POV-Ray : Newsgroups : povray.binaries.images : Woven Cloth Texture Server Time
19 Feb 2026 17:18:26 EST (-0500)
  Woven Cloth Texture (Message 10 to 19 of 29)
<<< Previous 9 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Woven Cloth Texture
Date: 14 Feb 2010 05:11:20
Message: <4b77cc48$1@news.povray.org>
On 13/02/2010 4:44 AM, Anthony D. Baye wrote:
> Most Excellent.  I tried to come up with something similar a while back,
> but failed. This works great.
ha! a little 9. that's very cute.
Date: 15 Feb 2010 06:55:00
Message: <web.4b79354aadaa4c5ecba3fb0f0@news.povray.org>
>   I think it would be even more useful if it had a 'normal' block as
> well. That way it would interact with lighting, giving it depth.
My original goal was to make a normal to use for cloth, but I couldn't get that
to work and I had to settle for a texture. It would be great if this texture
could be made into a normal though.
Dave Blandston
Date: 16 Feb 2010 18:46:08
Message: <4b7b2e40$1@news.povray.org>
I redesigned this as a pigment by replacing the layered texture
with a pigment_map. Therefore, you can now define a pigment function
and use that as normal pattern. Nice texture BTW ;)
#local ClothScale = .5;
#local ThreadWidth = .2;
#local EdgeWidth = .08;
#declare P_Cloth = pigment
   gradient x
   color_map
     [0 color Black]
     [.1 color Black]
     [.5 color White * 4]
     [.9 color Black]
     [1 color Black]
   gradient y
   pigment_map
     [0 color Black]
     [.5 - ThreadWidth / 2 - EdgeWidth color Black]
     [.5 - ThreadWidth / 2 P_Cloth]
     [.5 + ThreadWidth / 2 P_Cloth]
     [.5 + ThreadWidth / 2 + EdgeWidth color Black]
     [1 color Black]
   average
   pigment_map
     [1 P_Cloth]
     [1 P_Cloth translate <.5, .5, 0>]
     [1 P_Cloth rotate 90 * z translate <.5, 0, 0>]
     [1 P_Cloth rotate 90 * z translate <0, .5, 0>]
   scale <ClothScale, ClothScale, 1>
#declare f_cloth = function {pigment {P_Cloth}}
#declare N_Cloth = normal {function {f_cloth(x,y,z).red}}
Date: 17 Feb 2010 03:48:08
Message: <4b7bad48@news.povray.org>
"Christian Froeschlin" <chr### [at] chrfrde> schreef in bericht
news:4b7b2e40$1@news.povray.org...
Christian, you rule!  :-)
Date: 17 Feb 2010 04:27:08
Message: <4b7bb66c@news.povray.org>
Forgive my confusion/ignorance, but I see the same pigment name P_Cloth
declared three times successively and still the result is correct. How is
this possible without parse confusion?
Date: 17 Feb 2010 04:42:47
Message: <4b7bba17@news.povray.org>
Very cool!
Paolo
Date: 17 Feb 2010 05:08:51
Message: <4b7bc033$1@news.povray.org>
> gradient x
> color_map
> [0 color Black]
> [.1 color Black]
> [.9 color Black]
> [1 color Black]
> gradient y
> pigment_map
> [0 color Black]
> [1 color Black]
> average
> pigment_map
> [1 P_Cloth]
sorry, but this will not work (as expected) as the function you feed
into the normal statement needs to evaluate the *slope* and not the
*height* at a specific point in 3d space.
-Ive
Date: 17 Feb 2010 08:23:30
Message: <4b7bedd2@news.povray.org>
"Ive" <"ive### [at] lilysoftorg"> schreef in bericht
news:4b7bc033$1@news.povray.org...
The image below only uses Christian's normal. I don't see a problem there
(except that the object is ill chosen of course).
Download 'DB_WovenCloth.png' (137 KB)
Preview of image 'DB_WovenCloth.png'
Date: 17 Feb 2010 08:50:01
Message: <web.4b7bf3a8adaa4c5ecba3fb0f0@news.povray.org>
> Thomas
Here's a simple computer programming example to show how and why this works:
   x = 1;
   x = x + 1;
In this case, the variable "x" is assigned a value (1), then later it's assigned
a new value based on the old value. This works because when the new value is
assigned, a temporary copy is made of the old value, manipulated (in this case 1
is added), then re-stored in the original location and becomes "x" again.
"P_Cloth" is just a more complex variable that can be manipulated like any
simpler variable. The restriction would be that once "P_Cloth" is defined as a
pigment it must remain a pigment.
This can be a useful technique to make your scenes more readable, and also more
efficient by not leaving intermediate variables laying around.
Dave Blandston
Date: 17 Feb 2010 08:55:01
Message: <web.4b7bf49aadaa4c5ecba3fb0f0@news.povray.org>
Wow, that's fantastic! Thanks for taking the time to do that an post it!
Dave Blandston
