This image is an attempt to visualize the vector field <Z, -X, Y>.
Tor Olav
http://subcube.com
Download 'vectorfield.jpg' (118 KB)
Preview of image 'vectorfield.jpg'
Subject: Re: Visualizing vector fields with a single isosurface
Date: 30 Jan 2010 10:31:19
Message: <4b6450c7$1@news.povray.org>
Elegant. Is it faster than simply generating a heap of objects?
It is probably more difficult to add some direction indicator.
> Tor Olav
> http://subcube.com
I remember wanting to do something similar, but I found that you cannot have
parameters for a transformation function ;_;
I would up using a macro to generate parts of the function, but making a series
of functions that duplicate the behavior of a matrix in a symbolic fashion was
very difficult for me. I wound up making simpler functions, which could not
provide the ability to arbitrarily transform a function by varying amounts.
Anyway, I would be curious as to how your code is, if you don't mind posting a
sample. If your method provides a more elegant way of taking a point (x,y,z)
and spitting out a new, transformed point(x',y',z'), I can think of many uses
for it.
-Reactor
Thank you. No, in most cases it will be slower.
The attached image that shows something that can not be achieved
by orienting and spreading around a lot of objeccts with loops.
No, this can be done quite easily, but the rendering time will increase.
Tor Olav
http://subcube.com
Download 'vectorfield2.jpg' (129 KB)
Preview of image 'vectorfield2.jpg'
Here's an image with the bars made arrow shaped.
Doing it this way does not increase the rendering time significantly.
Tor Olav
http://subcube.com
Download 'vectorfield3.jpg' (117 KB)
Preview of image 'vectorfield3.jpg'
> > Tor Olav
> > http://subcube.com
> for it.
It will take some time to explain how I did this.
But I'll try to find time within a few days to explain what I've done and post
some source code.
Tor Olav
http://subcube.com
Date: 31 Jan 2010 18:00:34
Message: <4b660b92$1@news.povray.org>
neat ;)
