POV-Ray : Newsgroups : povray.binaries.images : Woven Cloth Texture Server Time
19 Feb 2026 15:24:10 EST (-0500)
  Woven Cloth Texture (Message 11 to 20 of 29)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: Woven Cloth Texture
Date: 15 Feb 2010 06:55:00
Message: <web.4b79354aadaa4c5ecba3fb0f0@news.povray.org>
>   I think it would be even more useful if it had a 'normal' block as
> well. That way it would interact with lighting, giving it depth.
My original goal was to make a normal to use for cloth, but I couldn't get that
to work and I had to settle for a texture. It would be great if this texture
could be made into a normal though.
Dave Blandston
Date: 16 Feb 2010 18:46:08
Message: <4b7b2e40$1@news.povray.org>
I redesigned this as a pigment by replacing the layered texture
with a pigment_map. Therefore, you can now define a pigment function
and use that as normal pattern. Nice texture BTW ;)
#local ClothScale = .5;
#local ThreadWidth = .2;
#local EdgeWidth = .08;
#declare P_Cloth = pigment
   gradient x
   color_map
     [0 color Black]
     [.1 color Black]
     [.5 color White * 4]
     [.9 color Black]
     [1 color Black]
   gradient y
   pigment_map
     [0 color Black]
     [.5 - ThreadWidth / 2 - EdgeWidth color Black]
     [.5 - ThreadWidth / 2 P_Cloth]
     [.5 + ThreadWidth / 2 P_Cloth]
     [.5 + ThreadWidth / 2 + EdgeWidth color Black]
     [1 color Black]
   average
   pigment_map
     [1 P_Cloth]
     [1 P_Cloth translate <.5, .5, 0>]
     [1 P_Cloth rotate 90 * z translate <.5, 0, 0>]
     [1 P_Cloth rotate 90 * z translate <0, .5, 0>]
   scale <ClothScale, ClothScale, 1>
#declare f_cloth = function {pigment {P_Cloth}}
#declare N_Cloth = normal {function {f_cloth(x,y,z).red}}
Date: 17 Feb 2010 03:48:08
Message: <4b7bad48@news.povray.org>
"Christian Froeschlin" <chr### [at] chrfrde> schreef in bericht
news:4b7b2e40$1@news.povray.org...
Christian, you rule!  :-)
Date: 17 Feb 2010 04:27:08
Message: <4b7bb66c@news.povray.org>
Forgive my confusion/ignorance, but I see the same pigment name P_Cloth
declared three times successively and still the result is correct. How is
this possible without parse confusion?
Date: 17 Feb 2010 04:42:47
Message: <4b7bba17@news.povray.org>
Very cool!
Paolo
Date: 17 Feb 2010 05:08:51
Message: <4b7bc033$1@news.povray.org>
> gradient x
> color_map
> [0 color Black]
> [.1 color Black]
> [.9 color Black]
> [1 color Black]
> gradient y
> pigment_map
> [0 color Black]
> [1 color Black]
> average
> pigment_map
> [1 P_Cloth]
sorry, but this will not work (as expected) as the function you feed
into the normal statement needs to evaluate the *slope* and not the
*height* at a specific point in 3d space.
-Ive
Date: 17 Feb 2010 08:23:30
Message: <4b7bedd2@news.povray.org>
"Ive" <"ive### [at] lilysoftorg"> schreef in bericht
news:4b7bc033$1@news.povray.org...
The image below only uses Christian's normal. I don't see a problem there
(except that the object is ill chosen of course).
Download 'DB_WovenCloth.png' (137 KB)
Preview of image 'DB_WovenCloth.png'
Date: 17 Feb 2010 08:50:01
Message: <web.4b7bf3a8adaa4c5ecba3fb0f0@news.povray.org>
> Thomas
Here's a simple computer programming example to show how and why this works:
   x = 1;
   x = x + 1;
In this case, the variable "x" is assigned a value (1), then later it's assigned
a new value based on the old value. This works because when the new value is
assigned, a temporary copy is made of the old value, manipulated (in this case 1
is added), then re-stored in the original location and becomes "x" again.
"P_Cloth" is just a more complex variable that can be manipulated like any
simpler variable. The restriction would be that once "P_Cloth" is defined as a
pigment it must remain a pigment.
This can be a useful technique to make your scenes more readable, and also more
efficient by not leaving intermediate variables laying around.
Dave Blandston
Date: 17 Feb 2010 08:55:01
Message: <web.4b7bf49aadaa4c5ecba3fb0f0@news.povray.org>
Wow, that's fantastic! Thanks for taking the time to do that an post it!
Dave Blandston
Date: 17 Feb 2010 14:49:16
Message: <4b7c483c$1@news.povray.org>
Oops. A few years ago I did a few experiments in creating lace patterns
for poser lady dresses and it did not work this way. So either my memory
is tricking me (I'm gettin' older and older) or something within
POV-Ray's normal calculation has changed since then. I will investigate...
-Ive
