from all of you!
> For outdoor scenes I almost always have a sky_sphere with a spherical pigment
> influenced by the sun's position and color. This is to simulate scattered light
> in the atmosphere, and helps give the radiosity something like a real sky to
> work with.
Ah, again this points to my lack of experience with radiosity, but I didn't
realize it would make that big of a difference.  I'll have to try some test
scenes with and without the spherical pigment to completely convince myself.
> Apart from what you see in the attached code, I added photons to the cone and
> shifted the plane up slightly because of a coincident surfaces problem with it
> and the cone. Then I added some post-processing light blooming to balance the
> colors a bit after everything else.
Whoops, sorry about the coincident surfaces.  I meant it to be a test scene, but
not *that* test-y.  ;)
Date: 17 Jun 2010 13:55:01
Message: <web.4c1a60efad2ae7551e4ecc3b0@news.povray.org>
> > work with.
It helps, all right. When you test a basic background (using rgb_sky), look at
the shadows. They are quite telling. Giving the sky_sphere a spherical gradient
centered around the sun sort of bridges the gap between the sun's color and the
atmosphere's, helping to harmonize the overall color balance.
> > and the cone.
I considered shifting the plane /down/, so that the cone would appear to be
resting on top of the plane. But to keep the appearance of the original behavior
intact, I shifted it up instead.
Date: 17 Jun 2010 15:40:01
Message: <web.4c1a7941ad2ae755da6353d60@news.povray.org>
> If I understand you correctly, the 'reflecting lights' are shadowless light
> sources with low values that emulate inter-reflected light from other objects?
> For example, if I have a scene with a red car, I might place a red shadowless
> light near the car to 'help' cast scattered light...?  It seems you'd have to be
> careful not to allow the light to shine back on the object you're emulating.
> (Or, perhaps I've misunderstood what you're trying to get across.)
You are right. To avoid the wrong object to being lighted up, use spotlights,
shining away from these objects.
> Interesting!  So, in a real photography setting, how do you add a light
source
> that doesn't cast a shadow?
Actually is cast a shadow, but there are two important things:
1: the power of reflecting light is (in most cases) _much_ smaller then the
main-light.
2: when light is reflecting from an object, it works like a area-light. That
means very blurry shadow.
I've made a a little move that shows in a very nice way, what happens, when
light is reflecting in a room.
Its an animated gif.
best regards,
Holger
Download 'light.gif' (747 KB)
Preview of image 'light.gif'
Date: 17 Jun 2010 17:10:23
Message: <4c1a8f3f$1@news.povray.org>
Samuel Benge wrote:
> Giving the sky_sphere a spherical gradient centered around the sun sort of
 > bridges the gap between the sun's color and the atmosphere's, helping
to harmonize
Interesting. It's a bit like using a large area_light for the sun, then?
Date: 18 Jun 2010 01:29:11
Message: <4c1b0427$1@news.povray.org>
Christian Froeschlin wrote:
>> sort of
> to harmonize
More like having an area_light in addition to a regular one. I've tried
that without radiosity, and the results weren't very promising.
Date: 6 Aug 2010 08:16:29
Message: <4c5bfd1d@news.povray.org>
On 06/14/2010 10:46 PM, How Camp wrote:
> Below is a primitive scene (no pun intended) with only a basic light source.
> With the restriction that you aren't allowed to change the camera or the objects
> (including their mundane textures), what creative lighting solutions can you
> come up with to make this image more interesting?
  Seems like nobody remembers this:
http://warp.povusers.org/povtips/
Date: 7 Aug 2010 10:10:35
Message: <4c5d695b$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schreef in bericht
news:4c5bfd1d@news.povray.org...
<sigh>
So it goes...  :-)
Date: 7 Aug 2010 11:04:02
Message: <4c5d75e2$1@news.povray.org>
I've not and think that it should be required reading for all Povers..
Best Regards,
