Hi there,
Currently I'm working on a CSG model of an Mk 2 hand grenade. So far the top
part is finished except for the spoon. I'm having a hard time figuring out how
to construct the actual body of the grenade, though. Does anybody have any
suggestions? Here's a photo of a grenade similar to the one I'm modelling:
http://mysite.verizon.net/moronicon/Mk2Photo.jpg
I know it would be easy to make such a model using modelling software, but I
prefer the challenge of using POV's SDL. I've got a couple ideas about possible
methods but none of my ideas are very good.
Dave Blandston
Download 'mk2.jpg' (47 KB)
Preview of image 'mk2.jpg'
Dave Blandston wrote:
> Hi there,
> Regards,
> Dave Blandston
I'm seeing an isosurface function combining a sphere (stretched in the y
direction) and an extruded brick or f_rounded_box...
A.D.B.
Le 26/04/2010 20:08, Anthony D. Baye nous fit lire :
> A.D.B.
I would suggest a citrus (internal of self-interecting torus: when r>R)
instead of a stretched sphere, without stretch. an enclosing box might
avoid seeing the points of the citrus.
> I'm having a hard time figuring out how to construct the actual body
It's going to end up as a perfume bottle anyway so
why bother with the martial intermediate step? :-P
> suggestions?
Would a triangle-mesh object made with POV's HF_Sphere macro qualify as 'SDL'?
Here's a basic idea, some code I came up with (and an image.) It's one way to do
it; there are probably others. Just add a camera and some lights. The code's not
perfect by any means, but it does create that 'pineapple' look. BTW, I could
have used 'pattern' rather than 'pigment' to generate the functions (to do away
with the .gray step)--but the two functions need to be combined anyway, before
being used in the macro. (It accepts only one.)
There's still a problem with the model that I haven't yet been able to solve:
Where the vertical and horizontal indent lines meet, there's a deeper indent at
each intersection. (Or rather, the non-overlapping parts of the lines are raised
farther upward than the intersections.) They *should* all be at the same depth.
Seems there's an odd 'bias' somewhere--probably a result of the pigment values I
used. I just *know* there's a way around this little conundrum. (I may have
solved it years ago, but I can't remember how; I'll have to look back over some
of my old code.)
There are two things that you should definitely play around with, to see the
interesting effect: The HF's resolution, and adding/not adding 'smooth' to it.
The lower the resolution, the more 'slanted' the pineapple chunks become. (It's
a consequence of the rez not being high enough to actually reproduce the
indents' pigment functions.) In this case, it's quite useful!
Ken
#include "shapes.inc"
sky_sphere{pigment{color rgb .7*<.8,.9,1>}}
plane{y,0 pigment{color rgb .8}}
#declare vertical_pigment_function =
function{
pigment{
gradient x scale .090
color_map{
[0.0 rgb 1]
[0.75 rgb 1]
[0.75 rgb 0]
[1.0 rgb 0]
warp{spherical orientation y dist_exp 0}
#declare horizontal_pigment_function =
function{
pigment{
gradient y scale .10
color_map{
[0.0 rgb 1]
[0.8 rgb 1]
[0.8 rgb 0]
[1.0 rgb 0]
warp{spherical orientation z dist_exp 0}
#declare final_function =
function{
vertical_pigment_function(x,y,z).gray*.5
+ horizontal_pigment_function(x,y,z).gray*.5
// Just to show what the values represent...
//HF_Sphere(
// Function,
// UseUVheight,
// UseUVtexture,
// Res,
// Smooth,
// FileName,
// Center,
// Radius,
// Depth)
object{
HF_Sphere(final_function,0,0,<110,110>,0,"",0,1,.13)
pigment{color rgb <.5,1,.5>}
//double_illuminate
scale <1,1.4,1>
rotate -5*y
translate 1.5*y
Oops, forgot to include the image...
Download 'hand_grenade_test.jpg' (167 KB)
Preview of image 'hand_grenade_test.jpg'
BTW, I *really* like your rust texture--especially the normal(?) that you used.
It looks bumpy/grainy, but with sort of flattened tops to the bumps. Nice! Care
to share??
Ken
That's really funny, but I'm afraid to show my wife your comment in case it
gives her the idea!!!
> to share??
> Ken
Oops, I forgot to credit the original texture author, Xplo Aristotle. This is a
very useful texture.
//Iron, Rust, and RustyIron by Xplo Aristotle
#local Iron = texture {
pigment {color rgb .25}
normal {granite .3 scale .2}
finish {specular .5 roughness .01 reflection .05 diffuse .8}
} //texture
#local Rust = texture {
granite
color_map {
[0.0 rgb <0.809995, 0.299123, 0.113405> * .8]
[0.4 rgb <0.209995, 0.096941, 0.031510> * 1.2]
[0.6 rgb <0.209995, 0.096941, 0.031510> * 1.2]
[1.0 rgb <0.569986, 0.052720, 0.005707> * .9]
} //color_map
scale .5
turbulence 1
} //pigment
normal {wrinkles}
} //texture
#local RustyIron = texture {
bozo
texture_map {
[0 Iron]
[1 Rust]
} //texture_map
turbulence 1
omega .5
lambda 2
} //texture
Thank you guys very much for the suggestions. I'm constantly amazed and humbled
by everyone's abilities. This may be a good time to learn some new things that
I've never tried. The isosurface features, as suggested by Anthony D Baye and Le
Forgeron, sound promising.
Kenneth, I'm going to experiment with your code a little. I'm wondering if
increasing the resolution a lot and using a gradient defined by a non-linear
function instead of an abrupt pigment transition could create the curved edges
of the "pineapple" bumps. And, unioning in a plain sphere scaled just right
could cover up those extra indentations handily. Thanks so much for your help!
Dave Blandston
